A1C
A1C
    VCC
    LAMP NEON 6.2MM WIRE TERM 95V
A1C 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 Neon Indicator Lamps C o nfigur ation Wire Termina l-Stand ard B ri ghtne ss A B C P a rt Numbe r Old R e f. Numbe r 2M L A1 A A1 A- T A1 B A1 D A1 D- T K4 A A2 B A2 B -T A9 A A9 A- T A9 A- C A9 A- C T NE -3 8S NE -2 NE -2T 1M H A1 C A1 C -T G 2 B -1 G 2 B -2 A3 C A3 C -T C2 A C 2 A -T C 2 A -C D2 A NE -38 AR NE NE NE NE NE NE Des i gn C urre nt mA -9 -2V -2V T -2E -2E T -2E 1 -2E 1T Ma ximum B r e a kdow n Vol t age VD C VA C 0. 3 0. 6 0. 6 0. 3 0. 3 0. 3 0. 3 0. 7 0. 7 0. 7 0. 7 0. 7 0. 7 65 65 65 65 65 65 80 65 65 65 65 65 65 90 90 90 90 90 90 115 90 90 90 90 90 90 1. 2 1. 2 1. 2 1. 2 1. 4 1. 9 1. 9 1. 9 1. 9 1. 9 2. 6 95 95 95 95 95 95 95 95 95 95 95 135 135 135 135 135 135 135 135 135 135 135 Wire T erm ina l-H igh B rightne ss A B C NE NE NE NE NE -2U -2U T -2H -2H T -2H 1 Footnotes 1. Life value is to approximately 50% of initial light output. Values shown apply to use on AC unless otherwise shown. Life on DC is approximately 60% of AC values when DC current is equal to RMS AC value. When equal DC and RMS AC voltages and equal resistances are utilized, life will be approximately the same. 2. For DC operation of high brightness lamps use a minimum of 150 circuit volts. Maximum initial breakdown voltage 95 VAC, 135 VDC in light. 3. Tinned leads. 4. High brightness. 5. Formed tip. 6. Dark effect reduced. 7. Lamp drops through a Ø.310" cylinder of .500" minimum length. CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC. engineered to light up your design www.vcclite.com 1.800.522.5546 Neon Indicator Lamps S eries R es is tor 100-125V 220-250V W Ohms W Ohms Wire T erminal-S tandard B rightnes s 1/4 220K 1/3 100K 1/4 540K 1/3 100K 1/4 540K 1/3 100K 1/4 540K 1/3 220K 1/4 540K 1/3 220K 1/4 540K 1/3 220K 1/4 540K 1/3 220K 1/4 220K 1/3 100K 1/4 220K 1/3 100K 1/4 220K 1/3 100K 1/4 220K 1/3 100K 1/4 220K 1/3 100K 1/4 220K 1/3 100K Wire T erminal-High B rightnes s 1/4 150K 1/3 47K 1/4 150K 1/3 47K 1/4 150K 1/3 47K 1/4 150K 1/3 47K 1/4 120K 1/3 39K 1/4 100K 1/3 30K 1/4 100K 1/3 30K 1/4 100K 1/3 30K 1/4 100K 1/3 30K 1/4 100K 1/3 30K 1/4 68K 1/3 22K Average Us eful Life A(Max.) Dimens ions inches B (Max.) C (Min.) F ootnotes 12,000 25,000 25,000 25,000 25,000 25,000 50 25,000 25,000 25,000 25,000 25,000 25,000 .156 .244 .244 .244 .244 .244 .244 .244 .244 .244 .244 .244 .244 .395 1.00 1.00 .500 .500 .500 .980 .750 .750 .750 .750 .750 .750 1.00 1.00 1.00 1.00 1.00 1.00 1.00 2.00 2.00 2.00 2.00 1.00 1.00 1,5 1,5 1,3,5 1,5 1,5,6 1,3,5,6 14 1,5,6 1,3,5,6 1,5 1,3,5 1,5 1,3,5 12,000 25,000 25,000 15,000 15,000 25,000 25,000 25,000 25,000 25,000 25,000 .156 .244 .244 .244 .244 .244 .244 .244 .244 .244 .244 .395 .500 .500 .500 .750 .750 .750 .750 .750 .750 .980 1.00 1.00 1.00 1.00 1.00 2.00 2.00 2.00 2.00 1.00 1.00 1,4,5 2,4,5,6,8 2,3,4,5,6,8 1,4,5,13 1,4,5,13 2,4,5,6,8,9 2,3,4,5,6,8,9 2,4,5,6,8 2,3,4,5,6,8 2,4,5,6,8 2,4,5,6,8,10 8. Life values shown apply to use on AC unless otherwise shown. End of life occurs when breakdown voltage increases to line voltage and lamp will no longer start. With equal DC and RMS AC current, life will be somewhat lower than the 60% value quoted for standard brightness lamp. 9. Maximum breakdown voltage in total darkness 100VAC. 10. Minimum current for stable operation 1.5mA. 11. Resistor included in Base. 12. Caution: Bulb may shatter and/or circuit may be damaged without external series resistance. 13. Green fluorescent. 14. Argon gas filled. CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
A1C
1. 物料型号:文档列出了不同配置的氖指示灯型号,包括标准亮度和高亮度型号,例如2ML、A1A、A1C、1MH等。
2. 器件简介:CML AVCC产品家族的氖指示灯被设计用于照亮你的设计,由Visual Communications Company, LLC制造。
3. 引脚分配:文档中提到了引脚分配,例如“Wire Terminal”,但未提供具体的引脚分配图或详细说明。
4. 参数特性:提供了不同型号的氖指示灯的设计电流、最大击穿电压等参数,例如2ML型号的设计电流为0.3mA,最大击穿电压为65V AC/90V DC。
5. 功能详解:文档中提到了氖指示灯的使用寿命、电阻配置、尺寸和一些注意事项,例如在AC上使用时的寿命值,以及在DC上使用时的寿命值大约是AC值的60%。
6. 应用信息:文档中没有直接提供应用信息,但可以推断这些氖指示灯适用于需要指示灯的各种电子设备和设计。
7. 封装信息:提供了氖指示灯的尺寸信息,例如A(Max.)、B(Max.)、C(Min.)等。
很抱歉,暂时无法提供与“A1C”相匹配的价格&库存,您可以联系我们找货
