LZ4-00UA00-0000
LZ4-00UA00-0000
    AMSOSRAM(艾迈斯半导体)
    SMD8
    EMITTER UV 395NM 1A
LZ4-00UA00-0000 数据手册
High Efficacy VIOLET LED Emitter LZ4-00UA00 Key Features  High Efficacy 10W Violet LED  Ultra-small foot print – 7.0mm x 7.0mm  Surface mount ceramic package with integrated glass lens  Very low Thermal Resistance (1.1°C/W)  Electrically neutral thermal path  Individually addressable die  Very high Radiant Flux density  JEDEC Level 1 for Moisture Sensitivity Level  Autoclave complaint (JEDEC JESD22-A102-C)  Lead (Pb) free and RoHS compliant  Reflow solderable (up to 6 cycles)  Emitter available on Standard or Serially Connected MCPCB (optional) Typical Applications  Dental Curing and Teeth Whitening  Sterilization and Medical  Ink and Adhesive Curing  DNA Gel Description The LZ4-00UA00 VIOLET LED emitter provides superior radiometric power in the wavelength range specifically required for sterilization, dental curing lights, and numerous medical applications. With a 7.0mm x 7.0mm ultrasmall footprint, this package provides exceptional optical power density. The radiometric power performance and optimal peak wavelength of this LED are matched to the response curves of many dental resins, inks & adhesives, resulting in a significantly reduced curing time. The patent-pending design has unparalleled thermal and optical performance. The high quality materials used in the package are chosen to optimize light output, have excellent VIOLET resistance, and minimize stresses which results in monumental reliability and radiant flux maintenance. UV RADIATION Avoid exposure to the beam Wear protective eyewear COPYRIGHT © 2016 LED ENGIN. ALL RIGHTS RESERVED. LZ4-00UA00 (6.2 – 10/21/16) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com Part number options Base part number Part number Description LZ4-00UA00-xxxx LZ4 emitter LZ4-40UA00-xxxx LZ4 emitter on Standard Star 1 channel MCPCB Bin kit option codes Single wavelength bin (5nm range) Kit number suffix Min flux Bin Color Bin Range Description 00U4 R U4 R minimum flux; wavelength U4 bin only 00U5 S U5 S minimum flux; wavelength U5 bin only 00U6 S U6 S minimum flux; wavelength U6 bin only 00U7 S U7 S minimum flux; wavelength U7 bin only 00U8 S U8 S minimum flux; wavelength U8 bin only COPYRIGHT © 2016 LED ENGIN. ALL RIGHTS RESERVED. LZ4-00UA00 (6.2 – 10/21/16) 2 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com Radiant Flux Bins Table 1: Bin Code Minimum Radiant Flux (Φ) @ IF = 700mA [1,2] (W) Maximum Radiant Flux (Φ) @ IF = 700mA [1,2] (W) R 2.40 3.00 S 3.00 3.80 T 3.80 4.80 Notes for Table 1: 1. Radiant flux performance guaranteed within published operating conditions. LED Engin maintains a tolerance of ± 10% on flux measurements. 2. Future products will have even higher levels of radiant flux performance. Contact LED Engin Sales for updated information. Peak Wavelength Bins Table 2: Bin Code Minimum Peak Wavelength (λP) @ IF = 700mA [1] (nm) Maximum Peak Wavelength (λP) @ IF = 700mA [1] (nm) U4 385 390 U5 390 395 U6 395 400 U7 400 405 U8 405 410 Notes for Table 2: 1. LED Engin maintains a tolerance of ± 2.0nm on peak wavelength measurements. Forward Voltage Bins Table 3: Bin Code Minimum Forward Voltage (VF) @ IF = 700mA [1,2] (V) Maximum Forward Voltage (VF) @ IF = 700mA [1,2] (V) 0 13.76 18.56 Notes for Table 3: 1. LED Engin maintains a tolerance of ± 0.16V for forward voltage measurements. 2. Forward Voltage is binned with all four LED dice connected in series. COPYRIGHT © 2016 LED ENGIN. ALL RIGHTS RESERVED. LZ4-00UA00 (6.2 – 10/21/16) 3 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com Absolute Maximum Ratings Table 4: Parameter Symbol Value Unit IF IFP VR Tstg TJ Tsol 1000 1000 See Note 3 -40 ~ +150 125 260 6 mA mA V °C °C °C [1] DC Forward Current Peak Pulsed Forward Current [2] Reverse Voltage Storage Temperature Junction Temperature Soldering Temperature Allowable Reflow Cycles Autoclave Conditions [4] 121°C at 2 ATM, 100% RH for 168 hours ESD Sensitivity [5] > 2,000 V HBM Class 2 JESD22-A114-D Notes for Table 4: 1. Maximum DC forward current is determined by the overall thermal resistance and ambient temperature. Follow the curves in Figure 10 for current derating. 