C13324_LENA-STD-BASE-CXA25
    LEDIL(芬兰)
C13324_LENA-STD-BASE-CXA25 数据手册
PRODUCT DATASHEET C13324_LENA-STD-BASE-CXA25 LENA-STD-BASE-CXA25 Basepart for LENA and LENINA reflectors. Compatible with CREE CXA and B 25xx. TECHNICAL SPECIFICATIONS: Dimensions Height Ø 58.7 mm 14.5 mm Fastening screw ROHS compliant yes MATERIAL SPECIFICATIONS: Component Type Material Colour LENA-STD-BASE-CXA25 Base part PC white Finish ORDERING INFORMATION: Component C13324_LENA-STD-BASE-CXA25 » Box size: 380 x 240 x 120 mm Qty in box 60 MOQ MPQ 60 60 Last update: 20/10/2019 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 1.0 1/3 PRODUCT DATASHEET C13324_LENA-STD-BASE-CXA25 See also our general installation guide: www.ledil.com/installation_guide Last update: 20/10/2019 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/3 PRODUCT DATASHEET C13324_LENA-STD-BASE-CXA25 GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 20/10/2019 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/3
物料型号:C13324_LENA-STD-BASE-CXA25
器件简介:该产品是LENA和LENINA反射器的基础部分,兼容CREE CXA和B 25xx系列。
引脚分配:文档中未提供引脚分配信息。
参数特性: - 尺寸:直径58.7毫米,高度14.5毫米 - 固定螺丝:符合ROHS标准
功能详解: - 光束角度可能会因不同的颜色、芯片尺寸和芯片位置公差而改变。 - 总光束角度是当发光强度为峰值一半时的全角度。
应用信息:文档中未提供具体的应用信息
封装信息: - 材料:PC塑料 - 颜色:白色
订购信息: - 组件数量:每箱60个 - 最小订购量(MOQ):60 - 最大包装量(MPQ):60 - 箱重:1.0公斤 - 箱尺寸:380 x 240 x 120毫米
公司信息: - LEDiL Oy是LEDiL在欧盟、美国和某些其他国家的注册商标。
免责声明: - 提供的数据仅供参考,LEDiL Oy不保证数据的准确性或完整性,并且保留在不通知的情况下更改产品的权利。
C13324_LENA-STD-BASE-CXA25 价格&库存
很抱歉,暂时无法提供与“C13324_LENA-STD-BASE-CXA25”相匹配的价格&库存,您可以联系我们找货
