400457
400457
    XMOS
    12.1 5-WIRE RES TOUCHSCREEN
400457 数据手册
400457 Bergquist Part Number: 400457 Revision: A Description: 12.1" 5-wire Resistive Touch Screen Mechanical Dimensions and Construction. Specification 271.27mm x 205.74mm 2.47mm 252.87mm x 191.40mm 248.87mm x 187.40mm 1.85mm Overall Dimensions Overall Thickness Viewable Area Active Area Nominal Glass Thickness Remarks +/- .30mm +/- .30mm +/- .20mm +/- .20mm *See mechanical drawing for additional specification Environmental Specification Operating Temperature Storage Temperature Specification -10° C ~ +70° C -40° C ~ +80° C Constant Temperature/ Humidity 70° C/ 80% RH/ 500 Hrs. Thermal Shock -40° C ~ +80° C 60 min/cycle/100 times Chemical Resistance Acetone, methylene chloride, methyl ethyl ketone, isopropyl alcohol, mineral spirits, unleaded gasoline, diesel fuel, antifreeze, vinegar, coffee, tea, cooking oil, most commercial cleaners including laundry detergent, and ammonia based glass cleaners Remarks Standard Standard Non Condensing. Tested at ambient temperature after cycle Tested at ambient temperature after cycle 10 minutes at room temperature Optical Characteristics Specification Light Transmission >80% Haze
400457 价格&库存
很抱歉,暂时无法提供与“400457”相匹配的价格&库存,您可以联系我们找货