2: Pulse forward current conditions: Pulse Width ≤ 10msec and Duty Cycle ≤ 10%. 3. LEDs are not designed to be reverse biased. 4. Autoclave Conditions per JEDEC JESD22-A102-C. 5. LED Engin recommends taking reasonable precautions towards possible ESD damages and handling the LZ4-00UA00 in an electrostatic protected area (EPA). An EPA may be adequately protected by ESD controls as outlined in ANSI/ESD S6.1. Optical Characteristics @ TC = 25°C Table 5: Typical Parameter Symbol Radiant Flux (@ IF = 700mA) Radiant Flux (@ IF = 1000mA) Peak Wavelength Viewing Angle [1] [2] Total Included Angle [3] Unit 385-390nm 390-400nm 400-410nm Φ 2.95 3.50 3.90 W Φ 4.10 4.90 5.45 W λP 385 395 405 nm 2Θ1/2 97 Degrees Θ0.9V 120 Degrees Notes for Table 5: 1. When operating the VIOLET LED, observe IEC 60825-1 class 3B rating. Avoid exposure to the beam. 2. Viewing Angle is the off axis angle from emitter centerline where the radiant power is ½ of the peak value. 3. Total Included Angle is the total angle that includes 90% of the total radiant flux. Electrical Characteristics @ TC = 25°C Table 6: Parameter Symbol Typical 1 Die 3.9 4.1 4 Dice 15.6 16.5 Unit Forward Voltage (@ IF = 700mA) Forward Voltage (@ IF = 1000mA) VF VF Temperature Coefficient of Forward Voltage ΔVF/ΔTJ -14.2 mV/°C Thermal Resistance (Junction to Case) RΘJ-C 1.1 °C/W COPYRIGHT © 2016 LED ENGIN. ALL RIGHTS RESERVED. V V LZ4-00UA00 (6.2 – 10/21/16) 4 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com IPC/JEDEC Moisture Sensitivity Level Table 7 - IPC/JEDEC J-STD MSL-20 Classification: Soak Requirements Floor Life Standard Accelerated Level Time Conditions Time (hrs) Conditions Time (hrs) Conditions 1 Unlimited ≤ 30°C/ 85% RH 168 +5/-0 85°C/ 85% RH n/a n/a Notes for Table 7: 1. The standard soak time is the sum of the default value of 24 hours for the semiconductor manufacturer’s exposure time (MET) between bake and bag and the floor life of maximum time allowed out of the bag at the end user of distributor’s facility. Average Radiant Flux Maintenance Projections Lumen maintenance generally describes the ability of an emitter to retain its output over time. The useful lifetime for power LEDs is also defined as Radiant Flux Maintenance, with the percentage of the original light output remaining at a defined time period. Based on long-term WHTOL testing, LED Engin projects that the LZ Series will deliver, on average, 70% Radiant Flux Maintenance (RP70%) at 20,000 hours of operation at a forward current of 700 mA per die. This projection is based on constant current operation with junction temperature maintained at or below 80°C. COPYRIGHT © 2016 LED ENGIN. ALL RIGHTS RESERVED. LZ4-00UA00 (6.2 – 10/21/16) 5 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com Mechanical Dimensions (mm) Pin Out Pad Die 1 A Anode 2 A Cathode 3 B Anode 4 B Cathode 5 C Anode 6 C Cathode 7 D Anode 8 D Cathode 9 [2] n/a Thermal 1 2 Function 3 8 4 Figure 1: Package outline drawing. 7 Notes for Figure 1: 1. Unless otherwise noted, the tolerance = ± 0.20 mm. 2. Thermal contact, Pad 9, is electrically neutral. 6 5 Recommended Solder Pad Layout (mm) Non-pedestal MCPCB Design Pedestal MCPCB Design Figure 2a: Recommended solder pad layout for anode, cathode, and thermal pad for non-pedestal and pedestal design Note for Figure 2a: 1. Unless otherwise noted, the tolerance = ± 0.20 mm. 2. Pedestal MCPCB allows the emitter thermal slug to be soldered directly to the metal core of the MCPCB. Such MCPCB eliminate the high thermal resistance dielectric layer that standard MCPCB technologies use in between the emitter thermal slug and the metal core of the MCPCB, thus lowering the overall system thermal resistance. 