LZ4-00R508-0000
LZ4-00R508-0000
    AMSOSRAM(艾迈斯半导体)
    SMD8
    EMITTERIR920NM1ASMD
LZ4-00R508-0000 数据手册
940nm Infrared LED Emitter LZ4-00R508 Key Features  High Efficacy 940nm 5W Infrared LED  Ultra-small foot print – 7.0mm x 7.0mm  Surface mount ceramic package with integrated glass lens  Low Thermal Resistance (2.8°C/W)  Individually addressable die  Very high Radiant Flux density  Autoclave compliant (JEDEC JESD22-A102-C)  JEDEC Level 1 for Moisture Sensitivity Level  Lead (Pb) free and RoHS compliant  Reflow solderable (up to 6 cycles)  Emitter available on Serially Connected MCPCB (optional) Typical Applications  Inspection  Security lighting Description The LZ4-00R508 940nm Infrared LED emitter generates 1.9W nominal output at 5W power dissipation in an extremely small package. With a 7.0mm x 7.0mm ultra-small footprint, this package provides exceptional radiant flux density. The patented design has unparalleled thermal and optical performance. The high quality materials used in the package are chosen to optimize light output and minimize stresses which results in monumental reliability and lumen maintenance. The robust product design thrives in outdoor applications with high ambient temperatures and high humidity. COPYRIGHT © 2013 LED ENGIN. ALL RIGHTS RESERVED LZ4-00R508 (1.0 – 08/23/13) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com Part number options Base part number Part number Description LZ4-00R508-xxxx LZ4 emitter LZ4-40R508-xxxx LZ4 emitter on 1 channel Standard Star MCPCB Bin kit option codes R5, Infrared (940nm) Kit number suffix Min flux Bin Color Bin Range Description 0000 N F09 full distribution flux; full distribution wavelength Notes: 1. Default bin kit option is -0000 COPYRIGHT © 2013 LED ENGIN. ALL RIGHTS RESERVED 2 LZ4-00R508 (1.0 – 08/23/13) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com Radiant Flux Bins Table 1: Bin Code Minimum Radiant Flux (Φ) @ IF = 700mA [1,2] (W) Maximum Radiant Flux (Φ) @ IF = 700mA [1,2] (W) N 1.25 1.60 P 1.60 2.00 Q 2.00 2.40 Notes for Table 1: 1. Radiant flux performance guaranteed within published operating conditions. LED Engin maintains a tolerance of ± 10% on flux measurements. 2. Future products will have even higher levels of radiant flux performance. Contact LED Engin Sales for updated information. Peak Wavelength Bin Table 2: Bin Code Minimum Peak Wavelength (λP) @ IF = 700mA [1] (nm) Maximum Peak Wavelength (λP) @ IF = 700mA [1] (nm) F09 920 960 Notes for Table 2: 1. LED Engin maintains a tolerance of ± 2.0nm on peak wavelength measurements. Forward Voltage Bins Table 3: Bin Code Minimum Forward Voltage (VF) @ IF = 700mA [1,2] (V) Maximum Forward Voltage (VF) @ IF = 700mA [1,2] (V) 0 6.8 10.8 Notes for Table 3: 1. Forward Voltage is binned with all four LED dice connected in series. 2. LED Engin maintains a tolerance of ± 0.16V for forward voltage measurements for the four LEDs. COPYRIGHT © 2013 LED ENGIN. ALL RIGHTS RESERVED 3 LZ4-00R508 (1.0 – 08/23/13) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com Absolute Maximum Ratings Table 4: Parameter Symbol Value Unit IF IFP VR Tstg TJ Tsol 1000 2000 See Note 3 -40 ~ +125 125 260 6 mA [1] DC Forward Current Peak Pulsed Forward Current [2] Reverse Voltage Storage Temperature Junction Temperature Soldering Temperature [4] Allowable Reflow Cycles mA V °C °C °C Autoclave Conditions [5] 121°C at 2 ATM, 100% RH for 168 hours ESD Sensitivity [6] > 8,000 V HBM Class 3B JESD22-A114-D Notes for Table 4: 1. Maximum DC forward current (per die) is determined by the overall thermal resistance and ambient temperature. Follow the curves in Figure 11 for current derating. 2: Pulse forward current conditions: Pulse Width ≤ 10msec and Duty Cycle ≤ 10%. 3. LEDs are not designed to be reverse biased. 4. Solder conditions per JEDEC 020D. See Reflow Soldering Profile Figure 3. 