CBM-120-UV-C31-FB365-21
    LUMINUS(朗明纳斯)
    Module
CBM-120-UV-C31-FB365-21 数据手册
CBM-120-UV Product Datasheet CBT-120 Product Datasheet Preliminary CBM-120 Mosaic Array Series Ultraviolet Chip On Board LEDs Table of Contents Technology Overview. . . . . . 2 Ordering Information . . . . . . 3 Binning Structure. . . . . . . . . . 4 Ordering Bin Kits. . . . . . . . . . . 5 Optical & Electrical Characteristics. . . . . . . . . . . . . 6 Typical Spectrum . . . . . . . . . . 8 Features: •• Mosaic Array UV LED chipset with surface emitting area of 12 mm2, 4:3 aspect ratio •• All the benefits of chip on board processing without the need for complicated assembly process •• Vertical chip UV LED technology for high power density and uniform emission •• Wide Range of UVA Wavelengths •• High thermal conductivity copper coreboard package •• Low-profile window for efficient coupling into small-etendue systems •• Can be operated at variable drive currents up to 18A •• NIST traceable optical and electrical measurement testing •• Environmentally friendly: RoHS and Halogen compliant Thermal Resistance . . . . . . . . 9 Mechanical Dimensions Slim Package (C14). . . . . . . . . . . . . 10 Mechanical Dimensions Square Package (C31). . . . . . . . . . . . . 11 Shipping Tray Slim Package (C14) . . . . . . . . . . . . . . . . . . . . . 12 Applications •• Curing: Shipping Tray Square Package (C31) . . . . . . . . . . . . . . . . . . . . . 13 ›› Inks Packaging Specifications. . 14 ›› Adhesives Revision History. . . . . . . . . . . 15 •• Specialty Projection Systems for Maskless Lithography: ›› Optically matched to TI 0.95”DMD ›› Coatings •• Rapid Prototyping and 3D printing •• Medical and Scientific Instrumentation •• Inspection •• Machine Vision •• Fiber-coupled illumination 1 PDS-002545 Rev B © 2015 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 175 New Boston Street • Woburn, MA 01801 CBM-120-UV Product Datasheet Preliminary Technology Overview Luminus LEDs benefit from innovations in device technology, chip packaging and thermal management. This suite of technologies give engineers and system designers the freedom to develop solutions both high in power and efficiency. Luminus Mosaic Array LED Technology Reliability Luminus’ Devices vertical chip LED technology enables LED chips with uniform brightness over the entire LED chip surface. The optical power and brightness produced by these densely packed arrays of devices enable solutions not possible with single chip packages that be used to replace arc and halogen lamps. With designs based on years of chip and packaging development experience, Luminus LEDs are one of the most reliable light sources in the world today. Luminus LEDs pass a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity, and have been fully qualified for use in extreme high power and high current applications. With very low failure rates and median lifetimes that typically exceed 30,000 hours, Luminus UV LEDs are ready for even the most demanding applications. Packaging Technology Thermal management is critical in high power LED applications. With a thermal resistance from junction to heat sink of 0.6 ºC/W, Luminus CBM-120 LEDs have the lowest thermal resistance of any UV LED on the market. This will allow the LEDs to be driven at higher current densities while maintaining a low junction temperature, thereby resulting in brighter solutions and longer lifetimes. Environmental Benefits Luminus LEDs help reduce power consumption and the amount of hazardous waste entering the environment. All LED products manufactured by Luminus are RoHS and Halogen compliant and free of hazardous materials, including lead and mercury. Understanding Mosaic Array UV LED Test Specifications Every Luminus LED is fully tested to ensure