PHOTONIC
DETECTORS INC.
High-Power & Current GaAIAs Infrared Emitters
Peak Wavelength, 880 nm,Type PDI-E812
PACKAGE DIMENSIONS inch (mm)
.038 [0.97]
GLASS LENS CAP
(WELDED)
CL
HEADER
.041 [1.04]
2X Ø.017 [0.43]
45°
C
L
CL
.100 [2.54]
CATHODE
CL
ANODE & CASE
.088 [2.24]
.017 [0.43]
Ø.185 [Ø4.70]
Ø.210 [Ø5.33]
880 nm LED CHIP
2X 1.06 [27.0]
.230 [5.84]
.019 [0.48] SQUARE
TO-46 HERMETIC CAN PACKAGE
40O HALF INTENSITYBEAM ANGLE
CATHODE
Pd
IFP
IFP
VR
To & Ts
TS
Power Dissipation
Continuous Forward Current
360
180
3.0
3.0
+125
+260
Peak Forward Current (100µs pulse,10pps)
Reverse voltage
Storage & Operating Temperature
Soldering Temperature*
-65
mW
mA
A
V
o
C
o
C
*1/16 inch from case for 3 secs max
RELATIVE POWER OUTPUT (%)
DESCRIPTION: The PDI-E812 infrared emitting APPLICATIONS
FEATURES
diode uses dual cathode, high current liquid
Dual cathode
Photoelectric switches
phase epitaxially grown GaAlAs. Optimized for
High current
Reflective switches
high power, high current at 880 nm. Packaged in
Medium emission angle
Smoke detectors
a TO-46 header with a glass lens cap.
ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted)
TYPICAL RADIATION PATTERN
100
SYMBOL
PARAMETER
MIN
MAX
UNITS
80
60
40
-80 -60 -40 -20 0 20 40 60 80
BEAM ANGLE, θ (deg)
ELECTRO-OPTICAL CHARACTERISTICS (TA=25 C unless otherwise noted)
SYMBOL CHARACTERISTIC
TEST CONDITIONS
MIN
TYP
O
λP
D
Dλ
Rd
tr
tf
Output Power
Forward Voltage
Reverse Current
Peak Wavelength
Spectral Halfwidth
Dynamic Resistance
Rise Time
Fall Time
IF = 100 mA
IF = 100 mA
V R = -3.0 V
IF = 50 mA
IF = 50 mA
IF = 100 mA
IF = 100 mA
IF = 100 mA
865
MAX
15
1.5
1.9
10
895
880
80
1.2
0.6
0.5
TYPICAL POWER OUTPUT
DEGRADATION CURVE
V F IN VOLTS
POWER OUTPUT vs
FORWARD CURRENT
7.0
UNITS
mW
V
mA
nm
nm
Ohm
µS
mS
SPECTRAL OUTPUT
V F IN VOLTS
PO
VF
IR
TEMPERATURE, ºC
IF IN AMPS
IF IN AMPS
Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications
are subject to change without notice. Optical power and radiant intensity measured using uncapped dimpled TO-46 into integrating sphere.
很抱歉,暂时无法提供与“PDI-E812”相匹配的价格&库存,您可以联系我们找货
