8
D
5
6
7
4
2
3
1
REVISIONS
NOTES:
1.
ROHS COMPLIANT
2.
MATERIAL: HOUSING - NYLON 6/6, U.L. 94-V0 RATING, BLACK (UNLESS OTHERWISE SPECIFIED)
CONTACTS - PHOSPHER BRONZE, TIN PLATED
3.
MOUNTING: SOCKET MOUNTS ON .250" [6.35mm] CENTERS. INSERT COMPONENT LEADS THRU
THE MOUNTING PAD END OF SOCKET
4.
OPTO: STANDARD VISIBLE, IR LED, OR PHOTO DETECTOR WITH LEADS ON .100" [.25mm] CENTERS
5.
LED LEAD DIMENSIONS: MINIMUM .017" [.43mm] ROUND OR SQUARE SHAPE. MAXIMUM .030" [.76mm]
THICKNESS - .040" [1.02mm] WIDTH
6.
U.S. & FOREIGN PATENTS ISSUED
ECN #
426
REV.
DESCRIPTION
DATE
INITIALS
001
REVISED PER ECR 111009AZ01
6/20/10
SMU
CHK'D
DZ
002
REVISED PER ECR 041212KH02
4/13/12
KH
ED
D
0.130in
3.3mm
0.070in
1.78mm
0.045in
1.14mm
C
2X
0.015in
0.38mm
SMD PAD PATTERN
C
SECTION A-A
POLARITY
REF
0.010in
0.25mm
B
DETAIL B
SCALE 10 : 1
0.010in
0.25mm
A
0.245in
6.22mm
B
0.125in
3.18mm
A
0.060in
1.52mm
0.060in
1.52mm
0.330in
8.38mm
0.100in
2.54mm
0.240in
6.10mm
0.010in
0.25mm
DIMENSION STYLE: INCHES [MM]
GENERAL TOLERANCES UNLESS
OTHERWISE SPECIFIED
.X
.XX
.XXX
A
INCHES
.020
.010
.005
ANGLE 1'
MM
.508
.254
.127
BREAK ALL CORNERS AND SHARP
EDGES .030 MAX
APPROVAL
DATE
DRAWN
SMU
6/20/10
CHECKED
DZ
6/20/10
12780 DANIELSON CT, SUITE A, POWAY, CA 92064 U.S.A
PHONE: (800) 522-5546 EMAIL: vccsales@vcclite.com
TITLE:
MATERIAL
P-C-LITE R HORIZONTAL
MOUNT
SEE NOTES
THIRD ANGLE PROJECTION
PROPRIETARY AND CONFIDENTIAL FINISH
ORDERING CODE : SMD 330
8
THE INFORMATION CONTAINED IN THIS
DRAWING IS THE SOLE PROPERTY OF
VISUAL COMMUNICATIONS COMPANY, INC.
ANY REPRODUCTION IN PART OR AS
A WHOLE WITHOUT THE WRITTEN
PERMISSION OF VISUAL
COMMUNICATIONS COMPANY, INC IS
PROHIBITED.
7
6
5
4
3
REV
SIZE DWG. NO.
SEE NOTES
B
SCALE: 5:1
DO NOT SCALE DRAWING
2
002
SMD 330
SHEET 1 OF 1
1
A
很抱歉,暂时无法提供与“SMD_330”相匹配的价格&库存,您可以联系我们找货
