8
D
6
7
5
4
2
3
NOTES
1.
ROHS COMPLIANT.
2.
UL 94V-2 FLAMMABILITY RATING.
-40 C TO 85 C OPERATING TEMPERATURE.
3.
SUITABLE FOR LIGHT PIPE WITH 2.2MM JACKET AND OPTICAL CORE NO GREATER
4.
THAN 1.5MM.
5.
DO NOT WAVE SOLDER WITH THIS DEVICE.
6.
FOR BEST RESULTS USE ONLY NARROW VIEWING ANGLE NON-DIFFUSED LEDS WITH
OUTPUT POWER GREATER THAN 100mcd.
ECN #
176
200
1
REVISIONS
REV
DESCRIPTION
INITIAL
RELEASE
001
002 REVISED PER ECR 100610KH01
DATE
8/3/10
10/6/10
INITIALS
KH
KH
D
.087
(2.210mm)
TRIMMED
FIBER OPTIC
JACKET
.06±.02
(1.52mm 0.51)
3
.193
(4.902mm)
PRESS FIBER OPTIC IN
C
C
.197
(5.004mm)
.161
(4.089mm)
1
3MM LED
B
.220
.210
5.588mm
5.334mm
CLIP ONTO LED
.114
(2.896mm)
.492
(12.497mm)
B
.039
(.991mm)
.157
(3.988mm)
.276
(7.010mm)
2X .035
(0.889mm)
2 SOLDER IN PLACE
.193
(4.902mm)
UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN INCHES:
ANGLES
1/2"
A
FINISH
128 BREAK ALL CORNERS AND SHARP
EDGES .030 MAX
LIGHT PIPE PREPARATION
AND SEQUENCE OF ASSSEMBLY
.098
(2.261mm)
LIGHT PIPE
AS ASSEMBLED
7
6
5
VISUAL COMMUNICATIONS COMPANY, INC.
NYLON 6/6
UL 94-V2
190 Bosstick Boulevard, Suite101 San Marcos, CA 92069 USA
Phone (760) 560-1300 Fax (760) 560-1301 email vccsales@vcclite.com
FINISH
TITLE:
SEE NOTES
APPROVAL
THROUGH-HOLE LED MOUNT
DATE
THIRD ANGLE PROJECTION
RECOMMENDED PWB
DEVICE LAYOUT
8
MATERIAL
DECIMALS
.X
.020
.010
.XX
.XXX .005
PROPRIETARY AND CONFIDENTIAL
THE INFORMATION CONTAINED IN THIS
DRAWING IS THE SOLE PROPERTY OF
VISUAL COMMUNICATIONS COMPANY, INC. ANY
REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
VISUAL COMMUNICATIONS COMPANY, INC IS
PROHIBITED.
4
3
DRAWN
K.Howard
8/3/10
CHECKED
DPZ
8/10/10
SIZE
SCALE: 4:1
DO NOT SCALE DRAWING
2
REV
DWG. NO.
B
THR 22
002
SHEET 1 OF 1
1
A
很抱歉,暂时无法提供与“THR_22”相匹配的价格&库存,您可以联系我们找货
