PDI-E880SM
PDI-E880SM
    LUNAOPTOELECTRONICS(Luna Optoelectronics)
    EMITTER IR 880NM 100MA
PDI-E880SM 数据手册
PHOTONIC High-Power GaAIAs Infrared Emitters DETECTORS INC.Peak Wavelength, 880 nm, SMT Type PDI-E880SM PACKAGE DIMENSIONS inch (mm) 0.118 [3.00] CL CL 0.075 [1.90] CL 0.037 [0.95] 1 0.039 [1.00] 0.004 [0.10] CLEAR PLASTIC 2 1 140° VIEWING ANGLE 15° 0.110 [2.79] 2 0.009 [0.22] 3 3 0.059 [1.50] 0.020 [0.51] 0.008 [0.20] 0.043 [1.10] 0.014 [0.36] SQ Ø0.0046 [0.117) ANODE BOND PAD SOT-23 SMT PACKAGE 70O HALF INTENSITY BEAM ANGLE BOTTOM SIDE CATHODE DESCRIPTION: The PDI-E880SM infrared emitting FEATURES APPLICATIONS diode uses high reliability liquid phase epitaxially grown SOT-23 package Light screens GaAlAs. Optimized for high power, high efficiency. This Surface mount Touch screens 880 nm emitter is packaged in a clear plastic SOT-23. Wide emission angle Infrared sources Compatible with automatic pick & place equipment. ABSOLUTE MAXIMUM RATING (TA=25OC unless otherwise noted) SYMBOL PARAMETER MIN MAX UNITS Pd IFP IFP VR To & Ts TS Power Dissipation Continuous Forward Current Peak Forward Current (10µs, 10Hz) Reverse voltage Storage & Operating Temperature Soldering Temperature* -25 200 100 1 5 +100 +240 mW mA A V o C o C *1/16 inch from case for 3 secs max ELECTRO-OPTICAL CHARACTERISTICS (TA=25OC unless otherwise noted) SYMBOL CHARACTERISTIC TEST CONDITIONS MIN TYP Ct tr tf POWER OUTPUT, P O(mW) POWER OUTPUT vs FORWARD CURRENT FORWARD CURRENT, I F(mA) IF = 50 mA IF = 20 mA IF = 10 µ A IF = 50 mA IF = 50 mA VR = 0 V,f = 1 MHz IF = 100 mA IF = 100 mA TYPICAL POWER OUTPUT DEGRADATION CURVE STRESS TIME (hrs) 0.5 1.3 5 MAX 1.0 1.5 30 880 70 20 1.5 0.8 UNITS mW/sr V V nm nm pF µS mS RELATIVE POWER OUTPUT (&) λP D Dλ Radiant Intensity Forward Voltage Reverse Breakdown Voltage Peak Wavelength Spectral Halfwidth Terminal Capacitance Rise Time Fall Time RELATIVE POWER OUTPUT (%) PO VF VR SPECTRAL OUTPUT WAVELENGTH, λ(nm) Information in this technical data sheet is believed to be correct and reliable. However, no responsibility is assumed for possible inaccuracies or omission. Specifications are subject to change without notice. Optical power and radiant intensity measured using uncapped dimpled TO-46 into integrating sphere. [FORM NO. 100-PDI-E880SM REV N/C]
PDI-E880SM 价格&库存
很抱歉,暂时无法提供与“PDI-E880SM”相匹配的价格&库存,您可以联系我们找货