that it meets the high quality standards expected from Luminus’ products. Testing Temperature Multiple Operating Points Luminus core board products are typically measured in such a way that the characteristics reported agree with how the devices will actually perform when incorporated into a system. This measurement is accomplished by mounting the devices on a 40ºC heat sink and measuring the device while fully powered. The tables on the following pages provide typical optical and electrical characteristics for the standard drive conditions. Since the LEDs can be operated over a wide range of drive conditions(currents from 200 mA to 18 A, and duty cycle from 240 Hz, duty cycle =10%, t=1ms) Maximum Junction Temperature8 407 Values Absolute Minimum Current (CW or Pulsed)6 Absolute Maximum Current (CW) 7 403 Note 1: Data verified using NIST traceable calibration standard. Note 2: All data are based on test conditions with a constant heat sink temperature Ths = 40°C under pulse testing conditions. Pulse conditions: 25% duty-cycle, frequency of 720Hz , 3 second soak. Note 3: Unless otherwise noted, values listed are typical. Devices are production tested and specified at 9 A. Note 4: Listed drive conditions are typical for common applications. CBM120-UV devices can be driven at currents ranging from 200 mA to 120 A and at duty cycles ranging from 1% to 100%. Drive current and duty cycle should be adjusted as necessary to maintain the junction temperature desired to meet application lifetime requirements. Note 5: Typical total flux from emitting area at listed peak wavelength. Reported performance is included to show trends for a selected power level. For specific minimum and maximum values, use bin tables. For product roadmap and future performance of devices, contact Luminus. Note 6: Special design considerations must be observed for operation under 1 A. Please contact Luminus for further information. Note 7: CBM-120-UV LEDs are designed for operation to an absolute maximum current as specified above. Product lifetime data is specified at recommended forward drive currents. Sustained operation at or beyond absolute maximum currents will result in a reduction of device life time compared to recommended forward drive currents. Actual device lifetimes will also depend on junction temperature. Refer to the lifetime derating curves for further information. In pulsed operation, rise time from 10-90% of forward current should be longer than 0.5 μseconds. Note 8: Lifetime dependent on LED junction temperature. Input power and thermal system must be properly managed to ensure lifetime. 6 PDS-002545 Rev 0B © 2015 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 175 New Boston Street • Woburn, MA 01801 CBM-120-UV Product Datasheet CBT-120 Product Datasheet Preliminary Optical & Electrical Characteristics Relative Power vs Forward Current, Tj = 60°C Relative Power vs Junc. Temperature, If = 9 A Peak Wavelength vs Forward Current Peak Wavelength vs Junction Temperature Forward Voltage vs Forward Current Forward Voltage vs Junction Temperature 7 PDS-002545 Rev B © 2015 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 175 New Boston Street • Woburn, MA 01801 CBM-120-UV Product Datasheet CBT-120 Product Datasheet Preliminary Typical Spectrum9 Note 9: Typical spectrum at current of 9 A in continuous operation. 