PHOTONIC
DETECTORS INC.
High-Power & Current GaAIAs Infrared Emitters
Peak Wavelength 880 nm,Type PDI-E811
PACKAGE DIMENSIONS inch (mm)
.045 [1.1]
.030 [0.8]
WINDOW CAP
(WELDED)
.047 [1.2]
.035 [0.9]
CL
INDUSTRY EQUIVALENTS
TEMT88F (A-D)
.170 [4.3]
.132 [3.4]
.015 [0.38] MAX
HEADER
2X Ø.019 [0.5]
45°
CL
CL
Ø .188 [4.8]
Ø .178 [4.5]
.100 [2.54]
CATHODE
CL
ANODE & CASE
.028 [0.7] MAX
2X 1.000 [25.4]
Ø.215 [5.5]
Ø .207 [5.3]
880 nm LED CHIP
.019 [0.48] SQ
TO-46 HERMETIC CAN PACKAGE
80O HALF INTENSITY BEAM ANGLE
CATHODE
Medium- high emission
DESCRIPTION: The PDI-E811 infrared emitting
diode uses dual cathode,high current reliability liquid
phase epitaxially grown GaAlAs. Optimized for high
power, high current at 880 nm. Packaged in a TO-46
angle
can with a flat glass window cap.
ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted)
SYMBOL
PARAMETER
MIN
MAX
UNITS
Pd
IFP
IFP
VR
To & Ts
TS
Power Dissipation
Continuous Forward Current
Peak Forward Current (100µs pulse,10pps)
Reverse voltage
Storage & Operating Temperature
Soldering Temperature*
-65
360
180
3.0
3.0
+125
+260
mW
mA
A
V
o
C
o
C
*1/16 inch from case for 3 secs max
APPLICATIONS
Photoelectric switches
Reflective switches
Smoke detectors
TYPICAL RADIATION PATTERN
RELATIVE POWER OUTPUT (%)
FEATURES
Dual cathode
High current
BEAM ANGLE, θ (deg)
ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted)
SYMBOL CHARACTERISTIC
TEST CONDITIONS
MIN
TYP
λP
D
Dλ
Rd
tr
tf
Output Power
Forward Voltage
Reverse Current
Peak Wavelength
Spectral Halfwidth
Dynamic Resistance
Rise Time
Fall Time
IF = 100 mA
IF = 100 mA
VR = -3.0 V
IF = 50 mA
IF = 50 mA
IF = 100 mA
IF = 100 mA
IF = 100 mA
865
MAX
15
1.5
1.9
10
895
880
80
1.2
0.6
0.5
TYPICAL POWER OUTPUT
DEGRADATION CURVE
VF IN VOLTS
RELATIVEPOWER OUTPUT
POWER OUTPUT vs
FORWARD CURRENT
7.0
UNITS
mW
V
mA
nm
nm
Ohm
µS
mS
SPECTRAL OUTPUT
VF IN VOLTS
PO
VF
IR
I F IN AMPS
I F IN AMPS
TEMPERATURE, ºC
Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications
are subject to change without notice. Optical power and radiant intensity measured using uncapped dimpled TO-46 into integrating sphere. [FORM NO. 100-PDI-E811 REV D]
很抱歉,暂时无法提供与“PDI-E811”相匹配的价格&库存,您可以联系我们找货
