PDI-E905
PDI-E905
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-46-2
    EMITTER IR 940NM 100MA TO-46
PDI-E905 数据手册
PHOTONIC DETECTORS INC. High-Power GaAs Infrared Emitters Peak Wavelength 940 nm,Type PDI-E905 PACKAGE DIMENSIONS inch (mm) CL 45° 0.040 [1.02] 0.145 [3.68] 1.00 [25.4] MIN CL 0.222 [5.64] Ø0.019 [0.48] Ø0.016 [0.41] CL Ø0.230 [5.84] 0.100 [2.54] CATHODE C L ANODE AND CASE L.E.D. PLASTIC LENS CAP HEADER TO-46 HERMETIC CAN PACKAGE 5O HALF INTENSITY BEAM ANGLE DESCRIPTION: The PDI-E905 infrared emitting -65 mW mA A V o C o C *1/16 inch from case for 3 secs max BEAM ANGLE, θ (deg) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP 80 100 60 40 0 0 FORWARD CURRENT, IF (mA) 10 1.0 0.1 V F - FORWARD VOLTAGE - (V) MAX 1.2 1.30 UNITS mW V V nm nm pF µS mS 1.50 940 50 30 0.8 0.8 960 RELATIVE POWER OUTPUT (%) 20 100 2.0 40 FORWARD CURRENT vs FORWARD VOLTAGE 1.8 60 5 920 1.6 80 1 1000 1.4 100 20 RELATIVE POWER , PO (%) POWER OUTPUT vs FORWARD CURRENT 1.2 Ct tr tf 1.0 λP D Dλ IF = 20 mA IF = 100 mA IF = 10 µ A IF = 100 mA IF = 100 mA V R = 0 V,f = 1 MHz IF = 100 mA IF = 100 mA 0.8 Output Power Forward Voltage Reverse Breakdown Voltage Peak Wavelength Spectral Halfwidth Terminal Capacitance Rise Time Fall Time IF - FORWARD CURRENT (mA) PO VF VR SPECTRAL OUTPUT 100 80 60 40 20 0 980 160 100 2.5 5 +125 +260 WAVELENGTH, λ (nm) 1000 Power Dissipation Continuous Forward Current Peak Forward Current (10µs, 10Hz) Reverse voltage Storage & Operating Temperature Soldering Temperature* TYPICAL RADIATION PATTERN RELATIVE POWER OUTPUT (%) Collimated high emission angle ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS Pd IFP IFP VR To & Ts TS APPLICATIONS Photo interrupters I.R. remotes Infrared sources diode uses high reliability liquid phase epitaxially grown GaAs. Optimized for high power, high efficiency. This 940 nm emitter is packaged in a TO-46 header with a clear plastic lens cap. 960 FEATURES High output power High reliablity 940 Ø0.005 [ Ø0.13] CATHODE BOTTOM SIDE ANODE 0.043 [1.09] 0.040 [1.02] 920 0.013 [0.33] SQ 900 Ø0.255 [6.48] Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. Optical power and radiant intensity measured using uncapped dimpled TO-46 into integrating sphere.
PDI-E905 价格&库存
很抱歉,暂时无法提供与“PDI-E905”相匹配的价格&库存,您可以联系我们找货