5. Autoclave Conditions per JEDEC JESD22-A102-C. 6. LED Engin recommends taking reasonable precautions towards possible ESD damages and handling the LZ4-00R508 in an electrostatic protected area (EPA). An EPA may be adequately protected by ESD controls as outlined in ANSI/ESD S6.1. Optical Characteristics @ TC = 25°C Table 5: Parameter Radiant Flux (@ IF = 700mA) Symbol Typical Unit Φ 1.90 W Φ 2.65 W λP 940 nm 2Θ1/2 95 Degrees Θ0.9 110 Degrees [1] Radiant Flux (@ IF = 1000mA) [1] [2] Peak Wavelength Viewing Angle [3] Total Included Angle [4] Notes for Table 5: 1. Radiant flux typical value is for all four LED dice operating concurrently at rated current. 2. This product emits non visible infrared light, which can be hazardous depending on total system configuration (including, but not limited to optics, drive current and temperature). Observe safety precaution given in IEC 62471 when operating this product. 3. Viewing Angle is the off axis angle from emitter centerline where the radiant power is ½ of the peak value. 4. Total Included Angle is the total angle that includes 90% of the total radiant flux. Electrical Characteristics @ TC = 25°C Table 6: Parameter Symbol Typical Unit Forward Voltage (@ IF = 700mA) [1] VF 7.2 V Forward Voltage (@ IF = 1000mA) [1] VF 8.0 V Temperature Coefficient of Forward Voltage ΔVF/ΔTJ -8.0 mV/°C Thermal Resistance (Junction to Case) RΘJ-C 2.8 °C/W Notes for Table 6: 1. Forward Voltage typical value is for all four LED dice connected in series. COPYRIGHT © 2013 LED ENGIN. ALL RIGHTS RESERVED 4 LZ4-00R508 (1.0 – 08/23/13) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com IPC/JEDEC Moisture Sensitivity Level Table 7 - IPC/JEDEC J-STD-20 MSL Classification: Soak Requirements Floor Life Standard Accelerated Level Time Conditions Time (hrs) Conditions Time (hrs) Conditions 1 1 Year ≤ 30°C/ 85% RH 168 +5/-0 85°C/ 85% RH n/a n/a Notes for Table 7: 1. The standard soak time is the sum of the default value of 24 hours for the semiconductor manufacturer’s exposure time (MET) between bake a nd bag and the floor life of maximum time allowed out of the bag at the end user of distributor’s facility. COPYRIGHT © 2013 LED ENGIN. ALL RIGHTS RESERVED 5 LZ4-00R508 (1.0 – 08/23/13) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com Mechanical Dimensions (mm) Pin Out Pad Die 1 A Anode 2 A Cathode 3 B Anode 4 B Cathode 5 C Anode 6 C Cathode 7 D Anode 8 D Cathode 9 [2] n/a Thermal 1 2 Function 3 8 4 Figure 1: Package outline drawing. 7 6 5 Notes for Figure 1: 1. Unless otherwise noted, the tolerance = ± 0.20 mm. 2. Thermal contact, Pad 9, is electrically neutral. Recommended Solder Pad Layout (mm) Figure 2a: Recommended solder pad layout for anode, cathode, and thermal pad. Note for Figure 2a: 1. Unless otherwise noted, the tolerance = ± 0.20 mm. 2. This pad layout is “patent pending”. COPYRIGHT © 2013 LED ENGIN. ALL RIGHTS RESERVED 6 LZ4-00R508 (1.0 – 08/23/13) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com Recommended Solder Mask Layout (mm) Figure 2b: Recommended solder mask opening for anode, cathode, and thermal pad Note for Figure 2b: 1. Unless otherwise noted, the tolerance = ± 0.20 mm. Recommended 8 mil Stencil Apertures Layout (mm) Figure 2c: Recommended 8mil stencil apertures layout for anode, cathode, and thermal pad Note for Figure 2c: 1. Unless otherwise noted, the tolerance = ± 0.20 mm. COPYRIGHT © 2013 LED ENGIN. ALL RIGHTS RESERVED 7 LZ4-00R508 (1.0 – 08/23/13) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com Reflow Soldering Profile Figure 3: Reflow soldering profile for lead free soldering. Typical Radiation Pattern 100 90 Relative Intensity (%) 80 70 60 50 40 30 20 10 0 -90 -80 -70 -60 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 Angular Displacement (Degrees) Figure 4: