PHOTONIC
DETECTORS INC.
High-Power & Current GaAs Infrared Emitters
Peak Wavelength, 940 nm,Type PDI-E913
INDUSTRY EQUIVALENTS
TEMT55P (A-D), 5525
PACKAGE DIMENSIONS inch (mm)
.257 [6.5]
.223 [5.7]
.045 [1.1]
.030 [0.8]
CL
.015 [0.38] MAX
LENS CAP
(WELDED)
.047 [1.2]
.035 [0.9]
HEADER
Ø.019 [0.5] TYP
45°
CL
Ø.188 [4.8]
CL Ø.180 [4.6]
CATHODE .100 [2.54]
CL
ANODE & CASE
.028 [0.7] MAX
Ø.215 [5.5]
Ø.207 [5.3]
940 nm LED CHIP
2X 1.000 [25.4]
.214 [5.4]
.192 [4.9]
.019 [0.48]
TO-46 HERMETIC CAN PACKAGE
10O HALF INTENSITYBEAM ANGLE
CATHODE
DESCRIPTION: The PDI-E913 infrared emitting APPLICATIONS
diode uses dual cathode, high current liquid
Photoelectric switches
phase epitaxially grown GaAs. Optimized for high
Reflective switches
power, and high current at 940 nm. Packaged in a
Medium-high emission angle
Smoke detectors
TO-46 can with a glass lens cap.
ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted)
TYPICAL RADIATION PATTERN
SYMBOL
PARAMETER
MIN
MAX
UNITS
Pd
IFP
IFP
VR
To & Ts
TS
Power Dissipation
Continuous Forward Current
Peak Forward Current (100µs pulse,10pps)
Reverse voltage
Storage & Operating Temperature
Soldering Temperature*
-65
360
180
3.0
3.0
+125
+260
mW
mA
A
V
o
C
o
C
*1/16 inch from case for 3 secs max
RELATIVE POWER OUTPUT (%)
FEATURES
Dual cathode
High current
BEAM ANGLE, θ (deg)
ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted)
SYMBOL CHARACTERISTIC
TEST CONDITIONS
MIN
TYP
λP
D
Dλ
Rd
tr
tf
Output Power
Forward Voltage
Reverse Current
Peak Wavelength
Spectral Halfwidth
Dynamic Resistance
Rise Time
Fall Time
IF = 100 mA
IF = 100 mA
V R = -3.0 V
IF = 50 mA
IF = 50 mA
IF = 100 mA
IF = 100 mA
IF = 100 mA
925
MAX
5.0
1.35
1.75
10
955
940
50
0.6
1.1
1.5
TYPICAL POWER OUTPUT
DEGRADATION CURVE
V F IN VOLTS
POWER OUTPUT vs
FORWARD CURRENT
1.0
UNITS
mW
V
mA
nm
nm
Ohm
µS
mS
SPECTRAL OUTPUT
V F IN VOLTS
PO
VF
IR
IF IN AMPS
IF IN AMPS
TEMPERATURE, ºC
Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications
are subject to change without notice. Optical power and radiant intensity measured using uncapped dimpled TO-46 into integrating sphere.
很抱歉,暂时无法提供与“PDI-E913”相匹配的价格&库存,您可以联系我们找货
