CNX_B_G_4_1_24
CNX_B_G_4_1_24
    VCC
    CNX_B_G_4_1_24
CNX_B_G_4_1_24 数据手册
8 5 6 7 4 2 3 NOTES: 1. 2. D 3. 4. 5. 6. ECN # ROHS COMPLIANT MATERIAL: PANEL CONNECTOR SOCKET - POLYPROPYLENE, UL RATING 94-HB HEADER CONNECTOR - POLYESTER, UL RATING 94-V0 TERMINAL - PHOSPHOR BRONZE, TIN PLATE WIRE - 24 AWG 1007/1569 MOUNTING: HOLE SIZE: 11/64" (4.37mm) PANEL THICKNESS: .030" (.762mm) MIN - .075" (1.905mm) MAX FOR PANEL THICKNESS .030" (.762mm) - .050" (1.270mm) USE 1 SPC 040 SPACER FOR PANEL THICKNESS .055" (1.397mm) - .075" (1.905mm) NO SPACER REQUIRED LED LEAD LENGTH: FOR SMC 130 - .380" (9.652mm); FOR SMC 170 - .320" (8.128mm) U.S. & FOREIGN PATENT ISSUED AND PENDING LED/SPACER (ORDER SEPARATELY) 1 REVISIONS REV DESCRIPTION 001 REVISED PER ECR 111009AZ01 DATE 9/28/10 D LENS/PANEL MOUNT (ORDER SEPARATELY) CABLE ORDERING CODE EXAMPLE: CNX B E 4 1 12 C X= E= G= INITIALS KH TERMINATION * STRIPPED END SINGLE ROW LOCKING HEADER SINGLE ROW PLAIN HEADER WIRE SIZE * 4 24 AWG WIRE COLOR * 1 WHITE - BLACK RED - BLACK 2 3 MM LED 04 06 08 12 18 24 WIRE LENGTH * 4 INCHES (101.6mm) 6 INCHES (152.4mm) 8 INCHES (203.2mm) 12 INCHES (304.8mm) 18 INCHES (457.2mm) 24 INCHES (609.6mm) * CALL FACTORY FOR ADDITIONAL OPTIONS C SMC 130 SMC 170 ANODE (+) WHITE OR RED LEAD B SPC 040 B 1 2 W2 W1 1 2 CATHODE (-) BLACK LEAD .650 16.51mm XX.XX DIMENSION STYLE: INCHES / MM GENERAL TOLERANCES UNLESS OTHERWISE SPECIFIED: A INCHES MM MATERIAL OPTOELECTRONICS SEE NOTES .500 12.7 190 BOSSTICK BLVD. SUITE 101 SAN MARCOS, CA 92069 U.S.A PHONE: (760) 560-1300, FAX: (760) 560-1301 EMAIL: vccsales@vcclite.com FINISH TITLE: SEE NOTES THIRD ANGLE PROJECTION PROPRIETARY AND CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF VISUAL COMMUNICATIONS COMPANY, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF VISUAL COMMUNICATIONS COMPANY, INC IS PROHIBITED. 8 7 6 5 4 3 CNX B CABLE ASSEMBLY DATE APPROVAL SIZE DRAWN K.Howard 9/28/10 CHECKED DPZ 11/29/10 SCALE: 1:1 DO NOT SCALE DRAWING 2 REV DWG. NO. B CNX B ASSY 001 SHEET 1 OF 1 1 A
CNX_B_G_4_1_24 价格&库存
很抱歉,暂时无法提供与“CNX_B_G_4_1_24”相匹配的价格&库存,您可以联系我们找货
