PDI-E817
PDI-E817
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-46-2,金属罐
    EMITTER IR 880NM 180MA TO-46
PDI-E817 数据手册
PHOTONIC DETECTORS INC. High-Power & Current GaAIAs Infrared Emitters Peak Wavelength, 880 nm,Type PDI-E817 PACKAGE DIMENSIONS inch (mm) .045 [1.1] .030 [0.8] .174 [4.42] .015 [0.38] MAX LENS CAP (WELDED) .047 [1.2] .035 [0.9] CL HEADER Ø.019 [0.5] TYP 45° CL CL Ø.188 [4.8] Ø.180 [4.6] CATHODE .100 [2.54] CL ANODE & CASE .028 [0.7] MAX 2X 1.000 [25.4] Ø.215 [5.5] Ø.207 [5.3] 880 nm LED CHIP .146 [3.70] .019 [0.48] TO-46 CAN PACKAGE 35O HALF INTENSITY BEAM ANGLE CATHODE Pd IFP IFP VR To & Ts TS Power Dissipation Continuous Forward Current Peak Forward Current (100µµ s pulse,10 pps) Reverse voltage Storage & Operating Temperature Soldering Temperature* -65 360 180 3.0 3.0 +125 +260 mW mA A V o C o C *1/16 inch from case for 3 secs max RELATIVE POWER OUTPUT (%) DESCRIPTION: The PDI-E817 infrared emitting APPLICATIONS FEATURES diode uses dual cathode, high current liquid Dual cathode Photoelectric switches phase epitaxially grown GaAlAs. Optimized for High current Reflective switches high power, high current at 880 nm. Packaged in Medium emission angle Smoke detectors a TO-46 can with a glass lens cap. ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) TYPICAL RADIATION PATTERN SYMBOL PARAMETER MIN MAX UNITS BEAM ANGLE, θ (deg) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP λP D Dλ Rd tr tf Output Power Forward Voltage Reverse Current Peak Wavelength Spectral Halfwidth Dynamic Resistance Rise Time Fall Time IF = 100 mA IF = 100 mA V R = -3.0 V IF = 50 mA IF = 50 mA IF = 100 mA IF = 100 mA IF = 100 mA 865 MAX 15 1.5 1.9 10 895 880 80 1.2 0.6 0.5 TYPICAL POWER OUTPUT DEGRADATION CURVE V F IN VOLTS RELATIVE POWER OUTPUT POWER OUTPUT vs FORWARD CURRENT 7.0 UNITS mW V mA nm nm Ohm µS mS SPECTRAL OUTPUT V F IN VOLTS PO VF IR TEMPERATURE, ºC IF IN AMPS IF IN AMPS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. Optical power and radiant intensity measured using uncapped dimpled TO-46 into integrating sphere.
PDI-E817 价格&库存
很抱歉,暂时无法提供与“PDI-E817”相匹配的价格&库存,您可以联系我们找货
