ZFC-11WR/KIT
ZFC-11WR/KIT
    JKLCOMPONENTS
ZFC-11WR/KIT 数据手册
ALUMINUM LED CHANNEL KITS Quality Lighting Solutions Since 1972 JKL COMPONENTS CORPORATION 13343 PAXTON ST, PACOIMA, CA 91331 (818)896-0019 • (800) 421-7244 SALES@JKLLAMPS.COM WWW.JKLLAMPS.COM ALUMINUM LED CHANNEL KITS ZFC-17-PC/KIT - Low Profile Channel W: 17mm H: 8.5mm L: 1 meter CONTENTS: • 1 ZFC-17 Aluminum Channel (1 meter) • 1 Milk White lens • 1 Semi Clear lens • 2 End Caps (1 with hole, 1 without) • 4 Mounting Clips FEATU RES H IG POLY CARB H-TEMP ONAT E LENSE S ZFC-18C-PC/KIT - Corner Mount Channel W: 18.5 mm H: 18.5 mm L: 1 meter CONTENTS: • 1 ZFC-18C Aluminum Channel (1 meter) • 1 Milk White lens • 1 Clear lens • 2 End Caps (1 with hole, 1 without) • 4 Mounting Clips FEATU RES H IG POLY CARB H-TEMP ONAT E LENSE S COMPATIBLE LED FLEX TAPE Width of tape Features FC /K PC 7 -1 T KI IT ZFS-84000 C/ -P C 18 FC IT FC K P/ B 0 -2 / 21 FC Z  C ZF        X     High Density     X  High Density     X    X    X JKL LED Flex Series Voltage ZFS-8500 ZFS-85000HD ZFS-105000-DBW ZFS-10504-RGB ZFS-84000 ZFS-125000HD ZFS-104000 ZFS-245000 12V 8mm Standard 12V 8mm 12V Z  Z  Z  High Density   10mm Adjustable White  12V 10mm RGB 24V 8mm 24V 12mm 24V 10mm High Output  24V 10mm High Output  T KI R/ W 1 -1 T KI ALUMINUM LED CHANNEL KITS ZFC-20BP-KIT - Domed Lens W: 20mm H: 20mm L: 1 meter CONTENTS: • 1 ZFC-20 Aluminum Channel (1 meter) • 1 Milk White lens • 1 Semi Clear lens • 2 End Caps (1 with hole, 1 without) BOTTOM RAIL PROVIDES FOR INVISIBLE MOUNTING NO MOUNTING CLIPS NEEDED ZFC-21-PC-KIT - Recessed Channel W: 27 mm H: 11 mm L: 1 meter CONTENTS: FEATU RES H IG POLY CARB H-TEMP ONAT E LENSE S • 1 ZFC-21 Aluminum Channel (1 meter) • 1 Frosted Lens • 2 End Caps (1 with hole, 1 without) RECESSED LED CHANNEL DOES NOT REQUIRE MOUNTING CLIPS ZFC-11WR-KIT - Narrow Channel W: 11.7mm H: 12mm L: 1 meter CONTENTS: • 1 ZFC-11WR Plastic Channel (1 meter) • 1 Frosted Lens • 2 End Caps (1 with hole, 1 without) • 4 Mounting Clips Quality Lighting Solutions Since 1972 JKL COMPONENTS CORPORATION 13343 PAXTON ST, PACOIMA, CA 91331 (818)896-0019 • (800) 421-7244 SALES@JKLLAMPS.COM WWW.JKLLAMPS.COM
ZFC-11WR/KIT 价格&库存
很抱歉,暂时无法提供与“ZFC-11WR/KIT”相匹配的价格&库存,您可以联系我们找货
