CNX_410_012_X02_4_1_18
    VCC
CNX_410_012_X02_4_1_18 数据手册
8 5 6 7 4 2 3 1 REVISIONS NOTES: 1. 2. D 3. 4. 5. 6. 7. 8. ROHS COMPLIANT MATERIAL: PANEL CONNECTOR - THERMOPLASTIC, WHITE, UL RATING 94-V0 HEADER CONNECTOR - POLYESTER, UL RATING 94-V0 LENS - POLYCARBONATE - UL RATING 94-V2 MOISTURE SEAL - EPDM LOCK WASHER - STEEL, NICKEL PLATE TERMINALS - PHOSPHER BRONZE, TIN PLATE WIRE - 24 AWG 1007/1569 MOUNTING: HOLE SIZE .313" (7.9mm) OPENING ON 1/2" CENTERS (12.7mm) PANEL THICKNESS: UP TO .125" (3.18mm) MAX LED LEAD LENGTH: .250" +/- .01 (6.35mm +/- .254) FOR STANDARD DRY APPLICATIONS USE CMC 441, FOR WET OR DRY APPLICATIONS USE CMS 442 (MEETS NEMA 6P/ IP67) LABEL TEXT: "CNX 410 XXX; XXX0 Ohms" U.S AND FOREIGN PATENT ISSUED REV. DESCRIPTION DATE INITIALS CHK'D 425 000 REVISED PER ECR 032112ED01 5/1/12 KH ED D LENS W/ LOCKWASHER (ORDER SEPARATELY) CABLE ORDERING CODE EXAMPLE: CNX 410 056 E02 4 1 08 C ECN # * CALL FACTORY FOR ADDITIONAL OPTIONS LED (ORDER SEPARATELY) C CMC 441 012 = 018 = 033 = 056 = 120 = 220 = RESISTOR * 120 OHMS 180 OHMS 330 OHMS 560 OHMS 1200 OHMS 2200 OHMS TERMINATION * STRIPPED END SINGLE ROW LOCKING HEADER X= E= WIRE SIZE * 4= 24 AWG WIRE COLOR * 1 = WHITE - BLACK 2= RED - BLACK LABEL 04 = 06 = 08 = 12 = 18 = 24 = WIRE LENGTH * 4 INCHES (101.6mm) 6 INCHES (152.4mm) 8 INCHES (203.2mm) 12 INCHES (304.8mm) 18 INCHES (457.2mm) 24 INCHES (609.6mm) CMS 442 (MOISTURE SEALED) PIN B = ANODE (+) WHITE OR RED LEAD 5MM LED B B W2 W1 PIN A = CATHODE (-) BLACK LEAD .550in 13.97mm XX.XX" DIMENSION STYLE: INCHES / MM GENERAL TOLERANCES UNLESS OTHERWISE SPECIFIED: INCHES MM A .500 12.7 APPROVAL DATE DRAWN KHOWARD 5/1/12 CHECKED EDEGUZMAN 5/2/12 12780 DANIELSON CT, SUITE A, POWAY, CA 92064 U.S.A PHONE: (800) 522-5546 EMAIL: vccsales@vcclite.com TITLE: MATERIAL CNX 410 CABLE ASSEMBLY SEE NOTES THIRD ANGLE PROJECTION PROPRIETARY AND CONFIDENTIAL FINISH THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF VISUAL COMMUNICATIONS COMPANY, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF VISUAL COMMUNICATIONS COMPANY, INC IS PROHIBITED. 8 7 6 5 4 3 REV SIZE DWG. NO. N/A B CNX 410 XXX ASSY SCALE: 2:1 DO NOT SCALE DRAWING 2 000 SHEET 1 OF 1 1 A
CNX_410_012_X02_4_1_18 价格&库存
很抱歉,暂时无法提供与“CNX_410_012_X02_4_1_18”相匹配的价格&库存,您可以联系我们找货
  • 500+40.97525500+5.31118
    • 1+53.75160
    • 200+21.44880
    • 500+20.73600
    • 1000+20.37960