8 PDS-002545 Rev B © 2015 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 175 New Boston Street • Woburn, MA 01801 CBM-120-UV Product Datasheet Preliminary Thermal Resistance CBM-120-UV Typical Thermal Resistance1 - C31 Tj = Die Junction Temp Tb = Coreboard Temp Ths = Heatsink Temp (3mm from surface) Tref - Thermistor Temp Rθj-b2 0.61 °C/W Rθb-hs3 0.12 °C/W Rθj-hs3 0.73 °C/W Rθj-ref2 0.64 °C/W Typical Thermal Resistance1 - C14 Rθj-b2 0.76 °C/W Rθb-hs3 0.12 °C/W Rθj-hs3 0.88 °C/W Note 1: Real thermal resistance data - “Electrical” thermal resistance values available upon request Tj = Die Junction Temp Tb = Coreboard Temp Ths = Heatsink Temp (3mm from surface) Note 2: Thermal resistance values are based on measured wavelength shift data. Note 3: Thermal Resistance is based on eGraf 1205 Thermal interface. Electrical Pinout - C31 Package Temperature (° C) 125 1 100 75 50 25 0 2 0 5 10 15 20 Resistance (K ohm) The thermistor used in CBT-120 devices mounted on coreboards is from Murata Manufacturing Co. The global part number is NCP18XH103J03RB. Please see http://www.murata.com/ for details on calculating thermistor temperature. For more information on use of the thermistor, please contact Luminus directly. 9 PDS-002545 Rev B © 2015 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 175 New Boston Street • Woburn, MA 01801 CBM-120-UV Product Datasheet CBT-120 Product Datasheet Preliminary Mechanical Dimensions – CBM-120-UV-C14 Mosaic Array LED Emitter ',0(16,216,10,//,0(7(56 “ ;“ ; $ %  727$/',( (0,77,1*$5($ & & “  “ ;     '(7$,/&  727$/',( (0,77,1*$5($ “ ',0(16,21 1$0( '(6&5,37,21 120,1$/ ',0(16,21 $ 7232)0(7$/68%675$7(727232):,1'2:   % 7232)',((0,77,1*$5($727232):,1'2:   & 7232)0(7$/68%675$7(727232)',((0,77,1*$5($   ':* Recommended connector for Anode and Cathode: Panduit Disco Lok™ Series P/N: DNG14-250FL-C. 10 PDS-002545 Rev B © 2015 Luminus Devices, Inc. - All Rights Reserved 72/(5$1&( Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 175 New Boston Street • Woburn, MA 01801 CBM-120-UV Product Datasheet CBT-120 Product Datasheet Preliminary Mechanical Dimensions – CBM-120-UV-C31 Mosaic Array LED Emitter ',0(16,216,10,//,0(7(56 “   727$/',( (0,77,1*$5($ ( “ “ ; & $  %  &  727$/',( (0,77,1*$5($ “  ;     '(7$,/&  ( ; 6(&7,21((  ',0(16,21 1$0( '(6&5,37,21 120,1$/ ',0(16,21 $ 7232)0(7$/68%675$7(727232):,1'2:   % 7232)',((0,77,1*$5($727232):,1'2:   & 7232)0(7$/68%675$7(727232)',((0,77,1*$5($   ':* Recommended connector for Anode and Cathode: Panduit Disco Lok™ Series P/N: DNG14-250FL-C. Thermistor Connector: MOLEX P/N 53780-0270 or GCT P/N WTB08-021S-F. Recommended Female: MOLEX P/N 51146-0200, GCT P/N WTB06-021S-F or equivalent 11 PDS-002545 Rev B © 2015 Luminus Devices, Inc. - All Rights Reserved 72/(5$1&( Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 175 New Boston Street • Woburn, MA 01801 CBM-120-UV Product Datasheet Preliminary Shipping Tray Outline - CBM-120-C14 ' & ;       ;  ;  ;5  ' % ; ; &    ' '   ;  ; ;  ;  ;                     '          ' ;  ; ;  ; ;                     '       ;       ;  & ;  ;5  7(&+12/2 %,//(5,&$   '(6&5,37,21 $ 75$0,//,0(7(56@ ;   '5$)7(5 180%(5 (1*,1((5 6.('',(        ;  7(&+12/2*0,//,0(7(56@ '5$)7(5 180%(5 (1*,1((5  12 PDS-002545 Rev B © 2015 Luminus Devices, Inc. - All Rights Reserved     6+((7 6&$/( 2) 121( 5(9 $ 72 6.('',(  $ 75$
物料型号:CBM-120-UV
器件简介: - 该产品是LUMINUS公司生产的CBM-120 Mosaic Array Series紫外光芯片级封装LED。 - 具有12平方毫米的表面发射区域,4:3的长宽比。 - 采用垂直芯片UV LED技术,具有高功率密度和均匀发射。 - 提供广泛的UVA波长范围。 - 采用高导热铜基板封装。 - 低剖面窗口,可有效耦合到小扩展角系统中。 - 可变驱动电流可高达18A。 - 提供NIST可追溯的光学和电学测量测试。 - 环保:符合RoHS和卤素标准。
引脚分配:文档中没有提供具体的引脚分配图,但提到了LED芯片、热敏电阻、连接器和铜基板。
参数特性: - 工作温度范围:-40℃至+100℃。 - 发光面积:12.9平方毫米。 - 发光面积尺寸:4.50mm x 3.32mm。 - 正向电压:最小3.0V,典型值3.6V至4.0V。 - 辐射通量:典型值从6.8W至10.5W不等,取决于波长范围。 - 色温范围:365nm至410nm,分为不同的功率和波长bin。
功能详解: - 该LED适用于固化(油墨、涂料、粘合剂)、检测、机器视觉、光纤照明、特种投影系统(例如与TI 0.95”DMD光学匹配的无掩模光刻)、快速成型和3D打印、医疗和科学仪器等领域。
应用信息: - 适用于固化、检测、机器视觉、光纤照明、无掩模光刻的特种投影系统、快速成型、3D打印、医疗和科学仪器等应用。
封装信息: - 提供两种封装配置:C14(Slim Package)和C31(Square Package)。 - 机械尺寸和发货托盘的详细信息在文档中有详细描述。
CBM-120-UV-C31-FB365-21 价格&库存
很抱歉,暂时无法提供与“CBM-120-UV-C31-FB365-21”相匹配的价格&库存,您可以联系我们找货
    • 1+6941.79720
    • 200+2769.82200
    • 500+2677.26600
    • 1000+2631.53880
