2ML-10PK
2ML-10PK
    VCC
    LAMP NEON WIRE TERM NE-38S 10PK
2ML-10PK 数据手册
TM Neon Indicator Lamps Small neon lamps are most widely used as indicators in electronic equipment and appliances, due to their low power consumption, long life, and ability to operate on mains power Descriptions and Features C o n gur ation Wire Terminal -Stand ard B ri ghtne ss C A B D P a rt Numbe r Old R e f. Numbe r 2M L A1 A A1 A- T A1 B A1 D- T A2 B A2 B -T A9 A A9 A- T A9 A- C NE -38S NE -2 NE -2T NE -2V NE -2V T NE -2E NE -2E T NE -2E 1 Rated [Nominal] Current (mA) Ma ximum B r e a kdown Volt age VD C VA C 0. 3 0. 5 0. 5 0. 3 0. 3 0. 6 0. 7 0. 7 0. 7 0. 7 65 65 65 65 65 65 65 65 65 65 90 95 90 90 90 95 90 90 90 90 0. 6 1. 2 1. 2 1. 2 1. 4 1. 9 1. 9 1. 9 2. 6 95 95 95 95 95 95 95 95 95 135 135 135 135 135 135 135 135 135 Wire T erm inal -H igh Brightness C A B D the first call for illuminated components NE -38 1M H A1 C A1 C -T G 2 B -1 G 2 B -2 A3 C C2 A C 2 A -T D2 A NE -2U NE -2H NE -2H T www.vcclite.com 1  1.800.522.5546 01/17 Rev 1 Product Dimensions S eries R es is tor 100 -125V 220-250V Ohms W W Ohmss Wire Terminal- Standard B rightnes s 220K 1/4 1/3 100K 150K 1/4 1/3 100K 150K 1/4 1/3 100K 540K 1/4 1/3 220K 540K 1/4 1/3 220K 220K 100K 1/4 1/3 220K 1/4 1/3 100K 220K 1/4 1/3 100K 220K 1/4 1/3 100K 220K 1/4 1/3 100K 220K 1/4 1/3 100K Wire T erminal-High B rightnes s 47K 82 K 1/4 1/3 47K 150K 1/4 1/3 47K 150K 1/4 1/3 47K 150K 1/4 1/3 39K 120K 1/4 1/3 30K 100K 1/4 1/3 100K 1/4 1/3 30K 30K 100K 1/4 1/3 22K 1/4 1/3 68K Average Us eful Life A(Max.) Dimens ions inches B (Max.) C F ootnotes D 25,000 25,000 25,000 25,000 25,000 25,000 25,000 25,000 25,000 25,000 25,000 .157 .244 .244 .244 .244 .244 .244 .244 .244 .244 .244 .394 1.00 1.00 .500 .500 .750 .750 .750 .750 .750 .750 1.00 Min. 1.00+0.06 1.06+0.06 1.06+0.06 1.00+0.06 2.06+0.06 2.00 2.06+0.06 2.00 1.00 1.00 1.00 Min. 1.00+0.06 1.06+0.06 1.06+0.06 1.00+0.06 2.06+0.06 2.00 2.06+0.06 2.00 1.00 1.00 12,000 25,000 25,000 15,000 15,000 25,000 25,000 25,000 25,000 .157 .244 .244 .244 .244 .244 .244 .244 .244 .395 .500 .500 .500 .750 .750 .750 .750 .980 1.00 Min. 1.06+0.06 1.00 1.00 1.00 2.06+0.06 2.06+0.06 2.06+0.06 1.00 1.00 Min. 1.06+0.06 1.00 1.00 1.00 2.06+0.06 2.06+0.06 2.06+0.06 1.00 2 2 2 1,3 2 5,6 2 1,3 1,3 2 Part Number 2ML A1A A1A-T A1B A1D-T A2B A2B-T A9A A9A-T A9A-C A9A-CT 1MH A1C A1C-T G2B-1 G2B-2 A3C C2A C2A-T D2A Footnotes 1. Life value is to approximately 50% of initial light output. Values shown apply to use on AC unless otherwise shown. Life on DC is approximately 60% of AC values when DC current is equal to RMS AC value. When equal DC and RMS AC voltages and equal resistances are utilized, life will be approximately the same. 2. Tinned leads. 3. Formed tip. 4. Lamp with a green-light-emitting phosphorous coating. 5. Lead wire spacing: 0.068" + 0.009” (1.75mm + 0.25mm) 6. Lead wire diameter: 0.0150”+ 0.0007” (0.4mm + 0.02mm) Compliances and Approvals the first call for illuminated components www.vcclite.com 2 1.800.522.5546 01/17 Rev 1
2ML-10PK 价格&库存
很抱歉,暂时无法提供与“2ML-10PK”相匹配的价格&库存,您可以联系我们找货
