CNX_H06_NTP
CNX_H06_NTP
    VCC
    RIGHT ANGLE SINGLE ROW HDR
CNX_H06_NTP 数据手册
CABLES POSITIVE LOCKING POLARITY HEADER SPECIFICATIONS MATERIAL Body Pins Spacing Header - - - - Thermoplastic (black) U.L. 94 V2 Phosphor bronze .025˝ square tin plate Pins on .100˝ centers Mates with VCC locking header connector, or equivalent FEATURES • Locking lever provides polarity integrity by restricting insertion of locking header in reverse. • Lever clicks and locks preventing header connector from being retracted inadvertently. • Locking header available in 2 to 28 pin positions, vertical or horizontal configuration. U.S. & Foreign Patents Issued and Pending • Designed for both vertical and horizontal mounting on the printed circuit board. • Pins are .025˝ square brass, tin plated, located on .100˝ centers. ORDERING CODES • Locking header mates with VCC locking header connectors or equivalent. CNX V06 NTP MODEL PLATING PIN CONFIGURATION - 02 TO 28 CIRCUITS V = VERTICAL / # CIRCUITS H = HORIZONTAL / # CIRCUITS OUTLINE DRAWINGS HEADER LOCKING FEATURE PCB HOLE LAYOUT HEADER CONNECTOR SPECIFICATIONS MATERIAL Header connector - Terminals - Wire - MOUNTING Non-locking plain header connector mates with any standard .025 ˝ square header on .100˝ centers. Locking header connectors mate with VCC positive locking header 450 series. Also mates with standard and friction header .025˝ pins on .100˝ centers. Thermoplastic (black) U.L. 94 V0 Phosphor bronze, tin plated Rate 3 amp continuous service 24 AWG, 7 strand copper, PVC insulated FEATURES • Header connector mates with VCC locking header CNX xxx, Molex 6373, 7478 friction header or equal. U.S. & Foreign Patents Issued and Pending • Header connectors 2, 3, 4, 6 and 8 position are end-to-end stackable. • Header connectors with or without locking tab, rated U.L. 94 V0. • Terminal’s unique tri-finger design mates with pins from .017˝ round to .025 ˝ square. ONLY AVAILABLE WITH WIRES CALL FOR ORDER INFORMATION • Terminals for use specifically with VCC header connectors. • Terminals designed for use with wire rating 24 AWG 300V, 105˚C. HEADER CONNECTORS NON-LOCKING HEADER CONNECTOR 1.800.522.5546 vccsales@vcclite.com LOCKING HEADER CONNECTOR www.VCCLITE.com 23
CNX_H06_NTP 价格&库存
很抱歉,暂时无法提供与“CNX_H06_NTP”相匹配的价格&库存,您可以联系我们找货
