PDI-E815
PDI-E815
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-46-2
    EMITTER IR 880NM 180MA TO-46
PDI-E815 数据手册
PHOTONIC DETECTORS INC. High-Power & Current GaAIAs Infrared Emitters Peak Wavelength, 880 nm,Type PDI-E815 PACKAGE DIMENSIONS inch (mm) .038 [0.97] PLASTIC LENS CAP C L HEADER .041 [1.04] 2X Ø.017 [0.43] 45° C L CL Ø.230 [5.85] .100 [2.54] CATHODE CL ANODE & CASE .039 [0.99] Ø.185 [Ø4.70] Ø.210 [Ø5.33] 880 nm LED CHIP 2X 1.06 [27.0] .222 [5.64] .019 [0.48] SQUARE TO-46 CAN PACKAGE 5O HALF INTENSITYBEAM ANGLE CATHODE DESCRIPTION: The PDI-E815 infrared emitting APPLICATIONS diode uses dual cathode, high current liquid Optical encoders phase epitaxially grown GaAlAs. Optimized for Infrared sources high power, high current at 880 nm. Packaged in Collimated high emission angle Optical readers a TO-46 can with a clear plastic lens cap. ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) TYPICAL RADIATION PATTERN SYMBOL PARAMETER MIN MAX UNITS Pd IFP IFP VR To & Ts TS Power Dissipation Continuous Forward Current Peak Forward Current (100µs pulse,10pps) Reverse voltage Storage & Operating Temperature Soldering Temperature* -65 360 180 3.0 3.0 +125 +260 mW mA A V o C o C *1/16 inch from case for 3 secs max RELATIVE POWER OUTPUT (%) FEATURES Dual cathode High current BEAM ANGLE, θ (deg) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP λP D Dλ Rd tr tf Output Power Forward Voltage Reverse Current Peak Wavelength Spectral Halfwidth Dynamic Resistance Rise Time Fall Time IF = 100 mA IF = 100 mA V R = -3.0 V IF = 50 mA IF = 50 mA IF = 100 mA IF = 100 mA IF = 100 mA 865 MAX 15 1.5 1.9 10 895 880 80 1.2 0.6 0.5 TYPICAL POWER OUTPUT DEGRADATION CURVE V F IN VOLTS RELATIVE POWER OUTPUT POWER OUTPUT vs FORWARD CURRENT 7.0 UNITS mW V mA nm nm Ohm µS mS SPECTRAL OUTPUT V F IN VOLTS PO VF IR TEMPERATURE, ºC IF IN AMPS IF IN AMPS Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. Optical power and radiant intensity measured using uncapped dimpled TO-46 into integrating sphere.
PDI-E815 价格&库存
很抱歉,暂时无法提供与“PDI-E815”相匹配的价格&库存,您可以联系我们找货