Typical representative spatial radiation pattern. COPYRIGHT © 2013 LED ENGIN. ALL RIGHTS RESERVED 8 LZ4-00R508 (1.0 – 08/23/13) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com Typical Relative Spectral Power Distribution 1.00 0.90 Relative Spectral Power 0.80 0.70 0.60 0.50 0.40 0.30 0.20 0.10 0.00 650 700 750 800 850 900 950 1000 1050 Wavelength (nm) Figure 5: Relative spectral power vs. wavelength @ TC = 25°C. Typical Peak Wavelength Shift over Current 3.00 Peak Wavelength Shift (nm) 2.00 1.00 0.00 -1.00 -2.00 -3.00 0 200 400 600 800 1000 1200 IF - Forward Current (mA) Figure 6: Typical peak wavelength shift vs. forward current @ Tc = 25°C COPYRIGHT © 2013 LED ENGIN. ALL RIGHTS RESERVED 9 LZ4-00R508 (1.0 – 08/23/13) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com Typical Peak Wavelength Shift over Temperature 40.00 Peak Wavelength Shift (nm) 30.00 20.00 10.00 0.00 -10.00 -20.00 0 10 20 30 40 50 60 70 80 90 100 Case Temperature (°C) Figure 7: Typical peak wavelength shift vs. case temperature Typical Normalized Radiant Flux over Current 160% Normalized Radiant Flux 140% 120% 100% 80% 60% 40% 20% 0% 0 200 400 600 800 1000 1200 IF - Forward Current (mA) Figure 8: Typical normalized radiant flux vs. forward current @ TC = 25°C COPYRIGHT © 2013 LED ENGIN. ALL RIGHTS RESERVED 10 LZ4-00R508 (1.0 – 08/23/13) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com Typical Normalized Radiant Flux over Temperature 140% Normalized Radiant Flux 120% 100% 80% 60% 40% 20% 0% 0 10 20 30 40 50 60 70 80 90 100 Case Temperature (°C) Figure 9: Typical normalized radiant flux vs. case temperature. Typical Forward Current Characteristics 1200 IF - Forward Current (mA) 1000 800 600 400 200 0 4.0 4.4 4.8 5.2 5.6 6.0 6.4 6.8 7.2 7.6 8.0 8.4 8.8 VF - Forward Voltage (V) Figure 10: Typical forward current vs. forward voltage @ TC = 25°C COPYRIGHT © 2013 LED ENGIN. ALL RIGHTS RESERVED 11 LZ4-00R508 (1.0 – 08/23/13) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com Current De-rating IF - Maximum Current (mA) 1200 1000 800 700 (Rated) 600 RΘJ-A = 4.0°C/W RΘJ-A = 5.0°C/W RΘJ-A = 6.0°C/W 400 200 0 0 25 50 75 100 125 Maximum Ambient Temperature (°C) Figure 11: Maximum forward current vs. ambient temperature based on TJ(MAX) = 125°C. Notes for Figure 11: 1. Maximum current assumes that all four LED dice are operating concurrently at the same current. 2. RΘJ-C [Junction to Case Thermal Resistance] for the LZ4-00R508 is typically 2.8°C/W. 3. RΘJ-A [Junction to Ambient Thermal Resistance] = RΘJ-C + RΘC-A [Case to Ambient Thermal Resistance]. COPYRIGHT © 2013 LED ENGIN. ALL RIGHTS RESERVED 12 LZ4-00R508 (1.0 – 08/23/13) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com Emitter Tape and Reel Specifications (mm) Figure 12: Emitter carrier tape specifications (mm). Figure 13: Emitter Reel specifications (mm). Notes for Figure 13: 1. Reel quantity minimum: 100 emitters. Reel quantity maximum: 1200 emitters. COPYRIGHT © 2013 LED ENGIN. ALL RIGHTS RESERVED 13 LZ4-00R508 (1.0 – 08/23/13) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com LZ4 MCPCB Family Part number Type of MCPCB Diameter (mm) LZ4-4xxxxx 1-channel 19.9 Emitter + MCPCB Typical Vf Typical If Thermal Resistance (V) (mA) (oC/W) 2.8 + 1.1 = 3.9 7.2 700  Mechanical Mounting of MCPCB o Mechanical stress on the emitter that could be caused by bending the MCPCB should be avoided. The stress can cause the substrate to crack and as a result might lead to cracks in the dies. o Therefore special attention needs to be paid to the flatness of the heat sink surface and the torque on the screws. Maximum torque should not exceed 1 Nm (8.9 lbf/in). o Care must be taken when securing the board to the heatsink to eliminate bending of the MCPCB. This can be done by tightening the three M3 screws (or #4-40) in steps and not all at once. This is analogous to tightening a wheel of an automobile o It is recommended to always use plastic washers in combination with three screws. Two screws could more easily lead to bending of the board. o If non taped holes are used with self-tapping screws it is advised to back out the screws slightly after tighten (with controlled torque) and retighten the screws again.  