PDI-E839
PDI-E839
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    金属化陶瓷
    EMITTER IR VIS MULTI-NM MET CER
PDI-E839 数据手册
PHOTONIC DETECTORS INC. Four Drive Emitter, Oximeter Component (880/660/940 nm) Type PDI-E839 Criticare, Data Scope, NovaMetrix,Ohmeda& Scimed capable PACKAGE DIMENSIONS INCH (mm) .265 [6.73] CL .161 [4.08] CL .133 [3.37] CL .105 [2.65] .075 [1.90] .055 [1.40] 880 nm L.E.D. 660 nm L.E.D. .025 [0.63] 940 nm L.E.D. .088 [2.24] CL WIRE BONDS .265 [6.73] CLEAR ENCAPSULANT A B C METALIZED CERAMIC D Metalized Ceramic Package APPLICATIONS DESCRIPTION: The PDI-E839 is a four drive line three FEATURES Low cost 660 nm +/- 3 nm 4 drive line Oximeter probes Finger clamps Reusable probes emitter oximeter component. The 880, 660 GaAlAs and 940 nm GaAs emitters are high power LPE grown. The metalized ceramic has clear epoxy encapsulation with top side solder pads. These components are ideal for O.E.M. and repair replacements of oximeter probe assemblies. ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS Pd Power Dissipation IF=20 mA 250 mW IFP Continuous Forward Current 30 mA IFP Peak Forward Current 200 mA VR Reverse Voltage 4 V To & TS TS Storage & Operating Temp -40 +80 o C 240 o C Soldering Temperature* SCHEMATIC B 880 nm LED 660 nm LED A * For 3 seconds max using a heat sink. C 940 nm LED D ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST 880 nm 660 nm 940 nm COND MIN TYP MAX MIN TYP MAX MIN TYP MAX UNITS PO Radiant Flux** IF = 20 mA 1.8 2.0 IV Luminous Intensity** IF = 20 mA VF Forward Voltage IF = 20 mA VR Reverse breakdown IF = 10 m A 5 5 lp Peak Wavelength IF = 20 mA 870 880 890 658 661 λ Spectral Bandwidth IF = 20 mA 50 Tr Rise Time IF = 20 mA Tr Fall Time IF = 20 mA 1.5 1.8 2.4 20 30 1.7 1.8 1.2 1.8 mW mcd 2.4 1.3 1.5 5 664 V V 930 904 950 nm 25 50 nm 0.8 0.8 0.8 mS 0.8 0.8 0.8 mS ** Bare chip measured packaged in a flat TO-18/ TO-46 header without resin coating. Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. [FORM NO. 100-PDI-E839 REV A]
PDI-E839 价格&库存
很抱歉,暂时无法提供与“PDI-E839”相匹配的价格&库存,您可以联系我们找货
