400430
400430
    XMOS
    12.1 8-WIRE RES TOUCHSCREEN
400430 数据手册
400430 Bergquist Part Number: 400430 Revision: A Description: 12.1" 8-wire Resistive Touch Screen Mechanical Dimensions and Construction. Specification 268.00mm x 204.00mm 2.1mm 250.00mm x 188.00mm 246.00mm x 185.00mm 1.8mm Overall Dimensions Overall Thickness Viewable Area Active Area Nominal Glass Thickness Remarks +/- .50mm +/- .30mm +/- .50mm +/- .50mm *See mechanical drawing for additional specification Environmental Specification Operating Temperature Storage Temperature Constant Temperature/ Humidity Specification -10° C ~ +60° C -40° C ~ +80° C 70° C/ 80% RH/ 500 Hrs. Remarks Tested at ambient temperature after cycle Tested at ambient temperature after cycle Thermal Shock -40° C ~ +80° C 60 min/cycle/10 times Chemical Resistance Acetone, methylene chloride, methyl ethyl ketone, isopropyl alcohol, mineral spirits, unleaded gasoline, diesel fuel, antifreeze, vinegar, coffee, tea, cooking oil, most commercial cleaners including laundry detergent, and ammonia based glass cleaners 10 minutes at room temperature Specification >80%
400430 价格&库存
很抱歉,暂时无法提供与“400430”相匹配的价格&库存,您可以联系我们找货
