400432
400432
    XMOS
    15 8-WIRE RESISTIVE TOUCHSCREEN
400432 数据手册
400432 Bergquist Part Number: 400432 Revision: A Description: 15.0" 8-wire Resistive Touch Screen Mechanical Dimensions and Construction. Specification 332.60mm x 257.50mm 3.1mm 308.20mm x 232.10mm 304.10mm x 228.10mm 2.8mm Overall Dimensions Overall Thickness Viewable Area Active Area Nominal Glass Thickness Remarks +/- .50mm +/- .30mm +/- .50mm +/- .50mm *See mechanical drawing for additional specification Environmental Specification Operating Temperature Storage Temperature Constant Temperature/ Humidity Specification -10° C ~ +60° C -40° C ~ +80° C 70° C/ 80% RH/ 500 Hrs. Remarks Tested at ambient temperature after cycle Tested at ambient temperature after cycle Thermal Shock -40° C ~ +80° C 60 min/cycle/10 times Chemical Resistance Acetone, methylene chloride, methyl ethyl ketone, isopropyl alcohol, mineral spirits, unleaded gasoline, diesel fuel, antifreeze, vinegar, coffee, tea, cooking oil, most commercial cleaners including laundry detergent, and ammonia based glass cleaners 10 minutes at room temperature Specification >80%
400432 价格&库存
很抱歉,暂时无法提供与“400432”相匹配的价格&库存,您可以联系我们找货
