RNG_234
RNG_234
    VCC
    LED RETAINING RING 3MM
RNG_234 数据手册
RNG 268 CMC 321 LENSE RNG 234 ACTUAL SIZE I.D. .210 .300 .280 .360 .360 ORDERING CODES MODEL CMC 321 RTP .070 CMC 321 (LENS) RNG 234 (RETAINER) RNG 268 ( RETAINER) .330 .165 .080 COLOR RTP Red Transparent ATP Amber Transparent GTP Green Transparent LENS RETAINING RING DISPLAY PANEL BTP Blue Transparent YTP Yellow Transparent CTP Clear Transparent LED RETAINING RING INSTALLATION PRINTED CIRCUIT BOARD PCB TO PANEL MOUNTING CONNECTOR INSTALLATION Hold the lense tight to the panel using any suitable device which will not mark the lense surface. Press the ring into place using a 5/16" nut driver. NOTES: MATERIAL: Lens - Polycarbonate Retaining Ring - Polypropylene DESIGN: Low profile lens using fresnel rings. MOUNTING: Mounts thru the front of panel. Hole size 9/32" (7.2mm) on 3/8" centers. For PCB mounted LED use RNG 268 Retainer. Panel thickness with CNX connector: .030 to .070 use RNG 234 spacer .105 to .130 None Required See VCC brochure for information on CNX connectors. Hold the lense tight to the panel using any suitable device which will not mark the lense surface. Press the connector into place. U.S. PAT. PEND. ® REVISIONS NO DESCRIPTION DATE BY CLIPLITE CMC 321 LENSE 1 VISUAL COMMUNICATIONS COMPANY, INC. 2 7920-F Arjons Drive San Diego, California 92126 U.S.A. Phone (858) 549-6900 Fax (858) 549-3520 e-mail vccsales@vcclite.com 3 4 TOLERANCES DECIMAL SCALE ±.010 DIAMETER N/A DATE .003 TIR DRAWN BY 5 ANGLE ± 30' RADII .008 Max CHK'D 11/07/99 D R A W I N G N O . JMS CMC 321A
RNG_234 价格&库存
很抱歉,暂时无法提供与“RNG_234”相匹配的价格&库存,您可以联系我们找货
