8
5
6
7
4
2
3
NOTES:
1.
2.
D
3.
4.
5.
6.
ECN #
ROHS COMPLIANT
MATERIAL:
PANEL CONNECTOR SOCKET - POLYPROPYLENE, UL RATING 94-HB
HEADER CONNECTOR - POLYESTER, UL RATING 94-V0
TERMINALS - PHOSPHOR BRONZE, TIN PLATED
WIRE - 24 AWG 1007/ 1569
MOUNTING: HOLE SIZE - 9/32" (7.14mm)
PANEL THICKNESS: .030" (.762mm) MIN - .250" (6.35mm) MAX
USE RNG 242 RETAINING RING WHEN ADDITIONAL SECURITY IS REQUIRED
LED LEAD LENGTH: 5mm FLANGLESS LED .250" (6.35mm)
U.S. & FOREIGN PATENT ISSUED AND PENDING
1
REVISIONS
REV
DESCRIPTION
001 REVISED PER ECR 111009AZ01
DATE
11/26/10
INITIALS
KH
D
CABLE ORDERING CODE EXAMPLE:
CNX K E 4 1 12
LED
(ORDER SEPARATELY)
C
X=
E=
G=
TERMINATION *
STRIPPED END
SINGLE ROW LOCKING HEADER
SINGLE ROW PLAIN HEADER
WIRE SIZE *
4
1
2
24 AWG
WIRE COLOR *
WHITE - BLACK
RED - BLACK
5MM FLANGLESS
* CALL FACTORY
FOR ADDITIONAL
OPTIONS
WIRE LENGTH *
04
06
08
12
18
24
4 INCHES (101.6mm)
C
6 INCHES (152.4mm)
8 INCHES (203.2mm)
12 INCHES (304.8mm)
18 INCHES (457.2mm)
24 INCHES (609.6mm)
ANODE (+) WHITE OR RED LEAD
RETAINING RING
B
W2
W1
1
2
.680
17.272mm
B
1
2
XX.XX
CATHODE (-) BLACK LEAD
DIMENSION STYLE: INCHES / MM
GENERAL TOLERANCES UNLESS
OTHERWISE SPECIFIED:
INCHES
MM
A
MATERIAL
OPTOELECTRONICS
SEE NOTES
.500
12.7
190 BOSSTICK BLVD. SUITE 101 SAN MARCOS, CA 92069 U.S.A
PHONE: (760) 560-1300, FAX: (760) 560-1301 EMAIL: vccsales@vcclite.com
FINISH
TITLE:
CNX K CABLE
ASSEMBLY
SEE NOTES
THIRD ANGLE PROJECTION
PROPRIETARY AND CONFIDENTIAL
THE INFORMATION CONTAINED
IN THIS DRAWING IS THE SOLE
PROPERTY OF VISUAL
COMMUNICATIONS COMPANY, INC.
ANY REPRODUCTION IN PART OR AS
A WHOLE WITHOUT THE WRITTEN
PERMISSION OF VISUAL
COMMUNICATIONS
COMPANY, INC IS PROHIBITED.
8
7
6
5
4
3
APPROVAL
DATE
DRAWN
K.Howard
11/26/10
CHECKED
DPZ
11/29/10
REV
SIZE DWG. NO.
B
SCALE: 1:1
DO NOT SCALE DRAWING
2
CNX K ASSY
001
SHEET 1 OF 1
1
A
很抱歉,暂时无法提供与“CNX_K_X_4_1_04”相匹配的价格&库存,您可以联系我们找货
