CNX_440_X02_4_1_12
CNX_440_X02_4_1_12
    VCC
    LED CBL ASSY 5MM 2WIRE WH/BK 12"
CNX_440_X02_4_1_12 数据手册
8 5 6 7 4 2 3 1 REVISIONS NOTES: 1. 2. D 3. 4. 5. 6. 7. ROHS COMPLIANT MATERIAL: PANEL CONNECTOR SOCKET - POLYESTER, UL RATING 94-V0 HEADER CONNECTOR - POLYESTER, UL RATING 94-V0 LENS - POLYCARBONATE, UL RATING 94-V2 MOISTURE SEAL - EPDM LOCKWAHER - STEEL, NICKEL PLATE TERMINALS - PHOSPHOR BRONZE, TIN PLATE WIRE - 24 AWG 1007/ 1569 MOUNTING: HOLE SIZE - 5/16" (8mm) OPENING ON 1/2" CENTERS PANEL THICKNESS: .031" ( .787mm) MIN - .125" (3.175mm) MAX LED LEAD LENGTH: FOR BI- LEADS - .250" 0.01" (6.35mm 0.254) FOR TRI-LEADS - CONTACT FACTORY FOR STANDARD DRY APPLICATIONS USE CMC 441 OR CMC 443 LENS; FOR DUST AND WET CONDITIONS USE CMS 442 OR CMS 444 LENS (EXCEEDS NEMA 6P/IP 67) U.S. & FOREIGN PATENT ISSUED ECN # REV. DESCRIPTION DATE INITIALS CHK'D 001 REVISED PER ECR 111009AZ01 11/26/10 KH DPZ D CABLE ORDERING CODE EXAMPLE: CNX 440 E02 4 1 12 LEDS (ORDER SEPARATELY) C 5MM BI-LEAD X= E= D= 02 = 03 = 04 = TERMINATION * STRIPPED END SINGLE ROW LOCKING HEADER DUAL ROW LOCKING HEADER 2 WIRES 3 WIRES 4 WIRES WIRE SIZE * 4 24 AWG 1 2 6 0 LENS (ORDER SEPARATELY) WIRE COLOR * WHITE - BLACK RED - BLACK WHITE - BLACK - RED WHITE - BLACK - RED - GREEN 04 06 08 12 18 24 WIRE LENGTH * 4 INCHES (101.6mm) 6 INCHES (152.4mm) 8 INCHES (203.2mm) 12 INCHES (304.8mm) 18 INCHES (457.2mm) 24 INCHES (609.6mm) C *CALL FACTORY FOR ADDITIONAL OPTIONS CMC 441 CMC 443 CMS 442 CMS 444 PIN B = CATHODE (-) BLACK LEAD B B 1 2 W1 W2 5MM TRI-LEAD PIN A = ANODE (+) WHITE OR RED LEAD .750 19.05mm XX.XX DIMENSION STYLE: INCHES / MM GENERAL TOLERANCES UNLESS OTHERWISE SPECIFIED: INCHES MM A .500 12.7 APPROVAL DATE DRAWN KHOWARD 11/26/10 CHECKED DPZ 11/29/10 12780 DANIELSON CT, SUITE A, POWAY, CA 92064 U.S.A PHONE: (800) 522-5546 EMAIL: vccsales@vcclite.com TITLE: MATERIAL SEE NOTES ASSEMBLY, CNX 440 CABLE THIRD ANGLE PROJECTION PROPRIETARY AND CONFIDENTIAL FINISH THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF VISUAL COMMUNICATIONS COMPANY, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF VISUAL COMMUNICATIONS COMPANY, INC IS PROHIBITED. 8 7 6 5 4 3 SIZE DWG. NO. SEE NOTES B SCALE: 1.75:1 DO NOT SCALE DRAWING 2 001 CNX 440 ASSY SHEET 1 OF 1 1 A
CNX_440_X02_4_1_12
- 物料型号:CNX 440 ASSY - 器件简介:文档中未提供详细的器件简介。 - 引脚分配:文档中提到了5mm Bi-Lead和5mm Tri-Lead,但具体的引脚分配信息未明确列出。 - 参数特性:文档提到了多种材料和UL评级,例如聚酯材料、UL 94-V0评级的插座连接器、聚碳酸酯镜头、EPDM密封圈、镀镍钢锁紧垫圈、磷青铜端子、镀锡等。 - 功能详解:文档中未提供详细的功能详解。 - 应用信息:文档中提到了不同条件下使用的镜头类型,例如CMC 441或CMC 443适用于干燥环境,CMS 442或CMS 444适用于尘土和潮湿环境。 - 封装信息:文档中提到了面板厚度、LED引线长度、孔径大小等封装信息
CNX_440_X02_4_1_12 价格&库存
很抱歉,暂时无法提供与“CNX_440_X02_4_1_12”相匹配的价格&库存,您可以联系我们找货
