31H-2002T
31H-2002T
    VCC
    IND NEON GREEN 250V SNAPFIT
31H-2002T 数据手册
31 Series Snapfit Indicator Lights for 1.281” x 0.395” (32.54mm x 10.03mm) Mounting Hole Zinc plated bezel, white nylon housing, neon or incandescent lights Overview The 31 Series rectangular indicators feature a wide variety of lens colors and voltage options. Indicator lights quickly snap fit into a 1.281” x 0.395” (32.54mm x 10.03mm mounting hole. Recommended panel thickless range from 0.020” (0.5mm) minimum to 0.090” (2.3mm) maximum. Lenses may be customized with stamped message. Contact your customer service representative for specific ordering information. • • • • • • rectangular indicator lights for 1.281” x 0.395” (32.54mm x 10.03mm) mounting hole 0.250” (6.35mm) tab terminals neon or incandescent indicator lights variety of lens colors UL Listed UL File E20356 Specifications Housing: white nylon. A black housing is available. Bezel: zinc plated steel. A black anodized bezel is available. Lens: polycarbonate. Lenses may be customized with stamped message. Incandescent AC or DC voltage options: 6, 14 and 28 volts. Neon AC or DC voltage options: 125 and 250 volts. Note: high brightness green and blue neon lamps supplied in green and blue neon applications. Terminals: 0.250” (6.35mm) tabs: brass, (.250” (6.35mm) length x 0.030” (.76mm)) thick. engineered to light up your design www.vcclite.com 1.800.522.5546 02/15 Rev 1 Zinc plated bezel, white nylon housing, neon or incandescent lights Part Number Lens Color Lamp Type Design Volts Design Watts or Amps Life (hrs) 31-2111T 31H-2111T 31G1-2111T 31G3-2111T 31G18-2111T 31-2112T 31H-2112T 31G1-2112T 31G3-2112T 31G18-2112T 31-2113T 31H-2113T 31G1-2113T 31G3-2113T 31G18-2113T 31-2114T 31H-2114T 31G1-2114T 31G8-2114T 31G18-2114T 31-2115T 31H-2115T 31G1-2115T 31G3-21115T 31G18-2115T 31-2117T 31H-2117T 31G1-2117T 31G3-2117T 31G18-2117T Red Red Red Red Red Green Green Green Green Green Amber Amber Amber Amber Amber Blue Blue Blue Blue Blue White White White White White Clear Clear Clear Clear Clear Neon Neon Incandescent Incandescent Incandescent Neon Neon Incandescent Incandescent Incandescent Neon Neon Incandescent Incandescent Incandescent Neon Neon Incandescent Incandescent Incandescent Neon Neon Incandescent Incandescent Incandescent Neon Neon Incandescent Incandescent Incandescent 125 250 6 14 28 125 250 6 14 28 125 250 6 14 28 125 250 6 14 28 125 250 6 14 28 125 250 6 14 28 1/3W 1/3W .20A .10A .04A 1/3W 1/3W .20A .10A .04A 1/3W 1/3W .20A .10A .04A 1/3W 1/3W .20A .10A .04A 1/3W 1/3W .20A .10A .04A 1/3W 1/3W .20A .10A .04A 25,000 25,000 5,000 10,000 7,000 25,000 25,000 5,000 10,000 7,000 25,000 25,000 5,000 10,000 7,000 25,000 25,000 5,000 10,000 7,000 25,000 25,000 5,000 10,000 7,000 25,000 25,000 5,000 10,000 7,000 engineered to light up your design www.vcclite.com 1.800.522.5546 02/15 Rev 1 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: VCC: 31G18-2111T 31G18-2112T 31G3-2111T 31-2113T 31-2115T 31-2111T 31G1-2113T 31H-2117T 31G1-2117T 31G3-2112T 31H-2113T 31-2114T 31G1-2114T 31H-2115T 31G3-2115T 31G18-2114T 31G18-2117T 31G12112T 31G3-2114T 31-2117T 31H-2111T 31G18-2115T 31G3-2117T 31G3-2113T 31G1-2115T 31G1-2111T 312112T 31H-2002T 31H-2000
31H-2002T 价格&库存
很抱歉,暂时无法提供与“31H-2002T”相匹配的价格&库存,您可以联系我们找货
