Page 1 of 2
EL WIRE/TAPE/PANEL / PANELS
Electroluminescent (EL) Panel - 20cm x
15cm Aqua
PRODUCT ID: 414
Page 2 of 2
DESCRIPTION
This is a big sheet of flexible plastic coated with EL material so its like one big
glowing square. It emits an even aqua glow over the entire shape, and you can even
cut it into any shape you want using scissors as long as the connector is still
attached (you'll probably need a few inches of the edge as well). Another option if
you want to have a custom design, we suggest cutting something opaque to 'mask
it' or printing onto a transparency and placing that on top. We do not suggest laser
cutting it (the coating may be toxic), although a vinyl-cutter might work OK.
Measures 20 cm x 15 cm (7.9" x 5.9"), about 0.5mm thick. Its covered in what
seems to be PVC, the panel is thus spill proof - but note that the connector is NOT
waterproof, just a bit of heatshrink. This isn't something we would suggest leaving
outdoors for extended periods.
Comes with a matching high power 12V inverter and a female DC jack so you can
plug it directly into a 12V supply. The inverter is a 'potted waterproof type' and is
thus very quiet (no resonating cavity!). This panel is not going to run on our pocket
inverter, you really need to have 12V! The full panel draws about 210 mA from a
12V supply. For portable use, we suggest a 8xAA battery holder
Please note! EL tape, EL wire and EL panel are made with different processes and so
the color and brightness will not be consistant between the two: aqua tape, aqua
wire and aqua panels will not necessarily match!
http://www.adafruit.com/products/414
7/23/2015
很抱歉,暂时无法提供与“414”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+313.330051+39.29219
