8
5
6
7
4
2
3
NOTES:
1.
2.
D
3.
4.
5.
6.
ECN #
ROHS COMPLIANT
MATERIAL:
PANEL CONNECTOR SOCKET - POLYPROPYLENE, UL RATING 94-HB
HEADER CONNECTOR - POLYESTER, UL RATING 94-V0
TERMINAL - PHOSPHOR BRONZE, TIN PLATE
WIRE - 24 AWG 1007/1569
MOUNTING: HOLE SIZE: 11/64" (4.37mm)
PANEL THICKNESS: .030" (.762mm) MIN - .075" (1.905mm) MAX
FOR PANEL THICKNESS .030" (.762mm) - .050" (1.270mm) USE 1 SPC 040 SPACER
FOR PANEL THICKNESS .055" (1.397mm) - .075" (1.905mm) NO SPACER REQUIRED
LED LEAD LENGTH: FOR SMC 130 - .380" (9.652mm); FOR SMC 170 - .320" (8.128mm)
U.S. & FOREIGN PATENT ISSUED AND PENDING
LED/SPACER
(ORDER SEPARATELY)
1
REVISIONS
REV
DESCRIPTION
001 REVISED PER ECR 111009AZ01
DATE
9/28/10
D
LENS/PANEL MOUNT
(ORDER SEPARATELY)
CABLE ORDERING CODE EXAMPLE:
CNX B E 4 1 12
C
X=
E=
G=
INITIALS
KH
TERMINATION *
STRIPPED END
SINGLE ROW LOCKING HEADER
SINGLE ROW PLAIN HEADER
WIRE SIZE *
4 24 AWG
WIRE COLOR *
1
WHITE - BLACK
RED - BLACK
2
3 MM LED
04
06
08
12
18
24
WIRE LENGTH *
4 INCHES (101.6mm)
6 INCHES (152.4mm)
8 INCHES (203.2mm)
12 INCHES (304.8mm)
18 INCHES (457.2mm)
24 INCHES (609.6mm)
* CALL FACTORY
FOR ADDITIONAL
OPTIONS
C
SMC 130
SMC 170
ANODE (+) WHITE OR RED LEAD
B
SPC 040
B
1
2
W2
W1
1
2
CATHODE (-) BLACK LEAD
.650
16.51mm
XX.XX
DIMENSION STYLE: INCHES / MM
GENERAL TOLERANCES UNLESS
OTHERWISE SPECIFIED:
A
INCHES
MM
MATERIAL
OPTOELECTRONICS
SEE NOTES
.500
12.7
190 BOSSTICK BLVD. SUITE 101 SAN MARCOS, CA 92069 U.S.A
PHONE: (760) 560-1300, FAX: (760) 560-1301 EMAIL: vccsales@vcclite.com
FINISH
TITLE:
SEE NOTES
THIRD ANGLE PROJECTION
PROPRIETARY AND CONFIDENTIAL
THE INFORMATION CONTAINED
IN THIS DRAWING IS THE SOLE
PROPERTY OF VISUAL
COMMUNICATIONS COMPANY, INC.
ANY REPRODUCTION IN PART OR AS
A WHOLE WITHOUT THE WRITTEN
PERMISSION OF VISUAL
COMMUNICATIONS
COMPANY, INC IS PROHIBITED.
8
7
6
5
4
3
CNX B CABLE
ASSEMBLY
DATE
APPROVAL
SIZE
DRAWN
K.Howard
9/28/10
CHECKED
DPZ
11/29/10
SCALE: 1:1
DO NOT SCALE DRAWING
2
REV
DWG. NO.
B
CNX B ASSY
001
SHEET 1 OF 1
1
A
很抱歉,暂时无法提供与“CNX_B_G_4_1_18”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+36.23025500+4.69309
