SLED-56-16639
SLED-56-16639
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    Through Hole
    Infrared (IR) Emitter 940nm 1.3V 40mA 140° Radial
SLED-56-16639 数据手册
SLED-56-16639 IR Side Emitter Features  Side-emitting plastic package with dome lens  940nm wavelength 4.50 5.72 Description The SLED-56-16639 is a Gallium arsenide infrared emitter mounted in a side-emitting plastic water clear non-diffused package. The chip is positioned to direct the optical energy through the side of the mechanical axis of the device. The in-line beam angle provides high on-axis intensity for excellent coupling efficiency. -20 to +70C -25 to +80C 260C Notes: (1) 3mm from case for < 5 sec. 14.0 min Dimensions in mm Tolerance is +/-0.1 unless otherwise noted Prodruded resin under flange is 1.0mm max. 2.54 nom 1.0 0.8 0.6 0.4 0.2 0 900 Electrical Characteristics (TA=25C unless otherwise noted) Symbol Parameter Min Typ Ee Radiant Incidance 0.4 0.8 Peak wavelength 940 P Spectrum Bandwidth 50  VF Forward Voltage 1.3 IR Reverse Current 140 21/2 Emission angle VBR Reverse Breakdown Voltage 3.0 Specifications subject to change without notice. Advanced Photonix Canada Inc., 300 St-Sacrement Suite 519 Montréal, QC, Canada H2Y 1X4 Anode Cathode 0.38 SQ RELATIVE RADIANT INTENSITY Storage Temperature Operating Temperature Soldering Temperature (1) 75mW 40mA 5V Schematic 2.39 4.42 A node Absolute Maximum Ratings Power Dissipation Forward Current Reverse Voltage 1.50 Dia.1.5 940 WAVE LENGTH (nm) Max 1.5 10 Units mW/cm^2 nm nm V A deg V 990 Test Conditions IF = 20 mA IF = 20 mA IF = 20 mA IF = 20 mA VR = 5V IF = 20 mA IR=10μA REV 04/04-14 Page 1 Phone:(514) 768-8000 Fax: (514) 768-8889 http://www.advancedphotonix.com
SLED-56-16639 价格&库存
很抱歉,暂时无法提供与“SLED-56-16639”相匹配的价格&库存,您可以联系我们找货
