PHOTONIC
High-Speed GaAIAs Infrared Point Source Emitter
Peak Wavelength 850 nm,Type PDI-E821
DETECTORS INC.
PACKAGE DIMENSIONS inch (mm)
CL
0.145 [3.68]
45°
0.040
[1.02]
1.00 [25.4] MIN
0.145 [3.68]
CL
0.112 [2.84]
0.098 [2.49]
Ø0.019 [0.48]
Ø0.016 [0.41]
CL
Ø0.195 [4.95]
Ø0.178 [4.52]
0.100 [2.54]
CATHODE
CL
ANODE
& CASE
L.E.D.
WINDOW CAP
(WELDED)
0.025 [0.64]
0.022 [0.56]
HEADER
0.015 [0.38] SQ
Ø0.004 [Ø0.10]
EMITTER AREA
CATHODE
BOTTOM SIDE ANODE
TO-46 HERMETIC CAN PACKAGE
80O HALF INTENSITY BEAM ANGLE
DESCRIPTION: The PDI-E821 is a GaAlAs, 850
FEATURES
nm, high speed point source emitter. The emitting
High speed
junction is .004 inch (0.10 mm) diameter. The topside
High reliablity
metal cathode forms an optical aperture mask. PackWide emission angle
aged in a TO-46 header with a flat glass window cap.
ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted)
SYMBOL
PARAMETER
MIN
MAX
UNITS
Power Dissipation
Continuous Forward Current
Peak Forward Current (10µs, 10Hz)
Reverse voltage
Storage & Operating Temperature
Soldering Temperature*
-55
200
100
2.5
2
+125
+260
mW
mA
A
V
o
C
o
C
*1/16 inch from case for 3 secs max
TYPICAL RADIATION PATTERN
BEAM ANGLE, θ (deg)
ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted)
SYMBOL CHARACTERISTIC
TEST CONDITIONS
MIN
TYP
λP
D
Dλ
RELATIVE OUTPUT vs.
FORWARD CURRENT
100
80
60
40
80
100
60
RELATIVE POWER OUTPUT (%)
Ct
tr
tf
FORWARD CURRENT (mA)
IF = 100 mA
IF = 100 mA
IF = 10 µ A
IF = 20 mA
IF = 20 mA
V R = 0 V,f = 1 MHz
IF = 20 mA
IF = 20 mA
TYPICAL POWER OUTPUT
DEGRADATION CURVE
STRESS TIME (hrs)
MAX
2.5
2.0
830
1.70
2.2
850
30
60
15
15
870
Output Power
Forward Voltage
Reverse Breakdown Voltage
Peak Wavelength
Spectral Halfwidth
Terminal Capacitance
Rise Time
Fall Time
PO
VF
VR
100
UNITS
mW
V
V
nm
nm
pF
nS
nS
SPECTRAL OUTPUT
80
60
40
810
820
830
840
850
860
870
880
890
900
Pd
IFP
IFP
VR
To & Ts
TS
APPLICATIONS
Fiber optic sources
Optical encoders
Point light sources
Ø0.212 [5.38]
Ø0.209 [5.31]
WAVELENGTH, λ (nm)
Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications
are subject to change without notice. Optical power and radiant intensity measured using uncapped dimpled TO-46 into integrating sphere.
很抱歉,暂时无法提供与“PDI-E821”相匹配的价格&库存,您可以联系我们找货
