LMD300-CA00-0000-0000001
    WOLFSPEED
    ADAPTER PLATE LMD300 PLASTIC
LMD300-CA00-0000-0000001 数据手册
Cree® LMD300, LMD400 & LMD600 LED Module Drivers PRODUCT DESCRIPTION Cree LED modules provide lighting designers and manufacturers with simple, easy-to-adopt LED lighting solutions that FEATURES TABLE OF CONTENTS • Input voltage options: 100‑240 V, Order Codes.................................................2 100‑277 V, 120‑277 V & 220‑240 V • 0/1-10 V dimming support for Characteristics - LMD300 100- to 240‑V 0/1-10 V Dimming Driver.............................2 reduce luminaire development time and 100‑240 V, 100‑277 V, 120‑277 V & Characteristics - LMD300 120- to 277‑V speed time-to-market. Cree LMD300, 220‑240 V options 0/1-10 V Dimming Driver.............................3 LMD400 and LMD600 LED module drivers are specifically designed to work • DALI + Touch dimming support for 220‑240 V option Characteristics - LMD300 220- to 240‑V 0/1-10 V Dimming Driver.............................3 with the Cree LMH2 2000-, 3000‑, 4000- • Optimized for Cree LMH2 2000‑, and 6000‑lumen light sources to jump- 3000‑ 4000- and 6000‑lm light DALI + Touch Dimming Driver.....................4 sources Characteristics - LMD400 120- to 277‑V start the design process for recessed downlights, wall sconces or pendant lights in demanding end markets such • LMD400 enables California Title 24 compliance CLM-DS14 REV 3L LED MODULE DRIVER DATA SHEET Characteristics - LMD300 220- to 240‑V 0/1-10 V Dimming Driver.............................4 Characteristics - LMD600 100- to 277‑V as retail, museums, hospitality and 0/1-10 V Dimming Driver.............................5 restaurants. Dimming.......................................................6 Mechanical Dimensions..............................7 Wiring Diagrams........................................ 10 Thermal Design......................................... 13 Emergency Battery Operation.................. 13 Safety and Regulatory Notes.................... 14 WWW.CREE.COM/XLAMP Packaging.................................................. 16 Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 LMD300, LMD400 & LMD600 LED MODULE DRIVERS ORDER CODES LMD300 Nominal Input Voltage (VAC) Frequency (Hz) Typical Output Current (mA) Dimming Order Code 100-240 50/60 900 0/1-10 V LMD300-0040-C900-8030000 120-277 50/60 900 0/1-10 V LMD300-0040-C900-7030000 220-240 50/60 900 0/1-10 V LMD300-0040-C900-2030000 220-240 50/60 900 DALI + Touch LMD300-0040-C900-2020000 Nominal Input Voltage (VAC) Frequency (Hz) Typical Output Current (mA) Dimming Order Code 120-277 50/60 940 0/1-10 V LMD400-0048-C940-7030000 Nominal Input Voltage (VAC) Frequency (Hz) Typical Output Current (mA) Dimming Order Code 100-277 50/60 1700 0/1-10 V LMD600-0100-C1A7-7030000 LMD400 LMD600 CHARACTERISTICS - LMD300 100- TO 240‑V 0/1-10 V DIMMING DRIVER Order Code: LMD300-0040-C900-8030000 Characteristics Unit Minimum Input voltage range VAC 90 Input power Typical 264 W 40 Output current mA Output voltage V Driver efficiency (@ 55 °C) - with LMH2 2000‑lm light source % 85 Driver efficiency (@ 55 °C) - with LMH2 3000‑lm light source % 86 900 40 Power factor - with LMH2 2000‑lm light source 0.95 Power factor - with LMH2 3000‑lm light source LED driver case temperature • Maximum 0.95 °C 0 70 3-D models (.STEP files) for the LMD300 LED module drivers are available on the Cree website by selecting the Documentation tab on the LMH2 product page. Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 2 LMD300, LMD400 & LMD600 LED MODULE DRIVERS CHARACTERISTICS - LMD300 120- TO 277‑V 0/1-10 V DIMMING DRIVER Order Code: LMD300-0040-C900-7030000 Characteristics Unit Minimum Input voltage range VAC 108 Input power Typical Maximum 305 W 40 Output current mA 900 Output voltage V Driver efficiency (@ 55 °C) - with LMH2 2000‑lm light source % 85 Driver efficiency (@ 55 °C) - with LMH2 3000‑lm light source % 86 40 Power factor - with LMH2 2000‑lm light source 0.95 Power factor - with LMH2 3000‑lm light source 0.95 Dimming current @ 120 V mA 2.3 Dimming current @ 277 V mA 2.3 LED driver case temperature °C • 0 70 3-D models (.STEP files) for the LMD300 LED module drivers are available on the Cree website by selecting the Documentation tab on the LMH2 product page. CHARACTERISTICS - LMD300 220- TO 240‑V 0/1-10 V DIMMING DRIVER Order Code: LMD300-0040-C900-2030000 Characteristics Unit Minimum Typical Maximum Input voltage range VAC 207 230 264 Input power W 40 Output current mA 900 Output voltage V Driver efficiency (@ 55 °C) - with LMH2 2000‑lm light source % 85 Driver efficiency (@ 55 °C) - with LMH2 3000‑lm light source % 86 39 Power factor - with LMH2 2000‑lm light source 0.95 Power factor - with LMH2 3000‑lm light source LED driver case temperature • 0.95 °C 0 70 3-D models (.STEP files) for the LMD300 LED module drivers are available on the Cree website by selecting the Documentation tab on the LMH2 product page. Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 3 LMD300, LMD400 & LMD600 LED MODULE DRIVERS CHARACTERISTICS - LMD300 220- TO 240‑V DALI + TOUCH DIMMING DRIVER Order Code: LMD300-0040-C900-2020000 Characteristics Unit Minimum Typical Maximum Input voltage range VAC 207 230 264 Input power W 40 Output current mA 900 Output voltage V Driver efficiency (@ 55 °C) - with LMH2 2000‑lm light source % 81 Driver efficiency (@ 55 °C) - with LMH2 3000‑lm light source % 85 39 Power factor - with LMH2 2000‑lm light source 0.95 Power factor - with LMH2 3000‑lm light source LED driver case temperature • 0.95 °C 0 70 3-D models (.STEP files) for the LMD300 LED module drivers are available on the Cree website by selecting the Documentation tab on the LMH2 product page. CHARACTERISTICS - LMD400 120- TO 277‑V 0/1-10 V DIMMING DRIVER Order Code: LMD400-0048-C940-7030000 Characteristics Unit Minimum Input voltage range VAC 108 Input power Typical Maximum 305 W 48 Output current mA 940 Output voltage V Driver efficiency (@ 55 °C) - with LMH2 2000‑lm light source % 85 Driver efficiency (@ 55 °C) - with LMH2 3000‑lm light source % 86 Driver efficiency (@ 55 °C) - with LMH2 4000‑lm light source % 87 22-44 Power factor - with LMH2 2000‑lm light source 0.95 Power factor - with LMH2 3000‑lm light source 0.95 Power factor - with LMH2 4000‑lm light source 0.95 Dimming current @ 120 V mA 2.3 Dimming current @ 277 V mA 2.3 LED driver case temperature °C • 0 90 3-D models (.STEP files) for the LMD400 LED module driver are available on the Cree website by selecting the Documentation tab on the LMH2 product page. Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 4 LMD300, LMD400 & LMD600 LED MODULE DRIVERS CHARACTERISTICS - LMD600 100- TO 277‑V 0/1-10 V DIMMING DRIVER Order Code: LMD600-0100-C1A7-7030000 Characteristics Unit Minimum Input voltage range VAC 90 Input power mA Output voltage V Driver efficiency (@ 55 °C) - with LMH2 6000‑lm light source % Maximum 305 W Output current 102 1700 25-52 87 Power factor - with LMH2 6000‑lm light source 0.95 Dimming current @ 120 V mA Dimming current @ 277 V mA LED driver case temperature °C • Typical .05 .05 0 76 3-D models (.STEP files) for the LMD600 LED module driver are available on the Cree website by selecting the Documentation tab on the LMH2 product page. Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 5 LMD300, LMD400 & LMD600 LED MODULE DRIVERS DIMMING The LMH2 2000-, 3000‑ and 4000‑lm light sources can use the LMD300 LED module driver with either DALI + Touch dimming or 0/110 V dimming and use the LMD400 LED module driver with 0/1-10 V dimming. The LMH2 6000‑lm light source can use the LMD600 LED module driver with 0/1-10 V dimming. Driver Input Voltage Dimming Lowest Light Level LMD300-0040-C900-8030000 100-240 V 0/1-10 V 10% LMD300-0040-C900-7030000 120-277 V 0/1-10 V 10% LMD300-0040-C900-2030000 220-240 V 0/1-10 V 10% LMD300-0040-C900-2020000 220-240 V DALI + Touch 10% LMD400-0048-C940-7030000 120-277 V 0/1-10 