PDI-E814
PDI-E814
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-46-2,金属罐
    EMITTER IR 880NM 180MA TO-46
PDI-E814 数据手册
PHOTONIC DETECTORS INC. High-Power & Current GaAIAs Infrared Emitters Peak Wavelength, 880 nm,Type PDI-E814 PACKAGE DIMENSIONS inch (mm) .038 [0.97] .100 [2.54] MAX HEADER CL .041 [1.04] 2X Ø.017 [0.43] 45° C L C L .168 [4.27] .100 [2.54] CATHODE CL ANODE & CASE CLEAR OPTICAL EPOXY Ø.185 [Ø4.70] Ø.210 [Ø5.33] 880 nm LED CHIP 2X 1.06 [27.0] .019 [0.48] SQUARE TO-46 HERMETIC CAN PACKAGE 80O HALF INTENSITYBEAM ANGLE CATHODE Pd IFP IFP VR To & Ts TS Power Dissipation Continuous Forward Current Peak Forward Current (100µs pulse,10pps) Reverse voltage Storage & Operating Temperature Soldering Temperature* -65 360 180 3.0 3.0 +125 +260 mW mA A V o C o C *1/16 inch from case for 3 secs max RELATIVE POWER OUTPUT (%) DESCRIPTION: The PDI-E814 infrared emitting APPLICATIONS FEATURES diode uses dual cathode, high current liquid Dual cathode Photoelectric switches phase epitaxially grown GaAlAs. Optimized for High current Optical encoders high power, high current at 880 nm. Packaged in a Wide angle Infrared sources TO-46 header with a clear epoxy glob top. ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) TYPICAL RADIATION PATTERN SYMBOL PARAMETER MIN MAX UNITS BEAM ANGLE, θ (deg) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP λP D Dλ Rd tr tf Output Power Forward Voltage Reverse Current Peak Wavelength Spectral Halfwidth Dynamic Resistance Rise Time Fall Time IF = 100 mA IF = 100 mA V R = -3.0 V IF = 50 mA IF = 50 mA IF = 100 mA IF = 100 mA IF = 100 mA 865 MAX 15 1.5 1.9 10 895 880 80 1.2 0.6 0.5 TYPICAL POWER OUTPUT DEGRADATION CURVE V F IN VOLTS RELATIVE POWER OUTPUT POWER OUTPUT vs FORWARD CURRENT 7.0 UNITS mW V mA nm nm Ohm µS mS SPECTRAL OUTPUT V F IN VOLTS PO VF IR TEMPERATURE, ºC IF IN AMPS IF IN AMPS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. Optical power and radiant intensity measured using uncapped dimpled TO-46 into integrating sphere.
PDI-E814 价格&库存
很抱歉,暂时无法提供与“PDI-E814”相匹配的价格&库存,您可以联系我们找货
