953
953
    ADAFRUIT
    SWITCH PUSH SPDT 0.25A 120V
953 数据手册
Page 1 of 2 EL WIRE/TAPE/PANEL / EL STARTER PACKS EL Flowing Effect Wire with Inverter - Pink 2.0 meter (6.5 ft) PRODUCT ID: 953 Page 2 of 2 DESCRIPTION - If you want to make your EL project a little more dynamic, you can swap in this nifty 'flowing effect' EL wire for the every-day stuff. Instead of a single core, this wire is actually a bundle of three thin EL wires. Inside the inverter is a little timer that will cycle through the strands to make it look like its moving. There's a wheel to adjust the speed and a button to select the mode. The three modes are 'all on', 'all off' and 'flow effect' This pack comes with 2 meters of EL flow wire attached to a 2xAA inverter, use any AA batteries (alkalines are better and brighter but it works fine with the NiMH rechargeables we tried). There's a belt clip on the inverter so you can attach it to something. This EL type isn't meant to be cut and re-soldered because of the triple-core so keep in mind that you can cut it short but we don't suggest trying to splice or re-solder to the wire. Lasts about 5 hours on a set of two batteries. http://www.adafruit.com/products/953 7/27/2015
很抱歉,暂时无法提供与“953”相匹配的价格&库存,您可以联系我们找货