3. LED Engin recommends x-ray sample monitoring for solder voids underneath the emitter thermal slug. The total area covered by solder voids should be less than 20% of the total emitter thermal slug area. Excessive solder voids will increase the emitter to MCPCB thermal resistance and may lead to higher failure rates due to thermal over stress. COPYRIGHT © 2016 LED ENGIN. ALL RIGHTS RESERVED. LZ4-00UA00 (6.2 – 10/21/16) 6 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com Recommended Solder Mask Layout (mm) Non-pedestal MCPCB Design Pedestal MCPCB Design Figure 2b: Recommended solder mask opening for anode, cathode, and thermal pad for non-pedestal and pedestal design Note for Figure 2b: 1. Unless otherwise noted, the tolerance = ± 0.20 mm. Recommended 8 mil Stencil Apertures Layout (mm) Non-pedestal MCPCB Design Pedestal MCPCB Design Figure 2c: Recommended 8mil stencil apertures for anode, cathode, and thermal pad for non-pedestal and pedestal design Note for Figure 2c: 1. Unless otherwise noted, the tolerance = ± 0.20 mm. COPYRIGHT © 2016 LED ENGIN. ALL RIGHTS RESERVED. LZ4-00UA00 (6.2 – 10/21/16) 7 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com Reflow Soldering Profile Figure 3: Reflow soldering profile for lead free soldering. Notes for Figure 3: 1. Solder profile for low temperature solder. LED Engin recommends 58Bi-42Sn (wt.%) Solder for the LZ4-00UA00. Typical Radiation Pattern 100 90 Relative Intensity (%) 80 70 60 50 40 30 20 10 0 -90 -80 -70 -60 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 Angular Displacement (Degrees) Figure 4: Typical representative spatial radiation pattern. COPYRIGHT © 2016 LED ENGIN. ALL RIGHTS RESERVED. LZ4-00UA00 (6.2 – 10/21/16) 8 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com Typical Relative Spectral Power Distribution 1 Relative Spectral Power 0.9 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 300 350 400 450 500 Wavelength (nm) Figure 5: Typical relative spectral power vs. wavelength @ TC = 25°C. Typical Peak Wavelength Shift over Temperature Peak Wavelength Shift (nm) 5.0 4.0 3.0 2.0 1.0 0.0 0 20 40 60 80 100 120 Case Temperature (ºC) Figure 6: Typical peak wavelength shift vs. case temperature. COPYRIGHT © 2016 LED ENGIN. ALL RIGHTS RESERVED. LZ4-00UA00 (6.2 – 10/21/16) 9 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com Typical Normalized Radiant Flux 1.4 Normalized Radiant Flux 1.2 1 0.8 0.6 0.4 0.2 0 0 200 400 600 800 1000 IF - Forward Current (mA) Figure 7: Typical normalized radiant flux vs. forward current @ TC = 25°C. Typical Normalized Radiant Flux over Temperature 1.20 Normalized Radiant Flux 1.00 0.80 0.60 0.40 0.20 0.00 0 20 40 60 80 100 120 Case Temperature (oC) Figure 8: Typical normalized radiant flux vs. case temperature @700mA COPYRIGHT © 2016 LED ENGIN. ALL RIGHTS RESERVED. LZ4-00UA00 (6.2 – 10/21/16) 10 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com Typical Forward Current Characteristics 1200 IF - Forward Current (mA) 1000 800 600 400 200 0 11.0 12.0 13.0 14.0 15.0 16.0 17.0 18.0 VF - Forward Voltage (V) Figure 9: Typical forward current vs. forward voltage @ TC = at 25°C. Current De-rating IF - Maximum Current (mA) 1200 1000 800 700 (Rated) 600 400 RΘJ-A = 4°C/W RΘJ-A = 5°C/W RΘJ-A = 6°C/W 200 0 0 25 50 75 100 125 Maximum Ambient Temperature (ºC) Figure 10: Maximum forward current vs. ambient temperature based on TJ(MAX) = 125°C. Notes for Figure 10: 1. RΘJ-C [Junction to Case Thermal Resistance] for the LZ4-00UA00 is typically 1.1°C/W. 2. RΘJ-A [Junction to Ambient Thermal Resistance] = RΘJ-C + RΘC-A [Case to Ambient Thermal Resistance]. COPYRIGHT © 2016 LED ENGIN. ALL RIGHTS RESERVED. LZ4-00UA00 (6.2 – 10/21/16) 11 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com Emitter Tape and Reel Specifications (mm) Figure 11: Emitter carrier tape specifications (mm). Figure 12: Emitter Reel specifications (mm). Notes: 1. Packaging contains VIOLET caution labels. Avoid exposure to the beam and wear appropriate protective eyewear when operating the VIOLET LED. COPYRIGHT © 2016 LED ENGIN. ALL RIGHTS RESERVED. LZ4-00UA00 (6.2 – 10/21/16) 12 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com LZ4 MCPCB Family Part number Type of MCPCB Diameter (mm) LZ4-4xxxxx 1-channel 19.9 Emitter + MCPCB Typical Vf Thermal Resistance (V) (°C /W) Typical If (mA) 1.1 + 1.1 = 2.2 700 15.6 Mechanical Mounting