PDI-E807
PDI-E807
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-46-2透镜顶部金属罐
    EMITTER IR 880NM 100MA TO-46
PDI-E807 数据手册
PHOTONIC DETECTORS INC. High-Power GaAIAs Infrared Emitters Peak Wavelength, 880 nm,Type PDI-E807 PACKAGE DIMENSIONS inch (mm) CL 0.175 [4.45] 45° 0.040 [1.02] 0.145 [3.68] INDUSTRY EQUIVALENT OD-880L 1.00 [25.4] MIN CL 0.146 [3.71] 0.029 [0.74] Ø0.019 [0.48] Ø0.016 [0.41] CL Ø0.195 [4.95] Ø0.178 [4.52] 0.100 [2.54] CATHODE CL ANODE & CASE L.E.D. Ø0.212 [5.38] Ø0.209 [5.31] LENS CAP (WELDED) 0.013 [0.33] SQ 0.025 [0.64] 0.022 [0.56] HEADER Ø0.005 [Ø0.13] CATHODE BOTTOM SIDE ANODE TO-46 HERMETIC CAN PACKAGE 35O HALF INTENSITYBEAM ANGLE Pd IFP IFP VR To & Ts TS Power Dissipation Continuous Forward Current Peak Forward Current (10µs, 10Hz) Reverse voltage Storage & Operating Temperature Soldering Temperature* -55 160 100 3.0 5 +100 +240 mW mA A V o C o C *1/16 inch from case for 3 secs max APPLICATIONS Photoelectric switches Infrared sources Automatic controls TYPICAL RADIATION PATTERN RELATIVE POWER OUTPUT (%) DESCRIPTION: The PDI-E807 infrared emitting FEATURES diode uses high reliability liquid phase epitaxially High output power grown GaAlAS. Optimized for high power, high High reliablity efficiency. This 880 nm I.R. emitter is packaged in Medium emission angle a TO-46 can with a glass lens cap. ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS BEAM ANGLE, θ (deg) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP Ct tr tf POWER OUTPUT, PO (mW) POWER OUTPUT vs FORWARD CURRENT FORWARD CURRENT, IF (mA) IF = 100 mA IF = 100 mA IF = 100 µA IF = 50 mA IF = 50 mA VR = 0 V,f = 1 MHz IF = 100 mA IF = 50 mA TYPICAL POWER OUTPUT DEGRADATION CURVE STRESS TIME (hrs) 18 5 883 MAX 24 1.6 30 880 70 20 1.5 0.8 2.0 886 RELATIVE POWER OUTPUT (&) λP Dλ Output Power Forward Voltage Reverse Breakdown Voltage Peak Wavelength Spectral Halfwidth Terminal Capacitance Rise Time Fall Time RELATIVE POWER OUTPUT (%) PO VF VR UNITS mW/Sr V V nm nm pF µS mS SPECTRAL OUTPUT WAVELENGTH, λ (nm) Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. Optical power and radiant intensity measured using uncapped dimpled TO-46 into integrating sphere. [FORM NO. 100-PDI-E807 REV A]
PDI-E807 价格&库存
很抱歉,暂时无法提供与“PDI-E807”相匹配的价格&库存,您可以联系我们找货
