400458
400458
    XMOS
    15 5-WIRE RESISTIVE TOUCHSCREEN
400458 数据手册
400458 Bergquist Part Number: 400458 Revision: A Description: 15.0" 5-wire Resistive Touch Screen Mechanical Dimensions and Construction. Specification 322.00mm x 245.50mm 2.47mm 309.50mm x 233.50mm 303.50mm x 227.50mm 1.85mm Overall Dimensions Overall Thickness Viewable Area Active Area Nominal Glass Thickness Remarks +/- .30mm +/- .30mm +/- .20mm +/- .20mm *See mechanical drawing for additional specification Environmental Specification Operating Temperature Storage Temperature Specification -10° C ~ +70° C -40° C ~ +80° C Constant Temperature/ Humidity 70° C/ 80% RH/ 500 Hrs. Thermal Shock -40° C ~ +80° C 60 min/cycle/100 times Chemical Resistance Acetone, methylene chloride, methyl ethyl ketone, isopropyl alcohol, mineral spirits, unleaded gasoline, diesel fuel, antifreeze, vinegar, coffee, tea, cooking oil, most commercial cleaners including laundry detergent, and ammonia based glass cleaners Remarks Standard Standard Non Condensing. Tested at ambient temperature after cycle Tested at ambient temperature after cycle 10 minutes at room temperature Optical Characteristics Specification Light Transmission >80% Haze
400458 价格&库存
很抱歉,暂时无法提供与“400458”相匹配的价格&库存,您可以联系我们找货
