8
5
6
7
4
2
3
1
REVISIONS
NOTES:
1.
2.
D
3.
4.
5.
6.
7.
ROHS COMPLIANT
MATERIAL:
PANEL CONNECTOR SOCKET - POLYESTER, UL RATING 94-V0
HEADER CONNECTOR - POLYESTER, UL RATING 94-V0
LENS - POLYCARBONATE, UL RATING 94-V2
MOISTURE SEAL - EPDM
LOCKWAHER - STEEL, NICKEL PLATE
TERMINALS - PHOSPHOR BRONZE, TIN PLATE
WIRE - 24 AWG 1007/ 1569
MOUNTING: HOLE SIZE - 5/16" (8mm) OPENING ON 1/2" CENTERS
PANEL THICKNESS: .031" ( .787mm) MIN - .125" (3.175mm) MAX
LED LEAD LENGTH:
FOR BI- LEADS - .250" 0.01" (6.35mm 0.254)
FOR TRI-LEADS - CONTACT FACTORY
FOR STANDARD DRY APPLICATIONS USE CMC 441 OR CMC 443 LENS; FOR DUST AND WET
CONDITIONS USE CMS 442 OR CMS 444 LENS (EXCEEDS NEMA 6P/IP 67)
U.S. & FOREIGN PATENT ISSUED
ECN #
REV.
DESCRIPTION
DATE
INITIALS
CHK'D
001
REVISED PER ECR 111009AZ01
11/26/10
KH
DPZ
D
CABLE ORDERING CODE EXAMPLE:
CNX 440 E02 4 1 12
LEDS
(ORDER SEPARATELY)
C
5MM BI-LEAD
X=
E=
D=
02 =
03 =
04 =
TERMINATION *
STRIPPED END
SINGLE ROW LOCKING HEADER
DUAL ROW LOCKING HEADER
2 WIRES
3 WIRES
4 WIRES
WIRE SIZE *
4
24 AWG
1
2
6
LENS
(ORDER SEPARATELY)
WIRE COLOR *
WHITE - BLACK
RED - BLACK
WHITE - BLACK - RED
WHITE - BLACK - RED - GREEN
04
06
08
12
18
24
WIRE LENGTH *
4 INCHES (101.6mm)
6 INCHES (152.4mm)
8 INCHES (203.2mm)
12 INCHES (304.8mm)
18 INCHES (457.2mm)
24 INCHES (609.6mm)
C
*CALL FACTORY
FOR ADDITIONAL
OPTIONS
CMC 441
CMC 443
CMS 442
CMS 444
PIN B = CATHODE (-) BLACK LEAD
B
B
1
2
W1
W2
5MM TRI-LEAD
PIN A = ANODE (+) WHITE OR RED LEAD
.750
19.05mm
XX.XX
DIMENSION STYLE: INCHES / MM
GENERAL TOLERANCES UNLESS
OTHERWISE SPECIFIED:
INCHES
MM
A
.500
12.7
APPROVAL
DATE
DRAWN
KHOWARD
11/26/10
CHECKED
DPZ
11/29/10
12780 DANIELSON CT, SUITE A, POWAY, CA 92064 U.S.A
PHONE: (800) 522-5546 EMAIL: vccsales@vcclite.com
TITLE:
MATERIAL
SEE NOTES
ASSEMBLY, CNX 440
CABLE
THIRD ANGLE PROJECTION
PROPRIETARY AND CONFIDENTIAL FINISH
THE INFORMATION CONTAINED IN THIS
DRAWING IS THE SOLE PROPERTY OF
VISUAL COMMUNICATIONS COMPANY, INC.
ANY REPRODUCTION IN PART OR AS
A WHOLE WITHOUT THE WRITTEN
PERMISSION OF VISUAL
COMMUNICATIONS COMPANY, INC IS
PROHIBITED.
8
7
6
5
4
3
SIZE DWG. NO.
SEE NOTES
B
SCALE: 1.75:1
DO NOT SCALE DRAWING
2
001
CNX 440 ASSY
SHEET 1 OF 1
1
A
很抱歉,暂时无法提供与“CNX_440_X02_4_1_24”相匹配的价格&库存,您可以联系我们找货
