TM
Neon Indicator Lamps
Small neon lamps are most widely used as indicators
in electronic equipment and appliances, due to their low
power consumption, long life, and ability to operate on mains power
Descriptions and Features
C o n gur ation
Wire Terminal -Stand ard B ri ghtne ss
C
A
B
D
P a rt
Numbe r
Old R e f.
Numbe r
2M L
A1 A
A1 A- T
A1 B
A1 D- T
A2 B
A2 B -T
A9 A
A9 A- T
A9 A- C
NE -38S
NE -2
NE -2T
NE -2V
NE -2V T
NE -2E
NE -2E T
NE -2E 1
Rated
[Nominal]
Current (mA)
Ma ximum
B r e a kdown Volt age
VD C
VA C
0. 3
0. 5
0. 5
0. 3
0. 3
0. 6
0. 7
0. 7
0. 7
0. 7
65
65
65
65
65
65
65
65
65
65
90
95
90
90
90
95
90
90
90
90
0. 6
1. 2
1. 2
1. 2
1. 4
1. 9
1. 9
1. 9
2. 6
95
95
95
95
95
95
95
95
95
135
135
135
135
135
135
135
135
135
Wire T erm inal -H igh Brightness
C
A
B
D
the first call for illuminated components
NE -38
1M H
A1 C
A1 C -T
G 2 B -1
G 2 B -2
A3 C
C2 A
C 2 A -T
D2 A
NE -2U
NE -2H
NE -2H T
www.vcclite.com
1
1.800.522.5546
01/17 Rev 1
Product Dimensions
S eries R es is tor
100 -125V
220-250V
Ohms
W
W
Ohmss
Wire Terminal- Standard B rightnes s
220K
1/4
1/3
100K
150K
1/4
1/3
100K
150K
1/4
1/3
100K
540K
1/4
1/3
220K
540K
1/4
1/3
220K
220K
100K
1/4
1/3
220K
1/4
1/3
100K
220K
1/4
1/3
100K
220K
1/4
1/3
100K
220K
1/4
1/3
100K
220K
1/4
1/3
100K
Wire T erminal-High B rightnes s
47K
82 K
1/4
1/3
47K
150K
1/4
1/3
47K
150K
1/4
1/3
47K
150K
1/4
1/3
39K
120K
1/4
1/3
30K
100K
1/4
1/3
100K
1/4
1/3
30K
30K
100K
1/4
1/3
22K
1/4
1/3
68K
Average
Us eful
Life
A(Max.)
Dimens ions
inches
B (Max.)
C
F ootnotes
D
25,000
25,000
25,000
25,000
25,000
25,000
25,000
25,000
25,000
25,000
25,000
.157
.244
.244
.244
.244
.244
.244
.244
.244
.244
.244
.394
1.00
1.00
.500
.500
.750
.750
.750
.750
.750
.750
1.00 Min.
1.00+0.06
1.06+0.06
1.06+0.06
1.00+0.06
2.06+0.06
2.00
2.06+0.06
2.00
1.00
1.00
1.00 Min.
1.00+0.06
1.06+0.06
1.06+0.06
1.00+0.06
2.06+0.06
2.00
2.06+0.06
2.00
1.00
1.00
12,000
25,000
25,000
15,000
15,000
25,000
25,000
25,000
25,000
.157
.244
.244
.244
.244
.244
.244
.244
.244
.395
.500
.500
.500
.750
.750
.750
.750
.980
1.00 Min.
1.06+0.06
1.00
1.00
1.00
2.06+0.06
2.06+0.06
2.06+0.06
1.00
1.00 Min.
1.06+0.06
1.00
1.00
1.00
2.06+0.06
2.06+0.06
2.06+0.06
1.00
2
2
2
1,3
2
5,6
2
1,3
1,3
2
Part
Number
2ML
A1A
A1A-T
A1B
A1D-T
A2B
A2B-T
A9A
A9A-T
A9A-C
A9A-CT
1MH
A1C
A1C-T
G2B-1
G2B-2
A3C
C2A
C2A-T
D2A
Footnotes
1. Life value is to approximately 50% of initial light output. Values shown apply to
use on AC unless otherwise shown. Life on DC is approximately 60% of AC
values when DC current is equal to RMS AC value. When equal DC and RMS
AC voltages and equal resistances are utilized, life will be approximately the
same.
2. Tinned leads.
3. Formed tip.
4. Lamp with a green-light-emitting phosphorous coating.
5. Lead wire spacing: 0.068" + 0.009” (1.75mm + 0.25mm)
6. Lead wire diameter: 0.0150”+ 0.0007” (0.4mm + 0.02mm)
Compliances and Approvals
www.vcclite.com
2
1.800.522.5546
01/17 Rev 1
很抱歉,暂时无法提供与“D2A”相匹配的价格&库存,您可以联系我们找货