Thermal interface material o To properly transfer the heat from the LED to the heatsink a thermally conductive material is required when mounting the MCPCB to the heatsink o There are several materials which can be used as thermal interface material, such as thermal paste, thermal pads, phase change materials and thermal epoxies. Each has pro’s and con’s depending on the application. For our emitter it is critical to verify that the thermal resistance is sufficient for the selected emitter and its environment. o To properly transfer the heat from the MCPCB to the heatsink also special attention should be paid to the flatness of the heatsink.  Wire soldering o For easy soldering of wires to the MCPCB it is advised to preheat the MCPCB on a hot plate to a maximum of 150°. Subsequently apply the solder and additional heat from the solder iron to initiate a good solder reflow. It is recommended to use a solder iron of more than 60W. We advise to use lead free, no-clean solder. For example SN-96.5 AG-3.0 CU 0.5 #58/275 from Kester (pn: 24-7068-7601) COPYRIGHT © 2013 LED ENGIN. ALL RIGHTS RESERVED 14 LZ4-00R508 (1.0 – 08/23/13) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com LZ4-4xxxxx 1 channel, Standard Star MCPCB (1x4) Dimensions (mm) Notes:  Unless otherwise noted, the tolerance = ± 0.2 mm.  Slots in MCPCB are for M3 or #4-40 mounting screws.  LED Engin recommends plastic washers to electrically insulate screws from solder pads and electrical traces.  Electrical connection pads on MCPCB are labeled “+” for Anode and “-” for Cathode  LED Engin recommends thermal interface material when attaching the MCPCB to a heatsink  The thermal resistance of the MCPCB is: RΘC-B 1.1°C/W Components used MCPCB: ESD chips: HT04503 BZX585-C30 (Bergquist) (NXP, for 4 LED dies in series) Pad layout Ch. 1 MCPCB Pad 1,2,3 4,5 String/die Function 1/ABCD Cathode Anode + COPYRIGHT © 2013 LED ENGIN. ALL RIGHTS RESERVED 15 LZ4-00R508 (1.0 – 08/23/13) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com Company Information LED Engin, Inc., based in California’s Silicon Valley, specializes in ultra-bright, ultra compact solid state lighting solutions allowing lighting designers & engineers the freedom to create uncompromised yet energy efficient lighting experiences. The LuxiGen™ Platform — an emitter and lens combination or integrated module solution, delivers superior flexibility in light output, ranging from 3W to 90W, a wide spectrum of available colors, including whites, multi-color and UV, and the ability to deliver upwards of 5,000 high quality lumens to a target. The small size combined with powerful output allows for a previously unobtainable freedom of design wherever high-flux density, directional light is required. LED Engin’s packaging technologies lead the industry with products that feature lowest thermal resistance, highest flux density and consummate reliability, enabling compact and efficient solid state lighting solutions. LED Engin is committed to providing products that conserve natural resources and reduce greenhouse emissions. LED Engin reserves the right to make changes to improve performance without notice. Please contact sales@ledengin.com or (408) 922-7200 for more information. COPYRIGHT © 2013 LED ENGIN. ALL RIGHTS RESERVED 16 LZ4-00R508 (1.0 – 08/23/13) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com
LZ4-00R508-0000 价格&库存
很抱歉,暂时无法提供与“LZ4-00R508-0000”相匹配的价格&库存,您可以联系我们找货
