COM-10796
COM-10796
    SPARKFUNELECTRONICS
    ELTAPE-RED(1M)
COM-10796 数据手册
1 Product code YF-659-B-2 2 Size (mm) 1004*14 3 4 Emitting size (mm) Leads Distance of Leads (mm) 985*10 FPC 5 6 Laminate 7 Thickness (mm) 8 Surface color 10 Emitting Color 5.08 Tolerance: ±0.2 Tolerance: ±0.2 Double Sealing 0.4 Blue, BlueGreen, Red, White, Greene Blue, Bluegreen, Red, Blue-White, Green 11 Testing Voltage 110 12 Testing frequency 400HZ 13 14 Candela (cd/ m2) Electric Current (mA/cm2) Power consumption (mw/cm2) 35 0.03 High Voltage test (VPP) ≤200 17 Optimal Life Time 8000 H 18 Connection Wire JST PHR-2 Female 15 16 3.6 Reliability Test Item Test Condition Life Time Temperature Humidity Normal Temperature 20℃ 65% 3000-5000H High Temperature, Humidity 40±2℃ 90% 100H High Temperature Storage 70±3℃ 10% 1000H Low Temperature Storage -30±3℃, / 1000H 60±2℃ 90% 1000H High Temperature and Humidity Storage EL Tape (100* 1 cm) SPECIFICATIONS
COM-10796 价格&库存
很抱歉,暂时无法提供与“COM-10796”相匹配的价格&库存,您可以联系我们找货
