PCH_175
PCH_175
    VCC
    PCH_175
PCH_175 数据手册
8 D 5 6 7 4 NOTES: 1. LED MOUNTING: for 5mm LEDs - round or rectangular shape with or without flange. Bi-lead, standard .100 [2.54mm] lead spacing. Tri-lead, either .050 [1.27mm] or .100 [2.54mm] lead spacing. Both the bi-lead and tri-lead LEDs can also be combined in arrays with one another. 2. ASSEMBLY: Can be used as a single LED mount or banded together in an array with its dovetail interlocking feature. When banded together with the PCH 175 the LEDs are on .250 [6.35mm] centers. 3. MATERIAL: Housing - Nylon 6/6, U.L. 94 V0 Rating, Color black (unless otherwise spec.) 4. U.S. & Foreign Pat. Issued & Pend. 5. LED shown for illustrative purposes. .050 1.27mm 2 3 ECN# 1 REV. REVISIONS DESCRIPTION DATE INITIALS 001 REVISED PER ECR111009AZ01 6-20-10 SMU 002 CORRECTED FORMAT FOR "A" DRAWING & NEW TITLEBLOCK 8/29/14 MB D POLARITY REF. .080 2.03mm A A .100 2.54mm PCB HOLE PATTERN C C .250 6.35mm TYP .350 8.89mm POLARITY REF. 2X .100 2.54mm .195 [4.95mm] 2X .050 1.27mm B ARRAY MOUNTING .248 6.30 .125 3.18mm B .20 [0.51mm] .050 1.27mm .100 2.54mm .220 5.59mm .156 [3.96mm] .010 0.25mm TYP SECTION A-A SCALE 4 : 1 MATERIAL DIMENSION STYLE: INCHES [MM] GENERAL TOLERANCES UNLESS OTHERWISE SPECIFIED A TRI - LEADS .X .XX .XXX BI - LEADS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF VISUAL COMMUNICATIONS COMPANY, LLC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF VISUAL COMMUNICATIONS COMPANY, LLC IS PROHIBITED. 7 6 NYLON 6/6, UL 94-V0, BLACK (UNLESS OTHERWISE SPEC.) MM .508 .254 .127 FINISH 12780 DANIELSON CT, SUITE A, POWAY, CA 92064 U.S.A PHONE: (800) 522-5546 EMAIL: vccsales@vcclite.com TITLE: P-C-LITE ANGLE 1 PROPRIETARY AND CONFIDENTIAL 8 INCHES .020 .010 .005 5 4 BREAK ALL CORNERS AND SHARP EDGES .030 MAX APPROVAL DATE SMU 6/20/10 DRAWN: CHECKED: DZ THIRD ANGLE PROJECTION PART # 6/20/10 DRAWING # SCALE: 1:1 DO NOT SCALE DRAWING 3 2 R A RT ANGLE MOUNT SIZE PCH_175 B REV PCH 175 002 SHEET 1 OF 1 1
PCH_175 价格&库存
很抱歉,暂时无法提供与“PCH_175”相匹配的价格&库存,您可以联系我们找货
PCH_175