V 10% LMD600-0100-C1A7-7030000 100-277 V 0/1-10 V 1% The LMH2 2000, 3000‑ and 4000‑lm light sources combined with the LMD300 DALI + Touch driver is a DALI‑certified device for use with DALI‑compliant dimmers. Caution - DALI dimming and Touch dimming should not be used on the same luminaire. Setting Up the LMD300 DALI + Touch Driver in Touch Control Mode The LMD300 DALI + Touch driver can be used in touch control mode in installations where DALI control is not installed. To set up touch control mode, wire the driver DALI terminals to 220- to 240‑VAC mains power through a pushbutton (a momentary switch rated for 220 to 240 VAC and 0.5 A) as shown in the Wiring Diagrams section of this data sheet. Multiple LMH2 modules can be connected together to be controlled by the same pushbutton. To activate touch control mode, turn on power to the LMH2 LED module without pressing the pushbutton, i.e., the switch is open. After one (1) second, the driver automatically enters touch control mode and the pushbutton can then be used to control the LMH2. Touch Control Mode Operation In touch control mode, a single pushbutton turns the LMH2 LED module on and off and changes its brightness. To turn the module on or off, press and release the pushbutton quickly (in less than 300 ms). When the module is on, change its brightness by pressing and holding the pushbutton. The brightness alternately increases or decreases each time the pushbutton is pressed and held. When the desired brightness is reached, release the pushbutton. The module will remain at this brightness level until the pushbutton is pressed and held again, even if it is turned off and back on. Two methods can be used to quickly reach maximum and minimum brightness. For maximum brightness instantly, double-click the pushbutton when the LMH2 LED module is on. Double-clicking means quickly pressing and releasing the pushbutton twice in succession (with less than 300 ms between presses). For minimum brightness, press and hold the pushbutton when the LMH2 is off. The LMH2 LED module turns on at minimum brightness and increases in brightness until the pushbutton is released. If multiple LMH2 LED modules are controlled by the same pushbutton, the modules can lose synchronization and not all perform the same action in response to the pushbutton. To synchronize all the modules connected to one pushbutton, press and hold the pushbutton Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 6 LMD300, LMD400 & LMD600 LED MODULE DRIVERS for at least one (1) second and release it, then double-click the pushbutton. All connected modules will then be on at maximum brightness, regardless of their previous states. Touch control mode operation is summarized in the following table. Module Operation in Touch Mode Pushbutton Operation Module On All off All on at previous brightness Brightness increases or decreases opposite of previous press and hold All on at minimum brightness, increasing brightness while pushbutton held Click Press and hold Module Off All on at maximum brightness Double-click MECHANICAL DIMENSIONS Physical Characteristics of the LMD300, LMD400 & LMD600 Drivers LMD300 100- to 240-V Driver Physical Characteristic 8 LMD300 120- to 277-V Driver LMD300 220- to 240-V Drivers 431.8 LMD400 120- to 277-V Driver LMD600 100- to 277-V Driver 440 Weight (g) 195 195 264 280 Maximum height (mm) 37.5 37.5 35 37.5 Maximum length (mm) 90 90 205 90 160 Maximum width (mm) 90 90 80 90 63 7 6 47 5 LMD300 100- to 240‑V and LMD300 & LMD400 120- to 277-V Drivers1 180 ± 10 STRIPPED 10 90 76.6 37.5 30 45 90 30 76.6 20 7.5 7.5 WIRE ROUTING SLOT TYP 9X 1 40 Tc LOCATION M3 OR #6 MOUNTING SLOT TYP 2X Dimensions for all the diagrams are in mm and are for reference only. For exact dimensions and tolerances, refer to the 3-D models (.STEP files) for the LMD300, LMD400 and LMD600 drivers available by selecting the Documentation tab on the LMH2 product page. Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 7 LMD300, LMD400 & LMD600 LED MODULE DRIVERS LMD300 220- to 240-V Driver - With Standard Covers 205 196 205 185 196 185 80 80 50 50 Tc LOCATION 80 Tc M3LOCATION OR #6 MOUNTING SLOT TYP #6 2X M3 OR MOUNTING SLOT TYP 2X 80 35 35 205 196 LMD300 220- to 240-V Driver - With Optional Conduit Covers 185 205 205 196 196 185 185 80 50 80 80 50 50 80 M3 OR #6 MOUNTING SLOT TYP 2X 80 80 M3 OR #6 35 M3 OR #6 MOUNTING SLOT MOUNTING SLOT TYP 2X TYP 2X 35 35 40 40 40 20 KNOCKOUT TYP 4X 20 KNOCKOUT TYP204XKNOCKOUT TYP 4X Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 8 LMD300, LMD400 & LMD600 LED MODULE DRIVERS LMD600 100- to 277-V Driver 160 61.6 23 23 50 47 47 Tc 6-32 MOUNTING MOUNTING 6-32 STUDS STUDS 39 39 88 WIRE WIRE LL == 150mm 150mm TYP. TYP. 1144 ..44 50.8 63 Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 9 LMD300, LMD400 & LMD600 LED MODULE DRIVERS WIRING DIAGRAMS Electrical Connection For the 100- to 240‑V, 100- to 277‑V and 120- to 277‑V LED module drivers, LMH2 LED module operation is accomplished by connecting the AC mains to the two (2) lead wires (line and neutral) from the driver and connecting the driver output wires to the input leads on the Cree LMH2 light source, as indicated in the following wiring diagrams. For the 220- to 240‑V LED module drivers, module operation is accomplished by connecting the AC mains to the appropriate terminal block pins. The 100- to 240‑V and 120- to 277‑V LED module driver lead wires are 152.4 mm long, 18 AWG with the ends stripped 10 mm. The 100- to 277‑V LED module driver lead wires are 150 mm long, 18 AWG with the ends stripped 10 mm. The 220- to 240‑V LED module drivers have poke‑in terminals. LMD300 100- to 240‑V Driver 0/1-10V CONTROL BLK - HOT RED WHT - NEU BLK TO LIGHT SOURCE VIO GRY BLK - HOT RED WHT - NEU BLK TO LIGHT SOURCE VIO GRY Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 10 LMD300, LMD400 & LMD600 LED MODULE DRIVERS LMD300 & LMD400 120- to 277‑V Drivers LMD300/ LMD400 LMD300/ LMD400 LMD300 220- to 240‑V 0/1 - 10 V and DALI + Touch Dimming Drivers - Touch Operation Not Required TO DALI BUS OR 0/1-10 V LMD300 LMD300 LMD300 LMD300 LMD300 LMD300 Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 11 LMD300, LMD400 & LMD600 LED MODULE DRIVERS LMD300 220- to 240-V DALI + Touch Driver LMD300 LMD300 LMD300 LMD300 LMD300 LMD300 LMD600 100- to 277‑V Driver Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 12 LMD300, LMD400 & LMD600 LED MODULE DRIVERS Wiring Strain Relief LMD300, LMD400 and LMD600 LED module drivers must not be suspended directly by the leads. Though the wiring from the LMD300, LMD400 and LMD600 LED module drivers is internally strain relieved, additional strain relief methods must be employed if the luminaire is to be suspended solely by the wiring, as in a pendant luminaire. THERMAL DESIGN Expected LMD300 Lifetime versus Temperature at Tc Point Tc (°C) @ 25 °C Room Ambient Expected Operation Life (Hours) LMD300 100- to 240-V 0/1-10 V Dimming Driver LMD300 120- to 277-V 0/1-10 V Dimming Driver LMD300 220- to 240-V 0/1-10 V Dimming Driver LMD300 220- to 240-V DALI + Touch Dimming Driver 35,000 70 70 70 70 50,000 65 65 65 65 Expected LMD400 Lifetime versus Temperature at Tc Point Tc (°C) @ 25 °C Room Ambient Expected Operation Life (Hours) LMD400 120- to 277-V 0/1-10 V Dimming Driver 35,000 90 50,000 80 Expected LMD600 Lifetime versus Temperature at Tc Point Tc (°C) @ 25 °C Room Ambient Expected Operation Life (Hours) LMD600 100- to 277-V 0/1-10 V Dimming Driver 50,000 76 EMERGENCY BATTERY OPERATION The LMD300, LMD400 and LMD600 LED module drivers are constant‑current supplies. Interrupting the driver current with a battery supply is an acceptable method of emergency or power outage operation. An acceptable installation should also include a switching mechanism that prevents the battery power from entering the driver through the DC output leads. Confirming backup power supply compatibility is the responsibility of the luminaire manufacturer or installer. Please refer to the backup power supply manufacturer’s instructions for installation and further product information. Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 13 LMD300, LMD400 & LMD600 LED MODULE DRIVERS SAFETY AND REGULATORY NOTES The following tables show the safety and regulatory certifications for the LMD300 and LMD400 LED module drivers. LMD300 100- to 240‑VAC Driver Standard J61347-1 (H20) J61347-1 (H21) Safety File Number CJP2012109004-0578 EN 61347-1 EN 61347-2-13 CE SELV equivalent CJP2012109004-0578 IP-20 EN 55015 Electromagnetic compatibility IEC 61000-3-2 IEC 61000-3-3 CJP2012109004-0578 IEC 61547 Environmental RoHs LMD300 & LMD400 120- to 277‑VAC Drivers Standard LMD300 220- to 240‑VAC Driver File Number Standard File Number UL®/cUL recognized (UL8750) Class 2 power supply UL – Damp rated E333437 Air handling (plenum) Safety 5VA flame rating EN 61347-1 EN 61347-2-13 CE SELV equivalent RZCE2012-0221LVD 101342922CHI-001 EN 61347-2-13 CE SELV equivalent IP-20 IP-20 EN 55015 EN 55015 IEC 61000-3-2 Electromagnetic compatibility EN 61347-1 IEC 61000-3-3 IEC 61547 RZCE2012-0221EMC R10051625-EMC IEC 61000-3-2 IEC 61000-3-3 RZCE2012-0205LVD RZCE2012-0512LVD RZCE2012-0574LVD-M1 RZCE2012-0205EMC RZCE2012-0512EMC RZCE2012-0574EMC-M1 IEC 61547 FCC 47 CFR Part 15 Class B/ ICES 03 Regulatory Environmental IEEE C.62.41-1991 Class A (surge) NEMA 410 RoHS RoHs Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 14 LMD300, LMD400 & LMD600 LED MODULE DRIVERS LMD600 100- to 277‑VAC Driver Standard File Number UL/cUL recognized (UL8750) Class 2 power supply UL – Damp rated E333437 Air handling (plenum) Safety 5VA flame rating EN 61347-1 EN 61347-2-13 CE SELV equivalent 101564185CHI-001 IP-20 EN 55015 IEC 61000-3-2 Electromagnetic compatibility IEC 61000-3-3 R10273893-EMC IEC 61547 FCC 47 CFR Part 15 Class B/ ICES 03 Environmental RoHS Safety Certification Together, the LMH2 light source combined with the LMD300, LMD400 or LMD600 LED module driver is “suitable for damp locations; covered ceilings.” Final luminaire designs should go through safety certification as required, which is the responsibility of the luminaire manufacturer. Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 15 LMD300, LMD400 & LMD600 LED MODULE DRIVERS PACKAGING LMD300 100- to 240–V LED module drivers are packaged in boxes of 10, which are then combined in cartons of 5 boxes, or 50 LMD300 120- to 240–V drivers. LMD300 and LMD400 120- to 277–V LED module drivers are packaged in boxes of 10, which are then combined in cartons of 5 boxes, or 50 LMD300 or LMD400 120- to 277–V drivers. LMD300 220- to 240‑V LED module drivers are packaged in boxes of 5, which are then combined in cartons of 10 boxes, or 50 LMD300 220- to 240‑V drivers. LMD600 100- to 277–V LED module drivers are packaged in boxes of 5, which are then combined in cartons of 5 boxes, or 25 LMD600 100- to 277–V drivers. Box and carton sizes are as follows. Box of 10 LMD300 100- to 240-V LED module drivers: 255 x 194 x 98 mm Carton of 5 LMD300 100- to 240-V driver boxes: 509 x 275 x 222 mm Box of 10 LMD300 or LMD400 120- to 277-V LED module drivers: 255 x 194 x 98 mm Carton of 5 LMD300 or LMD400 120- to 277-V driver boxes: 509 x 275 x 222 mm Box of 5 LMD300 220- to 240‑V LED module drivers: 285 x 211 x 91 mm Carton of 10 LMD300 220- to 240‑V driver boxes: 588 x 471 x 243 mm Box of 5 LMD600 100- to 277‑V LED module drivers: 490 x 235 x 90 mm Carton of 5 LMD600 100- to 270‑V driver boxes: 510 x 510 x 255 mm Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree® and the Cree logo are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 16 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Cree, Inc.: LMD300-0040-C900-2020000 LMD300-0040-C900-7030000 LMD300-0040-C900-2030000 LMD400-0048-C9407030000 LMD300-CA00-0000-0000001 LMD600-0100-C1A7-7030000
LMD300-CA00-0000-0000001 价格&库存
很抱歉,暂时无法提供与“LMD300-CA00-0000-0000001”相匹配的价格&库存,您可以联系我们找货