of MCPCB   MCPCB bending should be avoided as it will cause mechanical stress on the emitter, which could lead to substrate cracking and subsequently LED dies cracking. To avoid MCPCB bending: o Special attention needs to be paid to the flatness of the heat sink surface and the torque on the screws. o Care must be taken when securing the board to the heat sink. This can be done by tightening three M3 screws (or #4-40) in steps and not all the way through at once. Using fewer than three screws will increase the likelihood of board bending. o It is recommended to always use plastics washers in combinations with the three screws. o If non-taped holes are used with self-tapping screws, it is advised to back out the screws slightly after tightening (with controlled torque) and then re-tighten the screws again. Thermal interface material    To properly transfer heat from LED emitter to heat sink, a thermally conductive material is required when mounting the MCPCB on to the heat sink. There are several varieties of such material: thermal paste, thermal pads, phase change materials and thermal epoxies. An example of such material is Electrolube EHTC. It is critical to verify the material’s thermal resistance to be sufficient for the selected emitter and its operating conditions. Wire soldering   o To ease soldering wire to MCPCB process, it is advised to preheat the MCPCB on a hot plate of 125-150 C. Subsequently, apply the solder and additional heat from the solder iron will initiate a good solder reflow. It is recommended to use a solder iron of more than 60W. It is advised to use lead-free, no-clean solder. For example: SN-96.5 AG-3.0 CU 0.5 #58/275 from Kester (pn: 24-7068-7601) COPYRIGHT © 2016 LED ENGIN. ALL RIGHTS RESERVED. LZ4-00UA00 (6.2 – 10/21/16) 13 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com LZ4-4xxxxx 1 channel, Standard Star MCPCB (1x4) Dimensions (mm) Notes:  Unless otherwise noted, the tolerance = ± 0.2 mm.  Slots in MCPCB are for M3 or #4-40 mounting screws.  LED Engin recommends plastic washers to electrically insulate screws from solder pads and electrical traces.  Electrical connection pads on MCPCB are labeled “+” for Anode and “-” for Cathode  LED Engin recommends thermal interface material when attaching the MCPCB to a heatsink  The thermal resistance of the MCPCB is: RΘC-B 1.1°C/W Components used MCPCB: ESD chips: HT04503 BZX585-C30 (Bergquist) (NXP, for 4 LED dies in series) Pad layout Ch. 1 MCPCB Pad 1, 2, 3 4, 5 String/die Function 1/ABCD Cathode Anode + COPYRIGHT © 2016 LED ENGIN. ALL RIGHTS RESERVED. LZ4-00UA00 (6.2 – 10/21/16) 14 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com Company Information LED Engin, Inc., based in California’s Silicon Valley, specializes in ultra-bright, ultra compact solid state lighting solutions allowing lighting designers & engineers the freedom to create uncompromised yet energy efficient lighting experiences. The LuxiGen™ Platform — an emitter and lens combination or integrated module solution, delivers superior flexibility in light output, ranging from 3W to 90W, a wide spectrum of available colors, including whites, multi-color and UV, and the ability to deliver upwards of 5,000 high quality lumens to a target. The small size combined with powerful output allows for a previously unobtainable freedom of design wherever high-flux density, directional light is required. LED Engin’s packaging technologies lead the industry with products that feature lowest thermal resistance, highest flux density and consummate reliability, enabling compact and efficient solid state lighting solutions. LED Engin is committed to providing products that conserve natural resources and reduce greenhouse emissions. LED Engin reserves the right to make changes to improve performance without notice. Please contact sales@ledengin.com or (408) 922-7200 for more information. COPYRIGHT © 2016 LED ENGIN. ALL RIGHTS RESERVED. LZ4-00UA00 (6.2 – 10/21/16) 15 LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com
LZ4-00UA00-0000 价格&库存
很抱歉,暂时无法提供与“LZ4-00UA00-0000”相匹配的价格&库存,您可以联系我们找货
