B1A-10PK
B1A-10PK
    VCC
    LAMP NEON T3.25 MINI BAYO 65V
B1A-10PK 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 Neon Indicator Lamps Part Numbe r C onfiguration T - 2 Midge t Fla nge B a s e A B C A1 G A1 G -R A1 H A1 H -R C7 A C 7 A -R C9 A C 9 A -R G9 B G 9 B -R Old R e f. Numbe r NE -2D NE -2J Design C urre nt mA Ma ximum B r e a kdown V oltage VD C VA C 0. 3 0. 3 1. 2 1. 2 0. 7 0. 7 1. 9 1. 9 1. 2 1. 2 65 65 95 95 65 65 95 95 95 95 90 90 135 135 90 90 135 135 135 135 0. 7 0. 7 1. 2 1. 2 1. 9 1. 9 65 65 95 95 95 95 90 90 135 135 135 135 0. 3 0. 3 1. 2 1. 2 1. 2 1. 2 65 65 95 95 95 95 90 90 135 135 135 135 T - 2 T e l ephone S lide B a s e K1 C 5 K 1 C 5-R K1 B1 K 1 B 1 -R K1 A5 K 1 A 5-R A NE -84 B T - 3 1/4 Minia tur e B a yone t B a s e A B Footnotes 1. Life value is to approximately 50% of initial light output. Values shown apply to use on AC unless otherwise shown. Life on DC is approximately 60% of AC values when DC current is equal to RMS AC value. When equal DC and RMS AC voltages and equal B1 A B 1 A -R B2 A B 2 A -R B2 G B 2 G -R NE NE NE NE NE AR -51 -5 1R -5 1H -5 1H R -5 1G -5 1G R resistances are utilized, life will be approximately the same. 2. For DC operation of high brightness lamps use a minimum of 150 circuit volts. Maximum initial breakdown voltage 95 VAC, 135 VDC in light. CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC. 3. Tinned leads. 4. High brightness. 5. Formed tip. 6. Dark effect reduced. 7. Lamp drops through a Ø.310" cylinder of .500" minimum length. engineered to light up your design www.vcclite.com 1.800.522.5546 S eries R es is tor 100-125V 220-250V W Ohms W Ohms T -2 Midget F lange B as e 1/4 540K 1/3 220K 1/4 220K 1/4 150K 1/3 47K 1/4 47K 1/4 220K 1/3 100K 1/4 100K 1/4 100K 1/3 30K 1/4 30K 1/4 150K 1/3 47K 1/4 47K T -2 T elephone S lide B as e 1/4 220K 1/3 100K 1/4 100K 1/4 150K 1/3 47K 1/4 47K 1/4 100K 1/3 30K 1/4 30K Average Us eful Life T -3 1/4 Miniature B ayonet B as e 1/4 540K 1/3 220K 1/4 220K 1/4 150K 1/3 47K 1/4 47K 1/4 150K 1/3 47K 1/4 47K F ootnotes 1. Life value is to approximately 50% of initial light output. Values s hown apply to us e on AC unles s otherwis e s hown. Life on DC is approximately 60% of AC values when DC current is equal to RMS AC value. When equal DC and RMS AC voltages and equal A(Max.) Dimens ions inches B (Max.) C (Min.) F ootnotes 1,5,12 1,5,11 2,4,5,6,8,12 2,4,5,6,8,11 1,5,12 1,5,11 2,4,5,6,8,12 2,4,5,6,8,11 1,5,12,13 1,5,11,13 25,000 25,000 25,000 25,000 25,000 25,000 25,000 25,000 15,000 15,000 .250 .250 .250 .250 .250 .250 .250 .250 .250 .250 .525 .525 .525 .525 .828 .828 .828 .828 .828 .828 .625 .625 .625 .625 .938 .938 .938 .938 .938 .938 25,000 25,000 25,000 25,000 25,000 25,000 1.03 1.03 1.03 1.03 1.03 1.03 .290 .290 .290 .290 .290 .290 - 1,5,7,12 1,5,7,11 2,4,6,7,8,12 2,4,6,7,8,11 2,4,5,6,7,8,12 2,4,5,6,7,8,11 25,000 25,000 25,000 25,000 15,000 15,000 .430 .430 .430 .430 .430 .430 1.188 1.188 1.188 1.188 1.188 1.188 - 1 1,11 2,4,6,8 2,4,6,9,11 2,4,5,13 2,4,5,11,13 res is tances are utilized, life will be approximately the s ame. 2. F or DC operation of high brightnes s lamps use a minimum of 150 circuit volts . Maximum initial breakdown voltage 95 V AC , 135 V DC in light. CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC. 3. 4. 5. 6. 7. T inned leads . High brightnes s . Formed tip. Dark effect reduced. Lamp drops through a Ø.310" cylinder of .500" minimum length.
B1A-10PK
物料型号:STC89C52RC 器件简介:STC89C52RC是一款8051内核的单片机,适用于多种嵌入式系统应用。
引脚分配:STC89C52RC具有40个引脚,包括电源引脚、地引脚、I/O引脚、控制引脚等。
参数特性:工作电压范围为4.0V至5.5V,最大工作频率为35MHz,内置4KB的ROM和128字节的RAM。
功能详解:STC89C52RC支持多种功能,包括定时器、串行通信、中断处理等。
应用信息:该单片机广泛应用于工业控制、智能家电、医疗设备等领域。
封装信息:STC89C52RC通常采用PDIP封装,也有其他封装形式可供选择。
B1A-10PK 价格&库存
很抱歉,暂时无法提供与“B1A-10PK”相匹配的价格&库存,您可以联系我们找货
