Chemical Compatibility
Kit Part No.
CCK-6MX6
Chemical Compatibility Test Kit
• Includes 6 Cree MX-6 LEDs
• Used to properly test material chemical compatibility up to 85°C(1)(2) conditions
• Test material intended for use with LEDs for outgassing volatile organic compounds (VOCs)
that can damage LEDs in a sealed environment
• MX-6 must run a constant current of 350mA(1)(2)
• Used to validate chemical compatibility with:
MHB-A, MHD-G, MX-3, MX-6, ML-B, ML-C, and ML-E LEDs
• Reference Documents:
• Chemical compatibility testing procedures video HERE
• (1)For most up to date testing information check the Cree
chemical compatibility application notes HERE
• (2)Make sure work surface can handle temperature conditions.
18
pieces
Opulent Americas • 807 Spring Forest Road, Suite 900 Raleigh, NC 27609 • 919.407.8322 • info@opulent-americas.com
Last Modified 1/18/2017
Opulent-Americas.com
Kit Part No.
CCK-6XHP50
• Includes 6 Cree XHP LEDs
• Used to properly test material chemical compatibility up to 120°C(1)(2) conditions
• XHP must run a constant current of 700mA(1)(2)
XHP35, XHP50, XHP70 LEDs
(2)Make
18
pieces
Kit Part No.
CCK-6XPE
• Includes 6 Cree XLamp® XP-E LEDs
• XP-E must run a constant current of 700mA(1)(2)
CXA, CXB, XP-C, XP-E, XP-G, XM-L, XM-L HV, XT-E,
XT-E HV, MK-R, XB-D, XQ-D, XQ-B, and MT-G LEDs
18
pieces
Last Modified 7/13/2016
Chemical Compatibility Kit - Quick Reference Guide
Place material to test on top of the first three
LED components, then place the material to test
on the base of the next two LED components.
The final LED will be the control reference.
Mix the Arctic Silver Thermal Adhesive in a
mixing cup. Apply the adhesive around the
base of the glass vials then place around
each LED. Twist slightly to ensure a proper
seal.
Solder wire leads to each chemical
board and attach a constant current
supply. Drive current varies based
on component type. Run test for
1,000 hours and watch for changes
in LED intensity and/or color.
XHP50 must run constant current of 700mA(1)
XP-E must run constant current of 700mA(1)
MX-6 must run constant current of 350mA(1)
(1)
www.youtube.com/w
atch?v=t24bf9D_1SA
information check the cree chemnical
compatibility application notes below:
www.cree.com/xlamp_app_notes/chemical_compatibility
很抱歉,暂时无法提供与“CCK-6XPE-CK01”相匹配的价格&库存,您可以联系我们找货
