8
7
5
6
4
2
3
NOTES:
1.
2.
D
3.
4.
5.
6.
ECN #
ROHS COMPLIANT
MATERIAL:
PANEL CONNECTOR SOCKET - POLYPROPYLENE, UL RATING 94-HB
HEADER CONNECTOR - POLYESTER, UL RATING 94-V0
TERMINALS - PHOSPHOR BRONZE, TIN PLATE
WIRE - 24 AWG 1007/ 1569
MOUNTING: HOLE SIZE - 9/32" (7.14mm)
PANEL THICKNESS: .030" ( .762mm) MIN - .220" (5.588mm) MAX
USING CMC 285:
FOR PANEL THICKNESS .030" (.762mm) - .045" (1.143mm) USE 2 SPC 060 SPACERS
FOR PANEL THICKNESS .050" (1.27mm) - .100" (2.54mm) USE 1 SPC 060 SPACER
FOR PANEL THICKNESS .105" (2.67mm) - .125" (3.175mm) NO SPACER REQUIRED
USING CML 325 OR CML 327:
FOR PANEL THICKNESS .060" (1.524mm) - .100" (2.54mm) USE 2 SPC 060 SPACERS
FOR PANEL THICKNESS .105" (2.667mm) - .125" (3.175mm) USE 1 SPC 060 SPACER
FOR PANEL THICKNESS .150" (3.81mm) - .220" (5.588mm) NO SPACER REQUIRED
LED LEAD LENGTH: FOR CMC 285 - .350" .01" (8.89mm 0.254mm)
FOR CML 325 OR CML 327 - .275" 0.01" (6.985mm 0.254)
U.S. & FOREIGN PATENT ISSUED AND PENDING
1
REVISIONS
REV
DESCRIPTION
001 REVISED PER ECR 111009AZ01
DATE
11/26/10
INITIALS
KH
D
CABLE ORDERING CODE EXAMPLE:
CNX D F 4 6 12
LENS/PANEL MOUNT
(ORDER SEPARATELY)
LED / SPACER
(ORDER SEPARATELY)
C
X=
F=
TERMINATION *
STRIPPED END
SINGLE ROW LOCKING HEADER
24
WIRE SIZE *
24 AWG
6
WIRE COLOR*
WHITE - BLACK - RED
5MM LED
04
06
08
12
18
24
WIRE LENGTH *
4 INCHES (101.6mm)
6 INCHES (152.4mm)
8 INCHES (203.2mm)
12 INCHES (304.8mm)
18 INCHES (457.2mm)
24 INCHES (609.6mm)
CML 325
CML 327
CMC 285
ANODE (+) WHITE LEAD
B
C
* CALL FACTORY
FOR ADDITIONAL
OPTIONS
CATHODE (-) BLACK LEAD
SPC 060
B
1
2
3
W3
W2
W1
1
2
3
ANODE (+) RED LEAD
.690
17.53mm
XX.XX
DIMENSION STYLE: INCHES / MM
GENERAL TOLERANCES UNLESS
OTHERWISE SPECIFIED:
INCHES
MM
A
MATERIAL
OPTOELECTRONICS
SEE NOTES
.500
12.7
190 BOSSTICK BLVD. SUITE 101 SAN MARCOS, CA 92069 U.S.A
PHONE: (760) 560-1300, FAX: (760) 560-1301 EMAIL: vccsales@vcclite.com
FINISH
TITLE:
CNX D CABLE
ASSEMBLY
SEE NOTES
THIRD ANGLE PROJECTION
PROPRIETARY AND CONFIDENTIAL
THE INFORMATION CONTAINED
IN THIS DRAWING IS THE SOLE
PROPERTY OF VISUAL
COMMUNICATIONS COMPANY, INC.
ANY REPRODUCTION IN PART OR AS
A WHOLE WITHOUT THE WRITTEN
PERMISSION OF VISUAL
COMMUNICATIONS
COMPANY, INC IS PROHIBITED.
8
7
6
5
4
3
APPROVAL
DATE
DRAWN
K.Howard
11/26/10
CHECKED
DPZ
11/29/10
REV
SIZE DWG. NO.
B
SCALE: 1.75:1
DO NOT SCALE DRAWING
2
CNX D ASSY
001
SHEET 1 OF 1
1
A
很抱歉,暂时无法提供与“CNX_D_X_4_6_08”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+52.669751+6.84457
- 10+39.2143210+5.09600
- 100+31.26541100+4.06302
- 500+27.78887500+3.61124
- 1000+26.658831000+3.46439
- 2000+25.703152000+3.34019
- 国内价格
- 1+30.12120
- 200+12.02040
- 500+11.62080
- 1000+11.42640
