PDI-E824
PDI-E824
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    TO-46-2透镜顶部金属罐
    EMITTER IR 850NM 100MA TO-46
PDI-E824 数据手册
PHOTONIC High-Speed GaAIAs Infrared Point Source Emitter Peak Wavelength 850 nm,Type PDI-E824 DETECTORS INC. PACKAGE DIMENSIONS inch (mm) CL 0.145 [3.68] 45° 0.040 [1.02] 1.00 [25.4] MIN 0.100 [2.54] MAX CL Ø0.019 [0.48] Ø0.016 [0.41] CL Ø0.168 [4.27] 0.100 [2.54] CATHODE CL L.E.D. CLEAR EPOXY 0.043 [1.09] 0.040 [1.02] HEADER 0.015 [0.38] SQ Ø0.004 [0.10] EMITTER AREA CATHODE BOTTOM SIDE ANODE TO-46 HERMETIC CAN PACKAGE 80O HALF INTENSITY BEAM ANGLE DESCRIPTION: The PDI-E824 is a GaAlAs, 850 FEATURES nm, high speed point source emitter. The emitting High speed junction is .004 inch (0.10 mm) diameter. The topside High reliablity metal cathode forms an optical aperture mask. PackWide angle aged in a TO-46 header with a clear epoxy glob top. ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS Power Dissipation Continuous Forward Current Peak Forward Current (10µs, 10Hz) Reverse voltage Storage & Operating Temperature Soldering Temperature* -55 200 100 2.5 2 +125 +260 mW mA A V o C o C *1/16 inch from case for 3 secs max TYPICAL RADIATION PATTERN BEAM ANGLE, θ (deg) ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP λP D Dλ RELATIVE OUTPUT vs. FORWARD CURRENT 100 80 60 40 80 100 60 0 0 40 20 20 RELATIVE POWER OUTPUT (%) Ct tr tf FORWARD CURRENT (mA) IF = 100 mA IF = 100 mA IF = 10 µ A IF = 20 mA IF = 20 mA V R = 0 V,f = 1 MHz IF = 20 mA IF = 20 mA TYPICAL POWER OUTPUT DEGRADATION CURVE STRESS TIME (hrs) MAX 2.5 2.0 830 1.70 2.2 850 30 60 15 15 870 RELATIVE POWER OUTPUT (%) Output Power Forward Voltage Reverse Breakdown Voltage Peak Wavelength Spectral Halfwidth Terminal Capacitance Rise Time Fall Time RELATIVE POWER OUTPUT (%) PO VF VR 100 UNITS mW V V nm nm pF nS nS SPECTRAL OUTPUT 80 60 40 20 0 800 810 820 830 840 850 860 870 880 890 900 Pd IFP IFP VR To & Ts TS APPLICATIONS Fiber optic sources Optical encoders Point light sources RELATIVE POWER OUTPUT (%) Ø0.213 [5.41] Ø0.209 [5.32] ANODE AND CASE WAVELENGTH, λ (nm) Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. Optical power and radiant intensity measured using uncapped dimpled TO-46 into integrating sphere.
PDI-E824 价格&库存
很抱歉,暂时无法提供与“PDI-E824”相匹配的价格&库存,您可以联系我们找货
