8
D
7
5
6
4
2
3
1
REVISIONS
NOTES:
ROHS COMPLIANT
1.
2.
MATERIAL: HOUSING - NYLON 6/6, U.L.94-V0 RATING, BLACK (UNLESS OTHERWISE SPECIFIED)
CONTACTS - PHOSPHER BRONZE, TIN PLATED
3.
MOUNTING: SPACING ON .250" [6.35mm] CENTERS. OPTIONAL .060" [1.52mm] HOLES FOR OPPOSITE SIDE
MOUNTING. SAME SIDE MOUNTING , DELETE THE .060"[1.52mm] HOLES (SEE PATTERN)
4.
OPTO: STANDARD VISIBLE, IR LED, OR PHOTO DETECTOR WITH LEADS ON .100" [.25mm] CENTERS
5.
LED LEAD DIMENSIONS: MINIMUM .017" [.43mm] ROUND OR SQUARE SHAPE. MAXIMUM .030" [.76mm]
THICKNESS - .040" [1.02mm] WIDTH
6.
U.S. & FOREIGN PATENTS ISSUED
ECN #
426
REV.
DESCRIPTION
DATE
INITIALS
001
REVISED PER ECR 111009AZ01
6/20/10
SMU
CHK'D
DZ
002
REVISED PER ECR 041212KH02
4/13/12
KH
ED
D
0.060in
1.52mm
THRU HOLES
FOR OPP. SIDE
MOUNTING
.040
1.02mm
.095
2.41mm
.100
2.54mm
C
0.010in
0.25mm
2X
0.015in
0.38mm
PCB HOLE PATTERN
SECTION A-A
0.245in
6.22mm
0.100in
2.54mm
C
0.010in
0.25mm
POLARITY
REF
DETAIL B
SCALE 10 : 1
B
A
B
0.030in
0.76mm
0.125in
3.18mm
A
0.010in
0.25mm
0.150in
3.81mm
0.240in
6.10mm
0.010in
0.25mm
0.330in
8.38mm
DIMENSION STYLE: INCHES [MM]
GENERAL TOLERANCES UNLESS
OTHERWISE SPECIFIED
.X
.XX
.XXX
A
INCHES
.020
.010
.005
ANGLE 1'
MM
.508
.254
.127
BREAK ALL CORNERS AND SHARP
EDGES .030 MAX
APPROVAL
DATE
DRAWN
SMU
6/20/10
CHECKED
DZ
6/20/10
12780 DANIELSON CT, SUITE A, POWAY, CA 92064 U.S.A
PHONE: (800) 522-5546 EMAIL: vccsales@vcclite.com
TITLE:
MATERIAL
P-C-LITE
SEE NOTES
R
VERTICAL MOUNT
THIRD ANGLE PROJECTION
PROPRIETARY AND CONFIDENTIAL FINISH
ORDERING CODE : PCV 220
8
THE INFORMATION CONTAINED IN THIS
DRAWING IS THE SOLE PROPERTY OF
VISUAL COMMUNICATIONS COMPANY, INC.
ANY REPRODUCTION IN PART OR AS
A WHOLE WITHOUT THE WRITTEN
PERMISSION OF VISUAL
COMMUNICATIONS COMPANY, INC IS
PROHIBITED.
7
6
5
4
3
REV
SIZE DWG. NO.
SEE NOTES
B
SCALE: 5:1
DO NOT SCALE DRAWING
2
002
PCV 220
SHEET 1 OF 1
1
A
很抱歉,暂时无法提供与“PCV_220”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+14.3956450+1.86783
- 250+8.23254250+1.06817
- 500+7.18051500+0.93167
- 1000+6.549291000+0.84977
- 国内价格
- 1+8.67240
- 200+3.46680
- 500+3.34800
- 1000+3.29400
