EL Wire Chasing Adapter Cable
COM -1 2934 RO HS
images are CC BY-NC-SA 3.0
Description: This is an Chasing EL Wire Adapter Cable, a simple connector that
splits up the four wires in a Chasing EL wire allowing them to be individually powered
or controlled. On one side of this cable is a 4-pin JST SMP connector that can be
attached to a chasing EL wire, while on the other side are three 2-pin JST PHR-2
connectors which are used in more standard EL applications.
Two of the JST PHR-2 connectors are only equipped with one wire and one unused
pin while the last connector has two wires (this extra wire supports common ground).
With this adapter cable you will be able to use your Chasing EL Wires with our EL
Sequencer and EL Escudo Dos products!
Dimensions: 155mm (6") L
https://www.sparkfun.com/products/12934
11/24/2015
很抱歉,暂时无法提供与“COM-12934”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+10.043431+1.29950
- 5+9.170095+1.18650
- 25+8.0347425+1.03960
- 100+7.51074100+0.97180
- 国内价格
- 1+12.60755
- 5+11.55014
- 25+10.16738
- 100+9.43532
