446
446
    ADAFRUIT
    ELECTROLUMINESCNSTRIPGRN100CM
446 数据手册
      Green Electroluminescent (EL) Tape Strip 100cm w/2 connectors PRODUCT ID: 446       Description EL tape is the big sister to EL wire ‐ it has the same glow effect but with a flat, wide shape instead of a  round shape. The glowing part of the tape is 1 cm wide (the plastic coating is about 1.5cm wide). The  other side has an adhesive on it so you can stick the tape onto something. Its covered in what seems to  be PVC, the tape is thus weather‐proof ‐ but note that the connectors are NOT waterproof, just a bit of  heatshrink. This isn't something we would suggest leaving outdoors for extended periods.    Because EL tape has more surface area than wire, it requires a more powerful inverter for the same  length. This tape is about 4 times more capacitive (per length) than our high‐brightness EL wire and 8  times more capacitive than 'standard' EL wire. For that reason, we are shipping the EL tape in 100cm  lengths with two EL connectors soldered on, one on each end. You can cut it into two pieces of any  length and use both halves!    Note that the maximum amount for the 2xAA pocket inverter we carry is 60cm so don't try to run the  full strip off of one inverter ‐ it will look dim and isnt nice to the inverter ‐ cut it in half first! Plug it in  and it will light up nicely! A 50cm strip draws about 200mA from the 2xAA batteries in the pocket  inverter (so 2000mAh batteries will last ~10 hours if on 'constant' mode). You can also use our 4xAAA  inverter which is strong enough to power a full meter at once ‐ plug in only one end of the tape to the  inverter or cut it in half and plug both halves in.    Please note! EL tape, EL wire and EL panel are made with different processes and so the color and  brightness will not be consistant between the two: green tape, green wire and green panels will not  necessarily match!  Technical Details o o o o o o o o Size: 100 cm x 1.5 cm about 1mm thick  Panel lifetime: >25000 hours  Operating voltage: 60‐250VAC  Operating Frequency: 50‐5000HZ  Current Draw: 0.14mA/cm2 (max) @ 110V / 400Hz  Initial Brightness: 80 cd/m2  Operating Temperature: ‐50 C / 65 C  ~10 nF per meter  It is very difficult to reattach connectors to EL tape once its been cut, but here is a tutorial that shows  how it can be done  http://www.instructables.com/id/How‐to‐Attach‐or‐Reattach‐EL‐Tape‐ Electrolumine/        https://www.adafruit.com/product/446 8‐8‐17
很抱歉,暂时无法提供与“446”相匹配的价格&库存,您可以联系我们找货
