CABLES
POSITIVE LOCKING POLARITY HEADER
SPECIFICATIONS
MATERIAL
Body
Pins
Spacing
Header
Thermoplastic (black) U.L. 94 V2
Phosphor bronze .025˝ square tin plate
Pins on .100˝ centers
Mates with VCC locking header connector, or equivalent
FEATURES
• Locking lever provides polarity integrity by restricting insertion of locking header in reverse.
• Lever clicks and locks preventing header connector from being retracted inadvertently.
• Locking header available in 2 to 28 pin positions, vertical or horizontal configuration.
U.S. & Foreign Patents Issued and Pending
• Designed for both vertical and horizontal mounting on the printed circuit board.
• Pins are .025˝ square brass, tin plated, located on .100˝ centers.
ORDERING CODES
• Locking header mates with VCC locking header connectors or equivalent.
CNX V06 NTP
MODEL
PLATING
PIN CONFIGURATION - 02 TO 28 CIRCUITS
V = VERTICAL / # CIRCUITS
H = HORIZONTAL / # CIRCUITS
OUTLINE DRAWINGS
HEADER LOCKING FEATURE
PCB HOLE LAYOUT
HEADER CONNECTOR
SPECIFICATIONS
MATERIAL
Header connector -
Terminals
Wire
MOUNTING
Non-locking plain header connector mates with any standard .025 ˝
square header on .100˝ centers. Locking header connectors mate with
VCC positive locking header 450 series. Also mates with standard and
friction header .025˝ pins on .100˝ centers.
Thermoplastic (black) U.L. 94 V0
Phosphor bronze, tin plated
Rate 3 amp continuous service
24 AWG, 7 strand copper, PVC insulated
FEATURES
• Header connector mates with VCC locking header CNX xxx, Molex 6373, 7478 friction header or equal.
• Header connectors 2, 3, 4, 6 and 8 position are end-to-end stackable.
• Header connectors with or without locking tab, rated U.L. 94 V0.
• Terminal’s unique tri-finger design mates with pins from .017˝ round to .025 ˝ square.
ONLY AVAILABLE WITH WIRES
CALL FOR ORDER INFORMATION
• Terminals for use specifically with VCC header connectors.
• Terminals designed for use with wire rating 24 AWG 300V, 105˚C.
HEADER CONNECTORS
NON-LOCKING HEADER CONNECTOR
1.800.522.5546
vccsales@vcclite.com
www.VCCLITE.com
23
很抱歉,暂时无法提供与“CNX_H01_NTP”相匹配的价格&库存,您可以联系我们找货
