UV LED LAMP
VAOL-3GUV0Y4
Feature
Package Dimension
Low Power Consumption
I.C. compatible
Applications
Disinfection and Sterilization
Adhesive Curing
Leak Detection
Authentication
047
12
Description
These LEDs are Based on InGaN
Material Technology
Emitted color: Purple (UV)
Water Transparent Lens
*Tolerance:±
0.01
0.25
Unit:±
inch
mm
CAUTION : EMITS ULTRAVIOLET RADIATION!!!
• This UV (ultraviolet) LED during operation radiates intense UV light.
• Do Not look directly into the UV light during operation of device. This can be harmful to the human body especially
to the eyes and skin, even for brief period due to the intense UV light.
• If viewing the UV light is necessary, please use UV filtered glasses to avoid damage by the UV light.
UV
• If the UV LED in your product might be viewed directly, please affix a caution label to your product to that effect.
• Avoid direct eye and skin exposure to the UV light.
• Keep reach out of children.
Absolute Maximum Ratings at Ta=25°C
Symbol
Parameter
Max.
Unit
120
mW
PD
Power Dissipation
VR
Reverse Voltage
5
V
IAF
Average Forward Current
30
mA
IPF
Peak Forward Current(Duty=0.1,1kHz)
100
mA
Derating Linear Form 25°C
0.4
mA/°C
Topr
Operating Temperature Range
–20 to + 80
°C
Tstg
Storage Temperature Range
–20 to + 100
°C
Lead Soldering Temperature [1.6mm(0.063inch)From Body] 260°C For 5 Seconds.
Electrical / Optical Characteristics and Curves at Ta=25°C
Symbol
Parameter
Test Condition
Min.
Typ.
Max. Unit
2.8
3.0
3.6
V
µA
30
100
Deg.
VF
Forward Voltage
IF=
20 mA
IR
Reverse Current
VR=
5 V
Half Intensity Angle
IF=
20 mA
IV
Luminous Intensity
IF=
20 mA
120
mcd.
λp
Peak Wavelength
IF=
20 mA
400
405
nm
Electrical Characteristics at Ta
25
Symbol
Iv
VF
p
Parameter
Luminous Intensity
Forward Voltage
Peak Wavelength
Condition
IF20mA
IF20mA
IF20mA
Unit
mcd
V
nm
Grade
Range
Grade
Range
Grade
Range
BIN 9
90~125
P0
2.8~3.0
U6
400~405
BIN 10
125~175
P1
3.0~3.2
U7
405~410
P2
3.2~3.4
P3
3.4~3.6
Binning
Intensity: Tolerance of minimum and maximum = ± 15%
Vf: Tolerance of minimum and maximum = ± 0.05v
NOTE:
1. Static electricity and surge damages the LED. It is recommend to use a anti-static wrist
band or anti-electrostatic glove when handing the LEDs. All devices, equipment and machinery
must be properly grounded.
Radiation Diagram
IF=20 mA 50% Power Angle
Angle =30
UV
很抱歉,暂时无法提供与“VAOL-3GUV0Y4”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+6.08040
- 200+2.43000
- 500+2.35440
- 1000+2.31120
- 国内价格 香港价格
- 1+12.093871+1.56957
- 10+8.5617810+1.11117
- 100+6.40580100+0.83136
- 500+5.44876500+0.70715
- 1000+5.136021000+0.66657
- 2000+4.870732000+0.63213
- 5000+4.581245000+0.59457
- 10000+4.4009710000+0.57117
