PDI-E808
PDI-E808
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    T-1
    EMITTER IR 880NM 100MA T-1
PDI-E808 数据手册
PHOTONIC DETECTORS INC. High-Power GaAIAs Infrared Emitters Peak Wavelength, 880 nm,Type PDI-E808 PACKAGE DIMENSIONS inch (mm) BLUE CLEAR PLASTIC Ø0.118 [3.00] INDUSTRY EQUIVALENTS SFH487 & SEP8705 0.177 [4.50] 0.126 [3.20] 0.98 [25.0] 0.020 [0.51] SQ C L 0.100 [2.54] C L BEAM 80° ANGLE CATHODE ANODE 0.039 [0.99] 1.04 [26.5] BLUE TINT T 1 PACKAGE 40O HALF INTENSITYBEAM ANGLE Pd IFP IFP VR To & Ts TS Power Dissipation Continuous Forward Current Peak Forward Current (10µs, 10Hz) Reverse voltage Storage & Operating Temperature Soldering Temperature* -55 200 100 2.5 5 +100 +240 mW mA A V o C o C *1/16 inch from case for 3 secs max APPLICATIONS Photoelectric switches Infrared sources Automatic controls TYPICAL RADIATION PATTERN RELATIVE POWER OUTPUT (%) DESCRIPTION: The PDI-E808 infrared emitting FEATURES diode uses high reliability liquid phase epitaxially High output power grown GaAlAS. Optimized for high power, high High reliablity efficiency. This 880 nm I.R. emitter is packaged in Medium emission angle a low cost T 1 [3 mm diameter] package. ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS BEAM ANGLE, θ (deg) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP Ct tr tf POWER OUTPUT, PO (mW) POWER OUTPUT vs FORWARD CURRENT FORWARD CURRENT, IF (mA) IF = 50 mA IF = 100 mA IF = 100 µA IF = 50 mA IF = 50 mA VR = 0 V,f = 1 MHz IF = 100 mA IF = 50 mA TYPICAL POWER OUTPUT DEGRADATION CURVE STRESS TIME (hrs) 30 5 883 MAX 50 1.6 30 880 70 20 1.5 0.8 2.0 886 RELATIVE POWER OUTPUT (&) λP Dλ Radiant Intensity Forward Voltage Reverse Breakdown Voltage Peak Wavelength Spectral Halfwidth Terminal Capacitance Rise Time Fall Time RELATIVE POWER OUTPUT (%) IE VF VR UNITS mW/Sr V V nm nm pF µS mS SPECTRAL OUTPUT WAVELENGTH, λ (nm) Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. Optical power and radiant intensity measured using uncapped dimpled TO-46 into integrating sphere. [FORM NO. 100-PDI-E808 REV A]
PDI-E808 价格&库存
很抱歉,暂时无法提供与“PDI-E808”相匹配的价格&库存,您可以联系我们找货
